Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Thu Apr 22, 2021 8:43 am Post subject: Re: '59 Karmann Ghia fever |
Well, there’s a voice we have not heard for a while!
I guess my point is that it’s going to be difficult to work on our car while I am in Puerto Rico.
Just trying to ease into the seemingly unavoidable panic when KGF takes a hiatus. _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
Trylon Samba Member
Posted: Thu Apr 22, 2021 8:49 am Post subject: Re: '59 Karmann Ghia fever |
Now that’s all that poor lowlight needs. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
c21darrel Samba Member
Trylon Samba Member
Posted: Thu Apr 22, 2021 1:18 pm Post subject: Re: '59 Karmann Ghia fever |
Continuing with headlight wiring.
Realized I hadn’t put the seals on the signal lights:
In the interest of getting back on the road, I think I will just put back the signal light holders that were there and wait for a good set to come up for sale.
Reinstated a headlight dimmer switch — none was there when I got it:
Not sure what screws are used to attach it.
Wired up the front fuse box:
The instructions say the blue-white wire is to be attached to this fuse box but there is no such wire in the original wiring diagram. Hopefully it will become clear as the wiring progresses. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
PeteSC Samba Member
Posted: Thu Apr 22, 2021 1:28 pm Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
The instructions say the blue-white wire is to be attached to this fuse box but there is no such wire in the original wiring diagram. Hopefully it will become clear as the wiring progresses. |
The blue/white wire is there...look at the hi-res diagram linked here:
https://www.thesamba.com/vw/archives/info/wiring/58ghia_600dpi.jpg
Given the orientation of your photo it looks like it would go on the top right. |
Trylon Samba Member
Posted: Thu Apr 22, 2021 1:41 pm Post subject: Re: '59 Karmann Ghia fever |
Too funny— I somehow missing it coming out the other side! Was only looking at the screw that has nothing on it.
Thanks Pete! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Marcdeb Samba Member
Trylon Samba Member
Posted: Thu Apr 22, 2021 2:45 pm Post subject: Re: '59 Karmann Ghia fever |
Slow and steady and fun!
I do take extra care to check and recheck wires before I connect them so that I won’t be saddled with mystery connections when I am done.
Looks like yours is gonna be sweeeeet! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Thu Apr 22, 2021 5:19 pm Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
Looks like yours is gonna be sweeeeet! |
Well original at least. Like you, I want to make it look like the day it was built, if it's doable. That is - except for the 62 dash which I love. I can't imagine how I could have found all the parts that were missing if I didn't have TheSamba resources. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Trylon Samba Member
Posted: Thu Apr 22, 2021 5:21 pm Post subject: Re: '59 Karmann Ghia fever |
c21darrel wrote: |
I thought you had sealed beams?? |
Yeah, our car has a lot of things. It was originally at a Hamburg dealership though. Just asking about something I know little about. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
PeteSC Samba Member
Posted: Thu Apr 22, 2021 5:26 pm Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
Thanks Pete! |
Happy to help! You’re doing great on all of this.
Regarding the screw on your fuse block with nothing in it; I can’t tell if it’s present on your block but from the diagram there appears to be a bridge that’s supposed to connect those two terminals on the left. |
Trylon Samba Member
Posted: Thu Apr 22, 2021 5:28 pm Post subject: Re: '59 Karmann Ghia fever |
PeteSC wrote: |
Trylon wrote: |
Thanks Pete! |
Yes, I checked on the bottom. It’s there.
Hope I remember where I left off when I get back. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3304 Location: So. Cal. Oceanside GFK!
Posted: Thu Apr 22, 2021 5:49 pm Post subject: Re: '59 Karmann Ghia fever |
IIRC the screws that hold the high beam switch on are counter sunk flat head sheet metal screws, most of if not all the screws on low lights are flat heads not Phillips heads. _________________ It's not about the window, it's about the people.
German Folks |
Trylon Samba Member
Posted: Thu Apr 22, 2021 5:51 pm Post subject: Re: '59 Karmann Ghia fever |
lonotch wrote: |
IIRC the screws that hold the high beam switch on are counter sunk flat head sheet metal screws, most of the screws on low lights are flat heads not Phillips heads. |
That seems right. Thanks. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Braukuche Samba Member
Posted: Thu Apr 22, 2021 7:06 pm Post subject: Re: '59 Karmann Ghia fever |
If yours was Euro delivery then it came not only with different lenses but also headlight lamps and chrome ring. You’d have to get the whole package. They look cool. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Trylon Samba Member
Posted: Thu Apr 22, 2021 7:14 pm Post subject: Re: '59 Karmann Ghia fever |
Delivered to Raffay in Hamburg December 1958 according to the birth certificate.
Would love to make it actually look like that fact. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
