SGKent Samba Member
Posted: Wed Oct 21, 2020 9:00 am Post subject: Re: Another oil leak to track down |
most likely where the oil comes out will be clean because the detergent in it will wash everything else away. Also you might consider using a dye like Gary suggests. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Oct 21, 2020 9:41 am Post subject: Re: Another oil leak to track down |
Whaanga wrote: |
Well - Robbie was here a couple of weeks ago and we looked at it. At first he thought it might be lose nuts at the heads. We checked them and the lowers were nice and firm. He suspects that it's probably leaking from the sealing at the joint at the case halves.
Here's what I see is the main source of the leak.
Perhaps I'll have to pull the engine to check the head nuts above the valve train. Has any one else had a leak from this same place that my have any thoughts?
But - thank you for following up. |
Probably 80-90% of engines with very many miles on them are wet on the lower third of the cylinders. If its not dripping excessively this is just not something to worry about. |
crownline Samba Member
Joined: September 10, 2010 Posts: 593 Location: Northwoods of WI
Posted: Wed Oct 21, 2020 9:55 am Post subject: Re: Another oil leak to track down |
Get yourself one of these and call it a day. _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL] |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Wed Oct 21, 2020 2:02 pm Post subject: Re: Another oil leak to track down |
thanks for the update! |
timvw7476 Samba Member
Posted: Wed Oct 21, 2020 3:43 pm Post subject: Re: Another oil leak to track down |
alman72 wrote: |
now I'm confused. It started on 3/4 side but the image is !/2 side with thermo
cable.
Time for UV dye for sure. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Oct 21, 2020 4:40 pm Post subject: Re: Another oil leak to track down |
I'd be shoving a bore scope or inspection camera in the tin through a spark plug hole to see how the top of that cylinder looks, cooling air blows things around in many strange ways. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Whaanga Samba Member
Joined: May 07, 2016 Posts: 627 Location: Rochester, NY
Posted: Wed Oct 21, 2020 6:53 pm Post subject: Re: Another oil leak to track down |
Thanks for all the comments. I have a small snake camera and will check out the top of the cylinders. And I thought I was only losing oil on the 3/4 side but the photo I posted is from the 1/2 side. Here’s what the 3/4 side looks like.
_________________ Late 1973 Bay w/a transplanted 914 Engine |
Posted: Wed Oct 21, 2020 7:41 pm Post subject: Re: Another oil leak to track down |
I got out my little WiFi camera and this is what I saw on top of the #2 jug:
And here’s what my engine looked like in 2017 when it was out of the bus:
You can see there is no oil on the top of the jugs. At this point of my bus ownership, I had driven about 500 miles. Since then, I’ve put about 5,000 miles. _________________ Late 1973 Bay w/a transplanted 914 Engine |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Wed Oct 21, 2020 8:05 pm Post subject: Re: Another oil leak to track down |
If it were me I would do a cylinder leak down test.
.There is quite a lot of oil leaking from #1 cylinder and running down past the
Oil control valve .
And if you don’t drive it in the winter pull it and do a reseal plus whatever
Else you may find.
Possibly resurface the heads and a valve job . _________________ V.W.owner since 1967 |
