flabuggy Samba Member
Posted: Mon Aug 26, 2019 6:57 pm Post subject: Re: swing axle |
It's the same axle and tubes that came off the car. I'm feeling kind of lost here too. I feel like I had a stroke and nothing makes sense. Thanks for all the reply's everyone. Maybe tomorrow it will make sense |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Mon Aug 26, 2019 7:08 pm Post subject: Re: swing axle |
Yes sometimes just sleeping one night clarifies all of the issues and the next morning you think "how can I be so stupid". Well it does for me anyway.
Only thing is can you elaborate more on exactly what car you have. Is is a 67 and earlier with a '68 swing axle in it or something else. I just don't know how you have that transmission in your car.
In addition my understanding is that the true '68 swing axle was a "long" axle and was different than the previous models. Shouldn't make a difference if you are using your original axles.
But this is an interesting problem. I'm sure the solution is simple and someone will chime in. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Mon Aug 26, 2019 7:14 pm Post subject: Re: swing axle |
It might be a 67, It's a old dune buggy. The swing axle is original. It came without a title but for some reason I thought it was a 68 |
Posted: Mon Aug 26, 2019 8:30 pm Post subject: Re: swing axle |
Even though it is a buggy, it should still have the serial number on the chassis near the gearbox selector mechanism.
The first three numbers will give you the year number and may help narrow down your problem. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
theblake Samba Member
Joined: May 27, 2014 Posts: 30 Location: Honolulu, Hawaii
Posted: Wed Aug 28, 2019 1:41 am Post subject: Re: swing axle |
Here's my guess. Based on the picture above, the tubes need to be swapped. And of the three bolt holes (to bolt the swing arm to the tube), the top rear one currently in the picture is the one that needs to be positioned in the front of the three holes (but on the opposite side of the vehicle). |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Tue Sep 03, 2019 4:03 am Post subject: Re: swing axle |
Find the part number on the tubes - part numbers ending with an odd number is for the left side and part numbers ending with an even number is for the right side. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
