moogie32 Samba Member
Joined: April 06, 2005 Posts: 663 Location: Connecticut
Posted: Tue Mar 31, 2020 2:19 pm Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
Went to loosen the front lugs...and that’s where the day ended. Blaster, tapping, tugging, pleading, none of it seemed to matter. Ordered an impact wrench.
I've had success by using a breaker bar with a long pipe fitted over the body of it to extend it out and provide more torque _________________ RIP HBB (1984-2009)
Du liefst so gut
Du warst so schön
Doch leider musst du von uns gehn |
Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Tue Mar 31, 2020 2:38 pm Post subject: Re: '59 Karmann Ghia fever |
moogie32 wrote: |
Trylon wrote: |
I've had success by using a breaker bar with a long pipe fitted over the body of it to extend it out and provide more torque |
Seems to be the Muir method. Since I don’t have a breaker bar, had to decide which route I wanted to go.
Wish me luck! _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Tue Mar 31, 2020 3:04 pm Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
moogie32 wrote: |
Trylon wrote: |
Wish me luck! |
I too have always used a breaker bar to loosen/tighten lug bolts.
Typically I can free them with just the 24" breaker bar, but at times I've had to resort to slipping a length of pipe over the breaker bar to amplify my leverage.
Of course, the increased leverage then exerts increased pressure on the socket and that becomes the weak link if it's just a "regular" socket.
(Yeah, I've cracked and ruined a couple regular sockets that way. )
Moral of The Story - Whether you use an extended breaker bar or an impact driver, you'll probably want to use an impact socket that's meant to handle the extra torque. |
Trylon Samba Member
Posted: Tue Mar 31, 2020 4:32 pm Post subject: Re: '59 Karmann Ghia fever |
KGCoupe wrote: |
Trylon wrote: |
moogie32 wrote: |
Trylon wrote: |
Wish me luck! |
Thanks KG! They are coming with the driver! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
Posted: Tue Mar 31, 2020 4:57 pm Post subject: Re: '59 Karmann Ghia fever |
Impact wrenches are great tools but keep in mind, they don't always accomplish the task at hand.
Sometimes an arsenal of tools is required to break a stubborn bolt loose.
An impact is great for shock value.
Try to loosen it, let it rattle the fastener a bit, reverse the direction to actually tighten it, let it rattle a bit.
Reverse direction to loosen, let it rattle.... back and forth you go. Tight loose tight loose tight loose.
If it is really tight, once it begins to move switch to hand tools so you can "feel" the fastener as it comes.
Heat will build up quickly on tight fasteners. Let it cool down, apply penetrating oils and run it in tight again, let it sit.
After awhile try loosening it until it gets tight. Apply oils and tighten, loosen tighten, work it back and forth but do so gently.
You will actually feel it loosen and begin to come.
Be careful, all the way out. They often tighten up again right at the end.
Ghia
Vanagon
Beetle
Trylon Samba Member
Posted: Tue Mar 31, 2020 4:59 pm Post subject: Re: '59 Karmann Ghia fever |
djkeev wrote: |
Dave |
As you might imagine, I know none of this— thanks for enlightening me! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Tue Mar 31, 2020 7:45 pm Post subject: Re: '59 Karmann Ghia fever |
For leverage, does your hydraulic jack's handle fit over an existing tool? IMO most handles are made of strong, hollow pipe and can be removed from the jack with one or two bolts.
What you are now finding is one of the tips I often list for people about to make a long trip with a new classic VW. Many tire stores use way too high of a torque to set the rims back on after mounting new tires. As a result, the new owner can't budge the lug bolts off. If a flat tire occurs on the trip and the tools in the car don't get the bolts loose, that's one huge impediment for getting on your way. So while still at home, break loose every single lug bolt one at a time. Don't even need to remove the bolts for this trial. Then tighten to a closer spec using your body weight as estimated leverage length out on the lug wrench.
Your front wheels have a lot of movement. My guess is incorrectly adjusted/way loose king or link pins. |
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3304 Location: So. Cal. Oceanside GFK!
Posted: Tue Mar 31, 2020 7:56 pm Post subject: Re: '59 Karmann Ghia fever |
It seems to me rust shouldn’t be much of a issue like a car that’s been sitting for a long time, sounds like it’s been over tighten? _________________ It's not about the window, it's about the people.
German Folks |
Trylon Samba Member
Posted: Tue Mar 31, 2020 7:58 pm Post subject: Re: '59 Karmann Ghia fever |
lonotch wrote: |
It seems to me rust shouldn’t be much of a issue like a car that’s been sitting for a long time, sounds like it’s been over tighten? |
I too was surprised. Again. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Tue Mar 31, 2020 11:24 pm Post subject: Re: '59 Karmann Ghia fever |
I sometimes have the problem that, because the front is so light, the front wheels turn while I am trying to break loose the lug bolts So sometimes I need to chalk them. (Depends on how full the gas tank is, too).
The bearing play can be adjusted very easily, you may want to check some Youtube videos on that. There's a good one from a guy with an orange bug (but I can't find it right now), so you may want to try to tighten them, before tearing into something Be careful, the thread on one side (drivers' side?) is reversed. But quite an easy job.
Edit: Found it, it's this one :
(It shows changing them as well, but you get the picture of how all is put together.)
_________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Wed Apr 01, 2020 3:53 am Post subject: Re: '59 Karmann Ghia fever |
Vladiiiii wrote: |
I sometimes have the problem that, because the front is so light, the front wheels turn while I am trying to break loose the lug bolts ] |
Is right. They’re only supposed to be torqued to 70-90ftlbs. If the wheels turn while you’re trying to break them loose, they’re WAaaay overtorqued. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Apr 01, 2020 3:57 am Post subject: Re: '59 Karmann Ghia fever |
If it's dry, my garage floor is quite slick. If it's wet, it's like ice I may need to paint at least 2 trails (where the wheels go) with some abrasive stuff. _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
Posted: Wed Apr 01, 2020 4:39 am Post subject: Re: '59 Karmann Ghia fever |
To be honest, I'm postponing this to until the Ghia is finished. And the garage is barely large enough for it anyway, so it will never carry snow inside. It's kinda hard to get into with our more "modern" cars, so it is kept for the Ghia and some tools.
But the idea is here, nontheless. It was so wierd when trying to loosen the bolts (they weren't on too tight), the wheel started turning and squeaking on the floor . My wife held the brake and loose they came. Anyway, back to topic.....
PS: Munich only got 1 or 2 days of snow this whole winter…. _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
Trylon Samba Member
Posted: Wed Apr 01, 2020 6:44 am Post subject: Re: '59 Karmann Ghia fever |
djkeev wrote: |
I've driven VW's since the 60's, never fully expected to arrive anywhere incident free. |
May I humbly suggest that this pithy information be imparted to each and every new forum member who begins a thread in the vein of “Thinking about succumbing...”
Thank you for your attention to this matter.
The Management _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Wed Apr 01, 2020 6:56 am Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
djkeev wrote: |
The Management |
Umm... My car is easily the most driven & abused car in the Ghia forums & I have no problem taking it anywhere I want (literally.) without fear of it breaking down. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Apr 01, 2020 7:56 am Post subject: Re: '59 Karmann Ghia fever |
TDCTDI wrote: |
Trylon wrote: |
djkeev wrote: |
The Management |
Umm... My car is easily the most driven & abused car in the Ghia forums & I have no problem taking it anywhere I want (literally.) without fear of it breaking down. |
I'm saying nothing..I don't want to jinx what has been a remarkably .....able Ghia.
However I did find this under the rear seat when it first arrived:
...as well as a tow rope. _________________ John.
Posted: Wed Apr 01, 2020 8:09 am Post subject: Re: '59 Karmann Ghia fever |
John Moxon wrote: |
...as well as a tow rope. |
Some states used to require that road flares be kept in a vehicle.
Did you light one off? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
