Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Tue Apr 20, 2021 4:47 am Post subject: Re: '59 Karmann Ghia fever |
Pretty dusty. Car is always covered... and has been since I rubbed on it for hours. I heard something about ceramic but not sure it applied to our car.
So I can dust it with something appropriate and not fear micro scratches? _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Tue Apr 20, 2021 2:18 pm Post subject: Re: '59 Karmann Ghia fever |
Keep a good microfiber car duster in your car. When you uncover it and pull it out of the garage, you can always blow it off first with your air compressor, the duster will pick up any remaining particles the air didn't get. Just lightly dusting it over the body shouldn't cause any scratches, as long as you don't grind down on it.
Car looks great!
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Trylon Samba Member
Posted: Tue Apr 20, 2021 2:27 pm Post subject: Re: '59 Karmann Ghia fever |
Good to know— thanks Jeff! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Tue Apr 20, 2021 4:19 pm Post subject: Re: '59 Karmann Ghia fever |
Pulled the parking lights:
Look kinda crusty. Can they be saved?
And finally the headlight harness is out:
And the illusion of 1959 slowly emerges:
I think I should replace the headlights as they are mismatched— suggestions welcome. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Braukuche Samba Member
Posted: Tue Apr 20, 2021 4:34 pm Post subject: Re: '59 Karmann Ghia fever |
Shouldn’t the turn signal indicators be screw terminal? Those must be from a 60 or later car.
Mine are oxidized like that too. They can be rechromed but the socket assembly has to come out. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Trylon Samba Member
Posted: Tue Apr 20, 2021 4:46 pm Post subject: Re: '59 Karmann Ghia fever |
Seem like they have been there since the beginning but I’m game.
Where does one find screw terminal bulb holders? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Tue Apr 20, 2021 4:59 pm Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
Where does one find screw terminal bulb holders? |
Is everything else screw terminal on your car? 1960 is the year they switched to spade terminals I think. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Trylon Samba Member
Posted: Tue Apr 20, 2021 5:03 pm Post subject: Re: '59 Karmann Ghia fever |
Braukuche wrote: |
Trylon wrote: |
Is everything else screw terminal on your car? 1960 is the year they switched to spade terminals I think. |
No sir. But what is on our car rarely seems to have any bearing as to what should be on it. Likely changed when it was converted to 12v? To be fair, I think that was 40 years ago and that could easily create the illusion of “since the beginning.” _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
obus Samba Member
Joined: March 08, 2001 Posts: 11071 Location: just off Garden State Parkway Exit 81
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3304 Location: So. Cal. Oceanside GFK!
Posted: Tue Apr 20, 2021 6:34 pm Post subject: Re: '59 Karmann Ghia fever |
obus wrote: |
Braukuche wrote: |
Trylon wrote: |
Might be late 60 change to spade terminal? Mine are screw on terminals
and yes to what Jeff said about dusting the car. |
I think the change might be in 61 maybe or maybe late 60? I heard screw on terminals tail lights on a 60 Ghia are very hard to find among all the other 60 parts that are rare also.
I’m sure a expert in here will know for sure.
I might have a set of front turn signals that are screw on terminals in my stash, but I know they are much rougher than yours. _________________ It's not about the window, it's about the people.
German Folks |
Posted: Tue Apr 20, 2021 6:45 pm Post subject: Re: '59 Karmann Ghia fever |
lonotch wrote: |
obus wrote: |
Braukuche wrote: |
Trylon wrote: |
I might have a set of front turn signals that are screw on terminals in my stash, but I know they are much rougher than yours. |
I had a 60 Beetle convert and it was all screw terminal. So I think it was 61 that they went to spades on type 1.
Type 2 started out with screw terminals for the 1960s, then mid production went to push on terminal. My June 60 double cab is spade.
There is someone selling reproduction front turn signal assemblies but I can’t remember who or if they had screw or spade terminals. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Trylon Samba Member
Posted: Wed Apr 21, 2021 4:33 am Post subject: Re: '59 Karmann Ghia fever |
Seems as though there were some screws left on the strut:
Not sure if they never arrived, or I removed them, or Dwayne did... _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Loren Samba Member
Posted: Wed Apr 21, 2021 9:56 am Post subject: Re: '59 Karmann Ghia fever |
The 60 model year was the last for screw terminals. The terminals on your bulb holders are KGPR reproductions and your bases look shot. I have a set of jigs I made to drill out the mounting studs and replace them, but it looks like some one already attempted a repair and botched it Your Ghia would have had screw terminals, but they are extremely hard to find since they were only used for two years and most have succumbed to the elements. You will likely have to stick with spade terminals. You can replace the terminals, though some bases have a screw to hold them in place and others have them riveted in place. It's not hard to drill out the rivet and drill and tap the hole for a screw. You can find NOS bases, but most seem to be the the European version with only one terminal instead of two (US version has two terminals), but you can replace the single terminal with dual terminals.
For example:
https://www.thesamba.com/vw/classifieds/detail.php?id=2435851
Here are the reproductions being offered:
https://www.thesamba.com/vw/classifieds/detail.php?id=2002599
I have never seen one in person so I don't know how nice they are in person, but they look nice in the photos.
This thread shows how to replace riveted terminals:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20 |
Trylon Samba Member
Posted: Wed Apr 21, 2021 4:12 pm Post subject: Re: '59 Karmann Ghia fever |
Headlight wiring.
Hoping we can do better with the ground than that wonky cabling.
Also, given today’s headlights, aren’t we stuck with slide-on terminals for them?
Here’s what it looks like from the back:
So, who do I speak to around here to get next week off?
Everett? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Trylon Samba Member
Posted: Thu Apr 22, 2021 4:08 am Post subject: Re: '59 Karmann Ghia fever |
EverettB wrote: |
Trylon wrote: |
Everett? |
Send me your boss's number, I'll text him |
I meant a week off from Karmann Ghia Fever.
I think you’re my boss. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
Trylon Samba Member
Posted: Thu Apr 22, 2021 8:10 am Post subject: Re: '59 Karmann Ghia fever |
Oh dear.
With non-refundable reservations made, I fear that I may have to tender my resignation unless a suitable accommodation can be found. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Thu Apr 22, 2021 8:37 am Post subject: Re: '59 Karmann Ghia fever |
Quit whining & get to work & remember, do something, ANYTHING, to your project every day & you will get closer to completing it. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
