richierich Samba Member
Posted: Sat Aug 17, 2019 3:09 pm Post subject: Re: Spring loaded pushrod tubes. |
QRP wrote: |
I think its funny how this turned into this style vs that style.
All I asked was did anyone else use a larger washer . . .
FWIT . . . no stock pushrod tube ever leaked oil, never ever ever.
Hahahaha
And I guess no one here has ever modified a part instead of buying a new one . . . JESUS |
Come on man, you ought to know nothing is ever that simple on here _________________ Blah..... |
QRP Samba Member
Joined: April 27, 2008 Posts: 1710 Location: NORTH HOLLYWOOD,CA
Posted: Sat Aug 17, 2019 4:00 pm Post subject: Re: Spring loaded pushrod tubes. |
richierich wrote: |
QRP wrote: |
Hahahaha
Come on man, you ought to know nothing is ever that simple on here |
You got that right . . . HAHAHAHA |
slalombuggy Samba Member
Posted: Mon Aug 19, 2019 5:18 am Post subject: Re: Spring loaded pushrod tubes. |
Now that I know about this valve shim mod I'm going to use it on my Scat tubes. Thanks. BTW the Scat tubes I have, use 3 internal o-rings and are good to clear .610 lift out of the box, something i had troubles doing with stock style tubes
brad |
Supercompdad Samba Member
Joined: August 10, 2019 Posts: 17 Location: West Central Illinois
Posted: Mon Aug 19, 2019 5:42 am Post subject: Re: Spring loaded pushrod tubes. |
I just removed a set of which 7 were leaking bad. The PO tried using silicone in the tubes to seal them. There were plugs of it going back and forth on the pushrods.
He obviously lost the instructions, if I had seen this sooner I might have tried to use them. lol. |
Lsdeep Samba Member
Joined: November 09, 2016 Posts: 19 Location: Jamaica
Posted: Mon Dec 23, 2019 4:08 pm Post subject: Re: Spring loaded pushrod tubes. |
for what it is worth (and i know it will change nobodies mindset about it). i used windage type widemouth tubes when putting my engine back together some month ago. within weeks a couple started to leak (just a little, but they leaked). switched over to scat spring loaded at that point, have to admit main reason at the time was that i really was fed up with the idea to losen up the heads/ leave alone taking them off. so far so good - they work fine and no noticeable leak yet (daily driver, in for about 2mth). will they leak at some point? possibly yes. but i really don't get the spring loaded tube bashing in general.
cheers, L _________________ If one does not fail at times, then one has not challenged himself. |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6024 Location: CONGERS, N.Y.
