Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Thu May 06, 2021 4:05 am Post subject: Re: '59 Karmann Ghia fever |
rbsurfguy wrote: |
You want to keep your car all original, why would you hack that grounding tree off? Is it not original? Those grounding points are practically the foundation of your wiring, since as you know, everything must be grounded properly to function. Where are you going to place or replace it? I wouldn't take away such an important part of your system.
Jeff |
Ha! Pretty sure you will not see that monstrosity in any 1959 manual.
But, hey, correct me if I’m wrong. _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Thu May 06, 2021 4:07 am Post subject: Re: '59 Karmann Ghia fever |
I don't know, that's why I was asking. There must be some original grounding points somewhere. Do you think some PO welded those in that spot? Maybe someone has a pic of an original grounding tree, I'd be interested in seeing that.
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Trylon Samba Member
Posted: Thu May 06, 2021 4:11 am Post subject: Re: '59 Karmann Ghia fever |
rbsurfguy wrote: |
Jeff |
That is my thought— easy way to ground everything without having to track down poor original grounding points. Why would there be spade terminals when everything else is screw? Further, I don’t believe the new harness provides any such collection of grounding wires. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Thu May 06, 2021 4:17 am Post subject: Re: '59 Karmann Ghia fever |
No sign of such a tree here, and no sign of the collection of grounding wires that would be making there way to it:
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Thu May 06, 2021 5:16 am Post subject: Re: '59 Karmann Ghia fever |
Agree, the standard screw terminals for your year vs the spade terminals is odd. But from all the talk we have on this site about electrical problems, it almost always comes down to bad grounding, I know I had that problem. So even an early model like yours, there must be grounding points somewhere.
Why are you and I the only ones awake talking about this? C'mon people, wake up clarify so we can get on with our day!!!
2012 Passat-Sold
Trylon Samba Member
Posted: Thu May 06, 2021 5:41 am Post subject: Re: '59 Karmann Ghia fever |
Later Ghia— I spy some grounding points?
Also, I see we seem to be missing a tie down for a vent conduit. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
VeloMikey Samba Member
Posted: Thu May 06, 2021 6:37 am Post subject: Re: '59 Karmann Ghia fever |
rbsurfguy wrote: |
Jeff |
Early cars don't have a grounding lug. Everything is grounded thru the body or chassis. _________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
Trylon Samba Member
Posted: Thu May 06, 2021 7:19 am Post subject: Re: '59 Karmann Ghia fever |
VeloMikey wrote: |
rbsurfguy wrote: |
Jeff |
Early cars don't have a grounding lug. Everything is grounded thru the body or chassis. |
Thanks! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Braukuche Samba Member
Posted: Thu May 06, 2021 7:21 am Post subject: Re: '59 Karmann Ghia fever |
No spade connectors on a 59. My later Ghias have them. Those were likely added when they did the funky wiring job. I’d grind them off and touch the area up with some paint. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Trylon Samba Member
Braukuche wrote: |
No spade connectors on a 59. My later Ghias have them. Those were likely added when they did the funky wiring job. I’d grind them off and touch the area up with some paint. |
Yep, seems to be the consensus. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Thu May 06, 2021 1:21 pm Post subject: Re: '59 Karmann Ghia fever |
M5 0.8
Bolt size for lowlight wiper motor!
Wired up the motor and screw terminal switch and gave a whirl:
I realized that I had not added the grounding tab on the motor but was happy that it seems to be grounding anyway.
Attempted to wire up the parking circuit. Oddly, it will then park when I power up. If I switch the wipers on and then off, it parks and then parks again and again... Gotta think about what is happening. The switch itself is not grounded and perhaps that is causing this somehow.
Have not found any wires in the harness kit for connecting the switch to the motor (just the switch to the fuse block). I used some of the wires that I pulled. Clearly, there has to be a better way of connecting wires to the motor as the bare wire is not held well.
Also put the vent controls back together:
Will hold off installing until I get the driver’s side duct in. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
c21darrel Samba Member
Trylon Samba Member
Posted: Thu May 06, 2021 4:44 pm Post subject: Re: '59 Karmann Ghia fever |
c21darrel wrote: |
Your air control flippers look fantastic. |
I’ll say thanks but still looking for the joke here. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Trylon Samba Member
Posted: Thu May 06, 2021 4:57 pm Post subject: Re: '59 Karmann Ghia fever |
Nice!
I think blue dots are not for lowlights though. Thought I might simple paint them until I saw they were recessed as well. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Thu May 06, 2021 5:55 pm Post subject: Re: '59 Karmann Ghia fever |
Trylon wrote: |
c21darrel wrote: |
I’ll say thanks but still looking for the joke here. |
Seals and flippers are not a joking matter for Darrel. |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
Loren Samba Member
Posted: Fri May 07, 2021 12:38 pm Post subject: Re: '59 Karmann Ghia fever |
Not to worry. The levers are not side specific and Trylon has already faced the blue dots to the front of the car so you won't see them unless you crawl under the dash and look at the "back" of the lever knobs. This guy thinks of everything down to the last detail! |
Trylon Samba Member
Posted: Fri May 07, 2021 12:40 pm Post subject: Re: '59 Karmann Ghia fever |
Loren wrote: |
So one would think— more likely I just put them in upside down by accident. Anyway, I think there are dots on both sides. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
