Jim Bear Samba Member
Joined: March 25, 2006 Posts: 670 Location: Watkinsville, GA
Posted: Mon Sep 02, 2019 7:14 am Post subject: Re: 1974 Westfalia: how to remove sink cabinet |
I'll drop this question here since it is somewhat relevant--I have removed my sink and ice box cab's from my '74 since they are largely useless to me. bokuglen, will you be putting yours back in? If not, what are your intentions for the space(s)? I will likely just replace with stained paneling, although I'd like to go with a jump seat behind the driver's seat at some point and a more streamline and "thinner" cab behind the passenger seat. _________________ "You're either on the bus, or you're off the bus." ~kk
'85 Vanagon Westy - George In the Stable 2020-?/'74 Weekender - Ophelia In the Stable 2007- ?/'69 Beetle Convertible - SOLD 2017-2020/'67 Beetle - September SOLD 2013-2016 /'67 SO42 Westy - Sage SOLD 1996-2001 /'69 Transporter - Baby Blue SOLD 1995-1995/'72 Westy - Nelly - SOLD 1990-1995--STOP FRACKING |
bokuglen Samba Member
Joined: June 14, 2006 Posts: 43 Location: Southeast Pennsylvania
Posted: Sun Sep 01, 2019 6:31 pm Post subject: Re: 1974 Westfalia: how to remove sink cabinet |
Thanks for the advice, guys ! |
busdaddy Samba Member
Posted: Fri Aug 23, 2019 6:39 pm Post subject: Re: 1974 Westfalia: how to remove sink cabinet |
The 74 sink is attached to the bulkhead and the floor in a few places (L brackets), maybe the upper wall too (can't recall), the plumbing stays in the cabinet, you have to tilt it away from the wall to clear the vent tube and then lift straight up to get the drains out of the floor (remove screwed on seal plate underneath first). Before you start make sure you have blankets on the floor in the bus and a soft place to put it once it's out, the lower edges of the laminate are super brittle and crack easily if you put it down on something mean and slide it sideways. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Daisy71Kombi Samba Member
Joined: July 21, 2011 Posts: 141 Location: post falls ID
Posted: Fri Aug 23, 2019 4:14 am Post subject: Re: 1974 Westfalia: how to remove sink cabinet |
I did it on my 71 and it was pretty easy. I replaced the flooring and needed it out of the way. It took 15 minutes and other than disconnecting a few fasteners and lines nothing was an issue. It weights a lot for it's size so 2 people helped make it easy. Put a queen bed in so it's in storage. Really opened up the space. _________________ Her name is Daisy. 1971 Kombi camper. Pop up tent. 77K miles. Engine rebuilt recently. Just completed brakes with all new parts! |
Posted: Wed Aug 21, 2019 4:53 pm Post subject: 1974 Westfalia: how to remove sink cabinet |
I need to remove the sink cabinet from my 1974 VW Westfalia bus. How do i remove the sink cabinet? I can see bolts holding it in place (behind the driver's seat , etc. ) but I don't see how to work around the plumbing. Does it disconnect from the cabinet somehow? I did some searching and could not find sink removal instructions for my year.
