Strike two small car
BackpackerA1
BackpackerA1 is offline
PostPosted: Tue Aug 20, 2019 6:48 am    Post subject: Strike two small car Reply with quote
Finally found my propane leak. came from the heater that you know who installed. digging into this mess itís the worst install Iíve ever seen. I guess the old adage if you want something done right you have to do it yourself proves to be true once again.
dgbeatty
dgbeatty is offline
PostPosted: Tue Aug 20, 2019 7:23 am    Post subject: Re: Strike two small car Reply with quote
Please post photos and receipts.
When all else fails read the instructions. Schau in das Buch
danfromsyr
danfromsyr is offline
PostPosted: Tue Aug 20, 2019 9:46 am    Post subject: Re: Strike two small car Reply with quote
with this being your 1st post.. what was Strike 1?
mikemtnbike
mikemtnbike is offline
PostPosted: Tue Aug 20, 2019 10:00 am    Post subject: Re: Strike two small car Reply with quote
yeah, I'm curious too- actually relevant as I'm shopping conversion kits/options right now.
1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie"
In an abundance of water, the fool is thirsty.
MarkWard
MarkWard is offline
PostPosted: Tue Aug 20, 2019 10:02 am    Post subject: Re: Strike two small car Reply with quote
Great first post. There is a feedback section for this.
1982 Vanagon Camper with ALH TDI conversion.
1990 Vanagon Camper Syncro conversion.
BackpackerA1
PostPosted: Tue Aug 20, 2019 10:04 am    Post subject: Re: Strike two small car Reply with quote
Strike 1 resulted in my van on the lift over a long holiday weekend due incorrectly supplied parts. I do however need to take partial credit for my assumption that professionals take their time and do things right the first time.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Tue Aug 20, 2019 10:11 am    Post subject: Re: Strike two small car Reply with quote
Their "reputation" is richly earned...
Casey--
Volkswagens powered by Volkswagen
'89 Bluestar TDI
'01 Weekender VR6
Oly Bulli
djkeev Premium Member
djkeev is offline
PostPosted: Tue Aug 20, 2019 10:16 am    Post subject: Re: Strike two small car Reply with quote
First off, WELCOME to the site.
I'm sorry your first post is about problems with a vendor.
It should be noted that there is a forum specifically for feedback.
We will end this thread so you can repost.
I will encourage you to use that forum for your complaint.
https://www.thesamba.com/vw/forum/viewforum.php?f=14
Dave
Ghia
Vanagon
Beetle
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Vanagon All times are Mountain Standard Time/Pacific Daylight Savings Time
