Weird "won't shift" episode today...
carsdlt
carsdlt is offline
PostPosted: Tue Aug 13, 2019 8:44 pm    Post subject: Weird "won't shift" episode today... Reply with quote
So I'm driving home from work today...backed out of my space and pulled out of the parking lot...up to a traffic lite...into first and pulled away...down into second..GRIND..GRIND...WTF!!??...back into neutral and into third..GRIND..GRIND. Left it in neutral and coasted off the road onto the shoulder. It was as if the clutch cable had let go...but it hadn't .Pedal and effort where normal . No noises or odd sounds, vibrations...nothing. Now I'm sitting there at idle and I try first gear...click, right in, no problem. Now second right in also... Third,forth all ok. So I take off again and it shifts perfectly all the way home. Has anyone ever had this happen to them? Very strange.
Thanx, DLT
'73 181 stock 1600 - "Dr. Bombay"
"If it works, don't fix it....let it break on its own."
YDBD
YDBD is offline
PostPosted: Tue Aug 13, 2019 9:44 pm    Post subject: Re: Weird "won't shift" episode today... Reply with quote
Check your shift coupler under the back seat under the panel in the tunnel.
It may have slipped out and back in with a little force, it may be too loose allowing play or your nose cone on your transaxle may be loose or have a bad mount.
[/img]
'56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing"
carsdlt
carsdlt is offline
PostPosted: Wed Aug 14, 2019 11:28 pm    Post subject: Re: Weird "won't shift" episode today... Reply with quote
Replaced it not long ago but I will check it out. 80 mile trip today...no problemo Rolling Eyes
Thanx, DLT
74 Thing
74 Thing is offline
PostPosted: Thu Aug 15, 2019 6:56 am    Post subject: Re: Weird "won't shift" episode today... Reply with quote
Did you also replace the shift rod bushing that hangs from inside the tunnel and supports the shift rod just behind the shifter location? Also check your three transmission mounts (esp the front nosecone mount).
carsdlt
carsdlt is offline
PostPosted: Thu Aug 15, 2019 9:55 pm    Post subject: Re: Weird "won't shift" episode today... Reply with quote
Yes. Bushing replaced 5k ago..Got some PM that's due so will check all this out when that gets done and let you know what I find out. Stay tuned...
Thanx, DLT
