PaulMc Samba Member
Joined: August 02, 2014 Posts: 13 Location: Brookings, OR
Posted: Fri Jan 18, 2019 2:32 pm Post subject: 1961 bug - seat belt retrofit |
I have a 61 bug - I don't think it came with seat belts originally and I can't find any place where belts would be attached.
I want to install lap beats and need to know what is the best and cleanest way to do this.
I have the body off the chassis right now (welded in new pans) so I have full access.
Paul |
stale air Samba Member
Joined: August 23, 2007 Posts: 5728 Location: Senoia Ga, formerly NorCal
Posted: Fri Jan 18, 2019 3:03 pm Post subject: Re: 1961 bug - seat belt retrofit |
This thread may help....
http://www.thesamba.com/vw/forum/viewtopic.php?t=593960 _________________ WANTED: Henry Veale Santa Rosa plate frames
my59 Samba Member
Joined: August 13, 2003 Posts: 4009 Location: connecting the dots
Posted: Fri Jan 18, 2019 3:13 pm Post subject: Re: 1961 bug - seat belt retrofit |
The original owner had lap belts added in the front to my '59 beetle- think holes drilled in floor pans, and big fender washers and bolts. 60 year old bolts, washers, and belts. I'll have to look at receipts to see if the dealer did it.
When i registered the car here in CT the DMV guy was kind enough to skip marking the car as equipped with seat belts after I pointed out they were not stock, not original equipment, and legally not required in 1959 should I desire to restore the car. It has antique plates on it, and is no where near a daily driver.
Given the nature of the beast, I'd be looking to weld in plates big enough to not rip through the pans should the seat belts be loaded up. Of course, that means you have some engineering ahead of you. If you go that far, I'd look to add lap/shoulder belts, as lap belts in a bug will not prevent you from crushing the steering wheel with your chest or stopping your passenger from a skull blow into the windshield. Lets not talk about the passenger's lawsuit when their lawyer finds its not OG equipment...and the car was not equipped from day one. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Fri Jan 18, 2019 3:33 pm Post subject: Re: 1961 bug - seat belt retrofit |
Btw, my 58 had some lap belts installed at some point in its life also. When I restored the car, I went ahead and installed some original ones back in.
It wasnt the the best method of installing them back in the day, but its not like I use them anyway.
panicman Samba Member
Joined: December 18, 2011 Posts: 2673 Location: Canby, OR
Posted: Fri Jan 18, 2019 7:23 pm Post subject: Re: 1961 bug - seat belt retrofit |
That’s how I installed my outboard lap belt mounts. For the inboard, I welded to the chassis tube.
After welding in:
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3542 Location: Pennsylvania
Posted: Mon Sep 02, 2019 6:29 pm Post subject: Re: 1961 bug - seat belt retrofit |
Has anyone ever put a 3 point seatbelt in a 61 or early model Bug? I have a 61 to restore but everyone is afraid to ride in a car without a 3 point seatbelt. I even have 1 person who wants to know if I can install airbags in it.  |
Jos.Hall Samba Member
Joined: January 29, 2011 Posts: 348 Location: Sunny So Cal.
Posted: Mon Sep 02, 2019 8:22 pm Post subject: Re: 1961 bug - seat belt retrofit |
| Dwayne1m wrote: |
opt for different, less obtrusive passengers. It'll be much easier and cheaper. |
Posted: Mon Sep 02, 2019 9:39 pm Post subject: Re: 1961 bug - seat belt retrofit |
| Dwayne1m wrote: |
Yes. John Henry did it in his oval and did a great write up on his dedicated web page- you can find it quickly online. It’s a bit complicated to get what you would want, but it is possible.
Or... tell your squeamish friends to go joyride in a Yaris. |
