Speed-o question
Iowa Mark
Iowa Mark is offline
PostPosted: Sun Aug 18, 2019 5:15 pm    Post subject: Speed-o question Reply with quote
The oval window I drug home a few months ago has a speedometer in it that seems odd. VDO 90 mph date stamped 7.56 with a non clear needle and a large hole on the top of the dial for, I suspect is the high beam indicator. I did a quick search and found no matches. Anyone have a clue? There seem to be several things odd about this car.
billb
billb is offline
PostPosted: Mon Aug 19, 2019 8:40 am    Post subject: Re: Speed-o question Reply with quote
It was likely rebuilt by someone using the 56 housing and a later speedometer.
FritzCP
FritzCP is offline
PostPosted: Mon Aug 19, 2019 10:19 am    Post subject: Re: Speed-o question Reply with quote
its for a lowlight ghia
Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller
Iowa Mark
PostPosted: Mon Aug 19, 2019 3:34 pm    Post subject: Re: Speed-o question Reply with quote
Bingo! Just checked out a low light rebuild and there it was in the dash. The guy who used to own this car was not afraid to modify things. Must be a hundred extra holes in it! Thanks.
