shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Tue Jan 21, 2020 11:00 am Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
If you're willing to do your homework and devote time to building your own LiFePo4 battery then you can save a lot of cash.
Look at this YouTube channel
_________________ Brandon
Instagram @joannthevan |
vwhammer Samba Member
Joined: May 20, 2006 Posts: 998 Location: Boulder CO.
Posted: Tue Jan 21, 2020 11:04 am Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
https://youtu.be/i4oJYhGKw1s
This might get you started.
Edit: Dang! Beat me to it. |
baltik Samba Member
Posted: Tue Jan 21, 2020 11:39 am Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
As far as BMS is concerned there are 3 options that are emerging in the market
Option 1: Deligreen -
https://www.aliexpress.com/item/32852570488.html
PROs: cheap, easy and proven
CONs - no low temp cutoff, not suitable for colder climates, no ability to set parameters, no ability to monitor usage/capacity etc.
(side note, seller has offered me to add a temp sensor for $1 extra, however this is completely unproven and one should test thoroughly prior to implementing in cold weather)
Option 2: Smart BMS - 100A+bluetooth https://www.aliexpress.com/item/4000425316662.html
PROs: low temp cutoff, some customization via bluetooth app. Ability to monitor remaining capacity, voltage etc
CONs: still relatively unproven, no ability to read capacity/voltage etc without connecting via bluetooth
Option 3: Electrodacus
https://electrodacus.com/
PROs: by far the most complete/customizable option. Suitable for 4 & 8 battery banks. Built in Solar controller. Easy to read real time displays with all data. Historical logging
CONs: by far most expensive, requires more work/wiring. SBMS 40 not suitable for high loads (SBMS 120 is)
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Tue Jan 21, 2020 1:32 pm Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
baltik wrote: |
CONs: by far most expensive, requires more work/wiring. SBMS 40 not suitable for high loads (SBMS 120 is) |
There is also a substantial lead time on the Electrodacus and as a solar charge controller it should be noted that it does not do MPPT. |
jocoman Samba Member
Joined: August 11, 2016 Posts: 427 Location: Ottawa, Canada
Posted: Tue Jan 21, 2020 1:58 pm Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
The big down side for some of us, with this is the requirement to have at least 0C temperature for charging.
If you want to do any camping around the freezing mark, then this is not a good solution. Too bad _________________ '86 Westfalia 2.0L Zetec
'97 Volvo 850 AWD Turbo
" The fun never stops" |
Posted: Tue Jan 21, 2020 2:15 pm Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
jocoman wrote: |
If you want to do any camping around the freezing mark, then this is not a good solution. Too bad |
You can do heaters to get the batteries up to temp before charging but naturally this complicates things a bit.
If you had a decent load on the batteries there is the possibility that the battery would warm up on its own to the point that it could begin charging. |
ledogboy Samba Member
Joined: September 19, 2005 Posts: 578 Location: Scappoose, OR / Oakland, CA
Posted: Tue Jan 21, 2020 3:15 pm Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
jocoman wrote: |
A heating solution for that confined space would likely be simpler than many of the projects people have done to fit batteries into non-stock parts of the van (whether rear bench, Peace Vans-style frame rail install, etc...) _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
baltik Samba Member
Posted: Tue Jan 21, 2020 4:15 pm Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
Better yet get one of the cheap diesel heaters and get it going to heat the batteries and the van at the same time. |
Posted: Tue Jan 21, 2020 4:26 pm Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
That's one of the reason I installed heater here next to water tank. I hope to put a LiFePo4 in this area too!
Posted: Tue Jan 21, 2020 5:03 pm Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
Now that's something to think about! Good idea! txs _________________ '86 Westfalia 2.0L Zetec
baltik Samba Member
Posted: Wed Jun 03, 2020 2:23 pm Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
I was just looking at those batteries for my set up and wondering if they would fit under the seat.
The dimensions are the same as the 120ah and people have done that so...
I have been thinking about moving my starter battery to the rear and putting some of those batteries under both front seats.
However, I have a 250 amp alternator and 300 watts of solar and don't really plan on being off grid for more than 2 or 3 days at a time so 300ah of battery is probably overkill. _________________ Pretty normal daily driver build
https://www.thesamba.com/vw/forum/viewtopic.php?t=708418&highlight=
4x4 build
https://www.expeditionportal.com/forum/threads/volkswagen-vanagon-4x4-conversion.162055/ |
ProspectiveOwnergon Samba Member
Posted: Wed Jun 03, 2020 4:49 pm Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
vwhammer wrote: |
However, I have a 250 amp alternator and 300 watts of solar and don't really plan on being off grid for more than 2 or 3 days at a time so 300ah of battery is probably overkill. |
When you do a subaru conversion, the passenger area under the side intake is completely blank. Can you put a water tight battery in that area as the starter battery? |
baltik Samba Member
Posted: Wed Jun 03, 2020 5:06 pm Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
I’ve seen others successfully do the battery relocation
Pics below
That was my plan as well to go with the dual lithium, but I came to the realization it’s overkill, I can camp in my westy without a microwave
Posted: Wed Jun 03, 2020 5:10 pm Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
Thanks for the link. $550 shipped for 150ah is incredible. _________________ Brandon
rontv Samba Member
Posted: Thu Jun 11, 2020 1:46 am Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
woow, i like 120Ah
i finally went for a renogy 100Ah LifePO4, on sale in UK (i live in NL) for 600GBP, still aroun 800USD i gues, but should fit nicely in the second battery bay
now considering which DC-DC charger to use, with or without MPPT
full blown redarc, the renogy one or a german one without MPPT for which i could use my old Victron one
Love the redarc but expensive
anybody any other suggestions? |
pnwkayaker Samba Member
Joined: April 01, 2008 Posts: 920 Location: Sammamish, WA
Posted: Thu Jun 11, 2020 6:08 am Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
Do you have a link to the Renogy battery? So far I haven't seen any 100Ah off-the-shelf battery that will fit in the aux battery location, biggest ones I've seen are the GoWesty or Battleborn 50Ah batteries (the solution from this thread uses lithium-cells with an external BMS)
It took me several months to make up my mind (price was the biggest concern), but I finally bought the Redarc unit (25A version), should be finishing the installation this weekend. I like the simplicity of having the DC-DC and MPPT solar charger in the same device, with the Redarc taking care of all the charge balancing.
rontv wrote: |
woow, i like 120Ah
_________________ 87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link) |
jacklar Samba Member
Joined: April 08, 2018 Posts: 9 Location: Ontario, Canada
Posted: Sat Jun 13, 2020 12:24 pm Post subject: Re: New Record? 120 usable Amp Hours under Driver's seat |
Thanks for the link and explaining your setup. I just pulled the trigger on the 150AH cells shipped to Canada. I maybe back to ask some questions. I’m going to set this up w/ a solar setup and figure out a method of warming them when temps get to 0 for chilly spring or fall nights. I’ll keep folks updated on my journey of setting mine up as a relative newbie. |
