Sweller341 Samba Member
Posted: Wed Aug 21, 2019 4:03 pm Post subject: High comp with dtm shroud? |
Would the DTM fan shroud be worth if I wanted to run a higher compression ratio in a stock motor? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Wed Aug 21, 2019 4:06 pm Post subject: Re: High comp with dtm shroud? |
Bone stock.. heads, cam valves?
Why? _________________ Glenn
Member #1009
#BlueSquare |
kadub Samba Member
Joined: November 04, 2004 Posts: 444 Location: Auburn, Wa
Posted: Wed Aug 21, 2019 4:10 pm Post subject: Re: High comp with dtm shroud? |
What is the goal here? _________________ Karl
aka Turbobaja |
Posted: Wed Aug 21, 2019 4:38 pm Post subject: Re: High comp with dtm shroud? |
Well stock displacement but whatever upgrades necessary to handle a higher CR. What upgrades would I need to do? Reason for stock displacement is because I like small displacement motors and I'm not hunting for high hp. Also I know that the higher the CR the more heat is produced and the DTM was designed for bigger motors, so would it cool better with the higher CR? |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6032 Location: CONGERS, N.Y.
Bama Dave Samba Member
Posted: Wed Aug 21, 2019 5:24 pm Post subject: Re: High comp with dtm shroud? |
No longer available... _________________ David Richerson
1970 Beetle
1971 Super
1972 Baja
hellthorne wrote: |
First off, I know i made stupid decisions that led to my predicament, so while you are welcome to tell me that I am an idiot for doing the things I did, please know that I am already aware of this. |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Wed Aug 21, 2019 5:26 pm Post subject: Re: High comp with dtm shroud? |
I know a guy that is selling one. |
busey Samba Member
Joined: October 19, 2016 Posts: 420 Location: Sun City Arizona
Posted: Wed Aug 21, 2019 5:33 pm Post subject: Re: High comp with dtm shroud? |
A "legendary shroud"?, according to the description in the ad. I don't know of anyone or have ever seen any of the the Big Boy California shops running the DTM shroud. It seems every other badass build (even turbo builds) is running the Bernie Bergmann Porsche style. Jus sayin _________________ No turning back now, "Its Blow thru or No thru" baby! |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Wed Aug 21, 2019 6:01 pm Post subject: Re: High comp with dtm shroud? |
Sweller341 wrote: |
No, it would not be worth it.
A stock type 1 doghouse does a wonderful job.
I almost went with the Bergmann shroud but the only people that had positive things to say about it was the Bergmann site which is quite convincing by the way.
Since I plan on mostly cruising the mountains for 4-6 hours at a clip I stuck with proven stock cooling components. _________________ Volkswagen!
(Compression 8.7:1) |
busey Samba Member
Posted: Wed Aug 21, 2019 6:13 pm Post subject: Re: High comp with dtm shroud? |
jeffrey8164 wrote: |
Sweller341 wrote: |
Since I plan on mostly cruising the mountains for 4-6 hours at a clip I stuck with proven stock cooling components. |
Years ago i saw an eye catching doublecab on the highway making a trek from Southern Cal to Central Cal and was shocked to see the inside of the engine compartment was sporting a Bernie Bergmann shroud. Ive asked that doublecabs owner who went by the name of "lizard" of Lizard Motorsports how his motor runs with that shroud and he has said, Just Fine! _________________ No turning back now, "Its Blow thru or No thru" baby! |
Glenn Mr. 010
Posted: Wed Aug 21, 2019 6:39 pm Post subject: Re: High comp with dtm shroud? |
Last Bermann engine I worked on was a 2332, the car was towed in. The #3 exhaust valve seat came out and jammed the valve open. On talking it apart, 2 other valve seats were loose. Also it was built with 311b rods that looked like they were clearanced on a bench grinder. The case was clearanced with an axe. The valve stems were stretched and the engine had signs of overheating.
The engine had 6000 miles and was a boat anchor.
We built a new long block for the customer but told him we would not reinstall the 911 shroud. He was also told if he installed there would be no warranty. _________________ Glenn
Member #1009
#BlueSquare |
busey Samba Member
Posted: Wed Aug 21, 2019 6:46 pm Post subject: Re: High comp with dtm shroud? |
busey wrote: |
Sweller341 wrote: |
Years ago i saw an eye catching doublecab on the highway making a trek from Southern Cal to Central Cal and was shocked to see the inside of the engine compartment was sporting a Bernie Bergmann shroud. Ive asked that doublecabs owner who went by the name of "lizard" of Lizard Motorsports how his motor runs with that shroud and he has said, Just Fine! |
Believe it or not, that doublecab is the one i saw hauling ass equipped with a Bernie Bergmann. How those Cali boys have been doing it, who knows, but they always seem to be several steps ahead of the rest of the field.
[/quote] _________________ No turning back now, "Its Blow thru or No thru" baby! |
slalombuggy Samba Member
Posted: Wed Aug 21, 2019 7:15 pm Post subject: Re: High comp with dtm shroud? |
Pat Downs said I'd be fine running my Bergmann fan on my new FI turbo 2332. He's built a lot of engines using them. FAT also uses them a lot.
To the OP, your factory shroud will be more than adequate for your needs. It will keep much larger engines with high compression cool. Higher compression doesn't nessasarily translate into higher engine temps.
brad |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Wed Aug 21, 2019 7:51 pm Post subject: Re: High comp with dtm shroud? |
Just run a factory or 36hp shroud. More compression might not even raise temps if the compression is adequate for the valve events. Are you using another cam than stock? _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Posted: Wed Aug 21, 2019 8:04 pm Post subject: Re: High comp with dtm shroud? |
bugguy1967 wrote: |
Just run a factory or 36hp shroud. More compression might not even raise temps if the compression is adequate for the valve events. Are you using another cam than stock? |
no |
Posted: Wed Aug 21, 2019 8:06 pm Post subject: Re: High comp with dtm shroud? |
Hey week ago it was not available at the Type IV store. Just went back and it is back -- $625 8 -12 weeks.
To be honest the DTM is an amazing fan housing, it gets all 4 cylinders equal cooling -and the oil cooler- that said it and the Bernie stuff do not have Thermostats or vanes. But for warm weather guys, OK .. Or High Performance.
Cold climate like NY, you may never get running temp. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
SGKent Samba Member
Posted: Wed Aug 21, 2019 9:22 pm Post subject: Re: High comp with dtm shroud? |
8:1 on a 1600 won't kill it. Burn premium. I ran quite a few bus 1600 DP motors at 8:1 with no issues, stock DP doghouse shroud. I'd run 8:1 on my 2L T4 but 2L t4 already overheat, and I have to smog test so the NOX might go up quite a bit. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Aug 21, 2019 9:33 pm Post subject: Re: High comp with dtm shroud? |
Yeah, what's high compression to you? 1. You can't run a stock carburetor with the DTM, so you'll need duals. 2. If you run dual 2-barrels, like 36 IDFs, you can safely run about 8.25:1 on 91 octane.
I installed a DTM shroud on a Type 1 that I built, and it was an absolute nightmare. It took about ten hours to do all the necessary mods to make it fit. There were huge issues. Go through my gallery and you'll see that I needed to mill off 3/8"-1/2" from my alternator stand to get the shroud low enough to bolt onto my heads. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
