mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2797 Location: North Carolina
Posted: Thu Sep 24, 2020 8:35 am Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
First, if you're really good with a caulk gun, I don't think you should have to do any squishing, but I'm not. In fact, I'm terrible for some reason. So...
I found that using a screen installation tool like below to "squish" the seam sealer in did a much much much better job than my finger and produced a clean, professional looking line. 2 years later, still looks great, with no return of the rust I removed/treated.
https://www.amazon.com/Prime-Line-MP7503-Screen-Ro...KHB4V2P69Z _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
DuncanS Samba Member
Posted: Thu Sep 24, 2020 2:33 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
What door seams? Are you talking about the joint between the outer and inner door panel? I bought an '87 under the tourist delivery program and brought it back to Vermont. With no undercoating, after ten years, the car had to be junked as the rust was beyond repair. Even then there were no issues with the joint between the outer and inner door panels. |
RainierSyncro Samba Member
Joined: February 26, 2013 Posts: 809 Location: Seattle
Posted: Thu Sep 24, 2020 5:42 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
Abscate wrote: |
Tell everyone here you are taking the windows out to paint, even if you aren’t.
Thank me later
Good luck with that project! |
Not letting this comment go by without a huge thumbs up! |
remraf Samba Member
Posted: Thu Sep 24, 2020 7:16 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
I'm in the process of doing my seams and body work right now. I am by no means an expert but am getting guidance from a seasoned body person. As far as seams go I'm doing the following:
I scraped all old seam sealer from seams
Glass beaded seams
Used a utility knife to probe and verify I couldn't produce any rust dust from seams
treated seams with ospho rust converter
cleaned seams again with a commercial grease and dust remover (can't remember name but it's for paint prep)
sprayed seams with etching primer
van is now getting close to having primer sprayed over etching primer
---couple of notes
If you find rust in seam look on the inside of seam. Often you'll find the rust started behind the seam and worked it's way out. Depending on how deep down the rabbit hole you want to go you may be looking at panel replacement. Luckily for me the only panel replacement was minor behind rear wheels.
The seams have been tedious but there is another syncro west at the shop where mine is. Can't say for sure but it appears to have a less and 4 year old paint job on it and every seam is bubbling with rust. The other paint work looks nice but I can't imagine spending that much money for that outcome.
Good luck! Amazing work you've done on the conversion. I'll keep my 2.1 chugging along with hopes what you're doing will be plug and play someday |
yabert Samba Member
Posted: Sat Sep 26, 2020 5:46 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
5 entire and long days was needed to prepare the van for the primer. What a job it was!!!
Most of the job was to reach the bare metal. Welded repairs and potty was not so complex, but only because my quality standard for this paint job is low.
Plan is to finish the paint in fews days.
Here a interesting fact from this summer.
I had to take some concrete blocks and concrete bags at hardware.
In fact, it was 1300 lbs of conrete blocks on the 400 lbs trailer and 1000 lbs of concrete bags in the van. So around 7500 lbs total.
I was really happy and impressed by the manner the van was moving this around. Everything was fine and climbing a small hill wasn't a problem.
Of course, I didn't tried freeway for 100 km with this.
_________________ My 360 volts Vanabolt: https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Posted: Sat Sep 26, 2020 5:53 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
DuncanS wrote: |
when i had each door off there was sealer in the lips of the doors where the metal folded over on the door. My rear hatch seams were gone, and there had been a little bit of rust starting to develop where the hydraulic lifts attached |
Posted: Sat Sep 26, 2020 5:54 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
wow, nice. Glad the hitch held up!
yabert wrote: |
yabert Samba Member
Posted: Thu Oct 01, 2020 6:14 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
Here is the van before/after.
Hard to believe there is 80% blue and 20% green in our paint mix, but it's like that.
We expected a result a bit more blue.
The paint is far from perfection as there is orange peel, flies in the paint, some paint drip, some body filler imperfection, etc.
Still, we are super happy because there is way less holes in this van, no more fuel filler and no more opening on driver side center panel because electricity is coming from inside the van (water too).
It look very well at 10 feets and more
Is there the same proverb in english than in french? It a kind of: ''Beautiful from far, far from be beautiful.
No, really it look good to us and we still like to drive it a lot.
vino de vano Samba Member
Joined: September 10, 2016 Posts: 359 Location: columbia gorge
Posted: Thu Oct 01, 2020 6:28 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
that looks much nicer, cool color. I've been fallowing your thread and love your conversion. Has the ground clearance been a issue? _________________ what a long strange trip it's been |
yabert Samba Member
Posted: Thu Oct 01, 2020 6:35 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
vino de vano wrote: |
Has the ground clearance been a issue? |
Ground clearance (8'') isn't an issue anymore as I changed for stiffer front coil springs and bigger wheels/tires. _________________ My 360 volts Vanabolt: https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 785 Location: WestWorld Nanaimo BC
4Gears4Tires Samba Member
Posted: Fri Oct 02, 2020 7:12 am Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
^ hah, indeed.
The fresh paint looks great, man! The bumpers and grills could use a bit of love too, now. It's pretty easy to scuff the grill and hit it with matte black paint, it makes a world of difference. _________________ '87 Syncro
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Fri Oct 02, 2020 7:53 am Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
Way to go, Yan. The complete lack of gas filler is really going to confuse people!!
And yes, "Beautiful from afar - but far from beautiful." _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Merian Samba Member
Posted: Sun Oct 04, 2020 12:35 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
surprised it wasn't re-purposed as a charging plug in _________________ .... |
edbee Samba Member
Joined: October 15, 2009 Posts: 49 Location: BC, Canada
Posted: Fri Dec 25, 2020 4:45 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
Wow Yabert, congratulations on such an impressive job. I just discovered your build thread https://www.diyelectriccar.com/threads/westfalia-t3-with-chevy-bolt-drivetrain.198653/page-9
I admire your creative problem solving ability and many skill sets.
Thank you for sharing the process, it is an inspiration. One day I may be driving an electric vanagon...
thanks!
Ed
PS - any estimate on hours invested in the build. _________________ 1991 Syncro Westfalia - Bostig Zetec
1989 Syncro Doka - Volvo powered
other misc vehicles including a '46 M16 1.5 ton truck (Studebaker) |
jimf909 Samba Member
Posted: Fri Dec 25, 2020 4:55 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
Nice bump. I hadn't seen the repaint of this really neat van.
It seems a number of folks are working on e-conversions for Vanagons, at least two in Seattle alone. _________________ - Jim
Abscate wrote: |
yabert Samba Member
Posted: Mon Jun 21, 2021 12:41 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
As my Van start to move under electric power in june two years ago now, it time for a small update:
-It's still amazing how quick it start from the line, how easy it's to pass on the freeway or how easy it climb a hill. Thanks to the instant 270 lb-ft of torque and 200 hp!
-Still no mechanical problem since our return of 16 000 km roadtrip in 2019.
-Maintenance: Changed two tires and two front upper ball joint
That it. Really, there is no that much to say. We use this van as our only family vehicule and everything work well since more than 2 years now.
We regularly pull a trailler with 1000-1500 lbs of stuff inside (dirt, steel, sand) and I'm still amaze how well it drive.
It's an incredible van. The confort and wind noise are far from what it is in a new car, but except that, we like it a lot.
47 000 km done and counting. Oh! And of course we still continue to pay around 2$ in fuel (electricity) to travel 100 km _________________ My 360 volts Vanabolt: https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Mon Jun 21, 2021 1:04 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
Sounds great!
Viva la Spark! _________________ This free advice is worth exactly what you paid for it.
rogertj Samba Member
Joined: October 07, 2008 Posts: 505 Location: Tijuana, Baja California. Mexico
Posted: Mon Jun 21, 2021 5:01 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
Where was I when this was published! Heck im even looking in to buying a Bolt! Awesome contribution! _________________ Roger
Had a Carbureted ABA after engoing the heck out of it now going for ABA 2.0 Jetta EFI ill put a garrett in to the tin can later or maybe go electric?
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Mon Jun 21, 2021 8:48 pm Post subject: Re: Vanagon 100% electric with Chevy Bolt drivetrain |
yabert wrote: |
47 000 km done and counting. Oh! And of course we still continue to pay around 2$ in fuel (electricity) to travel 100 km |
Hi and congrats!
What's the range one one charge usually? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
