66 steering column questions
Dan2973
Dan2973 is offline
PostPosted: Sun Aug 25, 2019 4:25 pm    Post subject: 66 steering column questions Reply with quote
Hey guys. Iím in the process of restoring my 1966 standard. I disconnected the steering shaft rag joint and took off the horn center cap and ring. I left the wheel attached to the shaft. Than I started to pull the wheel and shaft from the tube and got it out but ball bearings fell all over the place. Now Iím trying to figure out what I need. Can anyone tell me exactly what I need here. I see so manny different pieces online and not sure what I need now. Thanks guys
mukluk
mukluk is offline
PostPosted: Sun Aug 25, 2019 5:06 pm    Post subject: Re: 66 steering column questions Reply with quote
You appear to have pulled the upper steering column bearing apart, the inner race is the metal collar stuck on the end of the column shaft. The remainder of the bearing (sans ball bearings) will still be found in the column tube. A replacement should be part number 113415585A.
Ceckert64
Ceckert64 is offline
PostPosted: Tue Aug 27, 2019 7:46 am    Post subject: Re: 66 steering column questions Reply with quote
I think thereís a clip that hold the races together. If you find all of the balls and clean them and put new grease on them, you should be able to put it back together. I had this happen to me a few times.
My Website: AidensVW.com
1964 Factory sunroof Beetle
1965 Factory sunroof parts beetle SOLD
Dan2973
Dan2973 is offline
PostPosted: Tue Aug 27, 2019 4:26 pm    Post subject: Re: 66 steering column questions Reply with quote
thankk you
vwoldbug
vwoldbug is offline
PostPosted: Tue Aug 27, 2019 5:53 pm    Post subject: Re: 66 steering column questions Reply with quote
Is that a nice 62 Chevy
glutamodo Premium Member
The Android
glutamodo is online now
PostPosted: Wed Aug 28, 2019 6:46 am    Post subject: Re: 66 steering column questions Reply with quote
Yes there is a clip ring.
Andy T.
-Volunteer Post-Production Sound Editor for Starship Excelsior - A Star Trek Fan Production.
Dan2973
Dan2973 is offline
PostPosted: Thu Aug 29, 2019 4:02 pm    Post subject: Re: 66 steering column questions Reply with quote
glutamodo wrote:
Thanks so much
