Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Sat Oct 17, 2020 1:14 pm Post subject: Re: '59 Karmann Ghia fever |
Glenn wrote: |
Trylon wrote: |
No response from Tim yet. |
I had a similar problem. I had my Weber IDAs rebuilt and everything was fine. I was on the first drive and I felt a loss of power, so I quickly got home. I found the needle valve was stuck on the right carb. I used a fresh can of brake parts cleaner and it freed up. I reinstalled and never had another problem. If that's keeping you from driving, you can give it a try. |
Thank Glenn. The interior is completely gutted — I have no driving plans.
I did poke a small pin in the hole and it got better but it still sticks.
I will get a new one either from Tim or some parts store. _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
Trylon Samba Member
Posted: Sun Oct 18, 2020 7:07 am Post subject: Re: '59 Karmann Ghia fever |
Tim got back to me last night and said all those check valves do that if you push them in with your finger. He suggested pushing it and and twisting it a bit. I did that and it got much better. I could still get it to stick but not as strongly and for the most part gravity pulled it down.
Put it back in the carburetor this morning and buttoned it down. Reattached the coil to the distributor as well as the ground cable. After looking at it a bit to make sure everything looked right. I gave it a shot.
Strong turnover, no start.
Poured a bit of gas into the carburetor and closed down my new manual choke.
It started!
It ran!
Sounded a bit harsh, opened the choke a bit and it calmed down.
Turned it off and checked the oil (which I do often). Looked a bit low so added a bit (things are leaking left and right under the car with it up at an angle— still haven’t put it down since installing the choke as I wanted to test it fully before doing so).
Started up again immediately, running very nicely!
People, I just installed a choke cable, a 28 PCI carburetor and matching distributor, and troubleshot a sticky check valve— successfully!
Even my wife was impressed! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Sun Oct 18, 2020 7:21 am Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
Even my wife was impressed! |
Great...
BTW, your 40hp Big Cap is on it's way to it's new owner. So everyone is happy. _________________ Glenn
Member #1009
#BlueSquare |
Marcdeb Samba Member
Trylon Samba Member
Posted: Sun Oct 18, 2020 8:06 am Post subject: Re: '59 Karmann Ghia fever |
Glenn wrote: |
Trylon wrote: |
Great...
BTW, your 40hp Big Cap is on it's way to it's new owner. So everyone is happy. |
Nice! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Marcdeb wrote: |
Great job. |
Thanks Marc!
Looking forward to similar successes from you! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Sun Oct 18, 2020 9:44 am Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
Marcdeb wrote: |
Great job. |
Thanks Marc!
Looking forward to similar successes from you! |
My car's coming along. It is all painted as of Friday, but I want the doors, engine lid, and trunk lid back on before unveiling the "new" look. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Braukuche Samba Member
Posted: Sun Oct 18, 2020 10:29 am Post subject: Re: '59 Karmann Ghia fever |
Figured that was your problem.
I thought I pointed this out earlier, but those replacement check valves are notorious for sticking. When I rebuild carbs I always use the old ones, never the new ones.
Ask him if has any originals, if not PM me your address and I’ll mail you one. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Trylon Samba Member
Posted: Sun Oct 18, 2020 11:15 am Post subject: Re: '59 Karmann Ghia fever |
Marcdeb wrote: |
Trylon wrote: |
Marcdeb wrote: |
Great job. |
Thanks Marc!
My car's coming along. It is all painted as of Friday, but I want the doors, engine lid, and trunk lid back on before unveiling the "new" look. |
What a tease! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Sun Oct 18, 2020 11:16 am Post subject: Re: '59 Karmann Ghia fever |
Braukuche wrote: |
Ask him if has any originals, if not PM me your address and I’ll mail you one. |
Yes, you did Brau!
I now see that my problem was I didn’t know what a check valve was at the time!
Thanks. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Sun Oct 18, 2020 11:36 am Post subject: Re: '59 Karmann Ghia fever |
Lest you think I am running low on things to do:
Tried it out on the accelerator sleeve— what a cool tool!
Also installed a battery disconnect switch to make wire replacement and testing easier.
Ain’t we got fun? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Sun Oct 18, 2020 12:12 pm Post subject: Re: '59 Karmann Ghia fever |
Marcdeb wrote: |
Your son may not want your car someday, but at the rate you're going, he's most likely going to be pleased with these nice new tools. |
Ha! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Sun Oct 18, 2020 1:44 pm Post subject: Re: '59 Karmann Ghia fever |
Looks so nice for the most part on the inside, thinking about just removing the little bit of loose paint, doing rust treatment, and leaving the inside au natural. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Sun Oct 18, 2020 2:44 pm Post subject: Re: '59 Karmann Ghia fever |
Good start with the battery cover. You saw from the other cover in the 2-unit ad, that those 2 triangular tabs hold a fiber-based liner which acts as a non-conductive insulator so that the battery terminals don't short circuit against the metal cover.
Bench grinder/wire wheel is among my most utilized tools. Good practice to wear full-width goggles or a face shield in case debris or a brush strand gets knocked loose and flies upward.
Next step: In the upside-down shot, you can see that the turned-out metal edges have some rust pockmarks. You can carefully file those edges flat back to good metal with a metal file. Sand the upper, visible surfaces of the turned-out edges with 120 grit to knock down the rust craters. Spray the entire cover with rust converter. Let dry. Spray self-etch primer to seal the bare metal, or Rust-O-Leum rusty metal primer. 220 wet sand. Then the sandable primer/filler. Wet sand with 320, then 2 light coats of semi-gloss black. |
Trylon Samba Member
Posted: Sun Oct 18, 2020 2:57 pm Post subject: Re: '59 Karmann Ghia fever |
Rome wrote: |
Yes, I have the liner and it looks serviceable. That’s why the inside looks good!
Thanks for the instructions— let see how I might screw them up! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Sun Oct 18, 2020 11:29 pm Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
Yes, I have the liner and it looks serviceable. |
If it is the original one it will be made of tar and fibre. You can make it like new just by heating it up so the tar melts. A hot air gun will do that well enough without a naked flame setting things alight. With the heat you can remove kinks and creases and also re-establish that dark black colour.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Trylon Samba Member
Posted: Mon Oct 19, 2020 4:47 am Post subject: Re: '59 Karmann Ghia fever |
sputnick60 wrote: |
Trylon wrote: |
Nicholas |
Looks original to me (circled one):
Thanks for the tip! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Mon Oct 19, 2020 2:49 pm Post subject: Re: '59 Karmann Ghia fever |
And it still runs!
Time to visit Ralph... _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
The aussie Trimmer Samba Member
Joined: July 05, 2006 Posts: 385 Location: Western Australia
Posted: Mon Oct 19, 2020 3:40 pm Post subject: Re: '59 Karmann Ghia fever |
I'm intrigued; why would anyone do that to the dash support, I can't think of anything that would require that modification?? _________________ Cheers,
Kev.
Drive with your lights on (Be aware be seen) help others GIVE Blood |
