Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Mon Aug 26, 2019 9:15 pm Post subject: Help assess for insurance '64 32k miles all original |
Hi folks,
A contractor I hired just bought this 1964 beetle.
He didn't know if it had 32k, 132k or 232k miles.
First of all, I think it's 32,527 miles.
What do you folks think?
I didn't take a pic of the engine but it's all original.
He insured it for $15,000 value.
If it's really 32,000 miles, how much $$$ is a reasonable insurance value that he can stand behind? _________________
....KTMs, GasGas, SPOT mtb |
KTPhil Samba Member
Posted: Mon Aug 26, 2019 10:03 pm Post subject: Re: Help assess for insurance '64 32k miles all original |
If it's really 32K, there would be some telltale signs since certain parts would not have been replaced or even disturbed. Some common CSI:VW checks are:
- Check if brake lines and bolts appear to have been wrenched.
- Check for the security sealant on the speedo cable knurled nut at the back of the speedo.
- Check for security sealant on the steering box adjustment.
- Check the spare tire date code.
- Check the model and any codes on the headlight sealed beams.
- Check if any of the wiring appears to have been pulled from the fusebox.
- Check everywhere (underneath, under mats and trunk liner) for rust and paint spray.
- Check the door jambs for any oil change stickers with dates.
- How pitted is the windshield?
daven Samba Member
Joined: January 13, 2009 Posts: 351 Location: Dayton OH
Posted: Tue Aug 27, 2019 3:13 am Post subject: Re: Help assess for insurance '64 32k miles all original |
I also look at the amount of wear on the pedals - yours looks low miles.
Dave |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Tue Aug 27, 2019 5:19 am Post subject: Re: Help assess for insurance '64 32k miles all original |
Based on carpet wear, I'd say the odometer has rolled over once. Obviously the car has been gently used. |
Sodo Samba Member
Posted: Tue Aug 27, 2019 5:47 am Post subject: Re: Help assess for insurance '64 32k miles all original |
Good tips.
100% original paint.
How wouldI find an "insurance value" ?
He needs to know if $15,000 is defensible, or can it stand higher? _________________
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Tue Aug 27, 2019 5:49 am Post subject: Re: Help assess for insurance '64 32k miles all original |
daven wrote: |
Dave |
Those pedal covers look more like 132,000.
And the wear & tear on the PASENGER side tells that there was more than 32,000 on the car. (It also looks like the braked with their left foot.) I mean really, what percentage of the time do you have a passenger in your car? Even at 132,000 miles, the passenger obviously had trouble getting their clodstompers in & out of the car. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Sodo Samba Member
Posted: Tue Aug 27, 2019 7:17 am Post subject: Re: Help assess for insurance '64 32k miles all original |
Good point about passenger side.
Little old lady stepping in and out wouldn't beat it up the drivers side footwell.
Perhaps wouldn't rack up the miles either.
And maybe NEVER opened the wing windows, for example. They look showroom new, as do the door handles & window cranks.
I'll look at some of the other indicators.
Does the steering wheel wear visibly?
I can't really pop the brake hubs off.
But KTPhil's list gave me lots of ideas how to suss it out, and I'd like to hear more.
Ignition key could offer some clues.
I'm sure envious.
He paid $8,000 2 months ago.
And thats only if he drives it again.
Contractor driving a beetle means he ain't working that day, so seeing the beetle again will lengthen my construction project.
But I'm sure he'd drive it again at the slightest mention. _________________
74 Thing Samba Member
Posted: Tue Aug 27, 2019 7:38 am Post subject: Re: Help assess for insurance '64 32k miles all original |
What kind of insurance policy are you getting and who is the insurer (stated will cap you)? Stated vs Agreed (from Hagerty website):
An Agreed Value policy -- the same as Hagerty’s Guaranteed Value™ policy --guarantees that you will receive the full insured amount of the vehicle (with no depreciation, and including all sales taxes), in the event of a covered total loss.
In contrast, a Stated Value policy (sometimes called “stated amount” or “maximum limit of liability”) does not promise to pay the full vehicle value that’s indicated or “stated” on the policy. With regard to a covered total loss, you may receive less than that stated amount, because the insurer has the right to pay either your vehicle’s depreciated actual cash value OR the cost to replace your vehicle -- whichever is less. Also, many insurers that offer stated value policies (typically standard insurers) require periodic appraisals to affirm the insured amount, adding cost and inconvenience to the client. |
KTPhil Samba Member
Posted: Tue Aug 27, 2019 9:00 am Post subject: Re: Help assess for insurance '64 32k miles all original |
TDCTDI wrote: |
(It also looks like the braked with their left foot.) |
When I was a starving student I used to swap the brake and clutch pedal covers when the corners started to wear, instead of replacing them. Made them look like these.
I would have rotated them (logo upside down) to get even more miles but by then the rubber usually degraded enough to crack on the backside, making them fall off!
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Tue Aug 27, 2019 9:37 am Post subject: Re: Help assess for insurance '64 32k miles all original |
It looks like the outside has had a repaint. The wheels have for sure. But I think your insured value of $15,000 is fine. It`s higher then the actual value, which is good. _________________ If you`re going to do something, do it right. |
Posted: Tue Aug 27, 2019 2:22 pm Post subject: Re: Help assess for insurance '64 32k miles all original |
Sodo wrote: |
Good tips.
He needs to know if $15,000 is defensible, or can it stand higher? |
Hagerty has no problem insuring my '66 (with 131,351 Little-Old-Lady-driven miles) for $15,000. |
cbeck Samba Member
Posted: Tue Aug 27, 2019 3:19 pm Post subject: Re: Help assess for insurance '64 32k miles all original |
Appraisal by somebody that is licensed and bonded thru the nationally recognized organization that appraisers belong to. Only way to know where you stand. Donald osbourn from jay lenos garage comes to mind. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
bluebus86 Banned
Posted: Tue Aug 27, 2019 4:09 pm Post subject: Re: Help assess for insurance '64 32k miles all original |
daven wrote: |
Dave |
My 66 Bug with 75000 miles, bought from original owner, had pedal pad wear thru the rubber to the metal, the pedals shown here have considerably less wear than mine. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Tue Aug 27, 2019 6:08 pm Post subject: Re: Help assess for insurance '64 32k miles all original |
Bryan67 wrote: |
It looks like the outside has had a repaint. The wheels have for sure. But I think your insured value of $15,000 is fine. It`s higher then the actual value, which is good. |
I'd say 132,000 and pampered. very nice car.
Sodo Samba Member
Posted: Tue Aug 27, 2019 9:05 pm Post subject: Re: Help assess for insurance '64 32k miles all original |
I’ll ask him to bring it again and I’ll post pics of what I find.
Ill look at the wheels; it should be apparent if they’ve been repainted. So is the white/blue per “OEM”?
I feel like the value of 32k vs 132k miles could be substantial and is worth determining. And should become telltale, if I find more than a couple other corroborating details. If it gets serious (32) the owner can decide if he wants a professional appraisal.
Does anyone “know” or have a good way to estimate the difference in value betw 32k & 132k miles?
This is fun, what an awesome find. He bought it from his brother. Im curious if he knows where it came from. _________________
KTPhil Samba Member
Posted: Tue Aug 27, 2019 9:34 pm Post subject: Re: Help assess for insurance '64 32k miles all original |
It's in really good shape. But I would not expect a great difference in price between the two mileage estimates.
32K is not low enough to be "factory fresh," and 132K is not worn out if it has had normal maintenance, which based on excellent condition, has been the case. The engine might need a refresh, but that costs $2K or so.
Maybe a bump from $15K to $17K is reasonable.
I think by '64 the wheels were "black and white" and not color-coded to the body color. Someone with Garwood's later book could confirm. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Tue Aug 27, 2019 9:55 pm Post subject: Re: Help assess for insurance '64 32k miles all original |
I'm only working with the pictures you provide- and here goes:
The bumper brackets should be silver.
There's too much wear on the carpet on both sides- drivers on the heater tube and passenger's threshold.
Repainted wheels makes me suspect more than just those and the bumper brackets have been painted.
I've seen a fuel gauge bezel look so unrefined. Looks third world. There's no reason either gauge should require replacement if such low miles.
We need better pics. A door jamb, engine, under hood, etc. to make accurate guess at authenticity. _________________
EverettB wrote: |
FU#5 |
Sodo Samba Member
Posted: Tue Aug 27, 2019 11:24 pm Post subject: Re: Help assess for insurance '64 32k miles all original |
If the engine has never been out that might indicate 32k miles.
As one feller said
Quote: |
I wonder what the nuts looks like. |
Engine serial has no letter preceding the number, so thats a 1200 right?
It sure runs strong.
Will the heater boxes show if if they've ever scooted around on a cement floor?
I'll see what kind of action the exhaust bolts have had. _________________
gt1953 Samba Member
Posted: Wed Aug 28, 2019 6:46 am Post subject: Re: Help assess for insurance '64 32k miles all original |
The pedal pads have been flipped around. Obvious. If the engine has never been out it should have the wavy washers under the nuts. Lots of time they never make it back on. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
mukluk Samba Member
Posted: Wed Aug 28, 2019 7:08 am Post subject: Re: Help assess for insurance '64 32k miles all original |
Regarding the question as to the wheel repaint, a Bahama Blue 1964 model's wheels would have been black discs with blue-white rims.
_________________ 1960 Ragtop w/Semaphores "Inga" |
