tomsbuggered Samba Member
Joined: October 16, 2014 Posts: 417 Location: Calgary, AB Canada
Posted: Tue Aug 27, 2019 8:59 pm Post subject: TP's 56 Oval Project |
Well I brought the Beetle Oval home yesterday. Started teardown on fender removal, light sand on surface rust today. Hope to have body separated from the chassis in a couple days.
_________________ June 1956 VW Oval Beetle |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Tue Aug 27, 2019 9:03 pm Post subject: Re: TP's 56 Oval Project |
Pictures, more pictures! Please.
You are going to have some fun! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Tue Aug 27, 2019 9:06 pm Post subject: Re: TP's 56 Oval Project |
VW_Jimbo wrote: |
You are going to have some fun! |
Yes it is going to be fun, just need to get it apart to see what I don't see. Going to be travelling this winter, so won't get much done after that, until Spring. _________________ June 1956 VW Oval Beetle |
Posted: Tue Sep 10, 2019 8:12 pm Post subject: Re: TP's 56 Oval Project |
Oval is stored , won't get any more work done until January. I attempted hand forming patch panels for the left rear fender but not up to par. I will be looking for donor fenders, or if that fails using aftermarket ones.
Oh, if only I had deep pockets and could afford the right metal working tools.
Looking forward to getting to it in the New Year. _________________ June 1956 VW Oval Beetle |
Posted: Sat Jan 25, 2020 9:19 pm Post subject: Re: TP's 56 Oval Project |
Finally found the time to get back at the Oval project.
Today I built a dolly to store the body section on. I used wood as metal proved to be too expensive.
I hope to have the body off chassis tomorrow if all goes well.
I also started removing rusted areas in the left and right rear wheelwells.
Replacement panels will be ordered tomorrow.
And so it begins. _________________ June 1956 VW Oval Beetle |
Volksvr6gti Samba Member
Joined: July 22, 2019 Posts: 298 Location: Jacksonville
Posted: Sat Jan 25, 2020 10:13 pm Post subject: Re: TP's 56 Oval Project |
How was the front fenders? They happen to be bullet fenders? |
Posted: Sat Jan 25, 2020 10:15 pm Post subject: Re: TP's 56 Oval Project |
Volksvr6gti wrote: |
They are bullet style in pretty good shape, certainly workable.
Posted: Sun Jan 26, 2020 8:31 pm Post subject: Re: TP's 56 Oval Project |
Spent today removing all attachments from body to chassis , Ready to separate them this week. Jacked. _________________ June 1956 VW Oval Beetle |
Posted: Mon Jan 27, 2020 10:10 pm Post subject: The Beetle has landed ! |
Well the body is off the chassis and sitting on the dolly.
Now for a good assessment, and start on the body work. _________________ June 1956 VW Oval Beetle |
Posted: Mon Jan 27, 2020 10:13 pm Post subject: Re: TP's 56 Oval Project |
Pictures or it did not happen! _________________ Jimbo
TDCTDI wrote: |
Posted: Mon Jan 27, 2020 10:50 pm Post subject: Re: TP's 56 Oval Project |
VW_Jimbo wrote: |
Pictures or it did not happen! |
Ha, ha pictues to follow, too busy putting tools away and cleaning shop area.
I need to reinforce my dolly with a couple gussets, then off the lift she comes.
So here is the dolly, at 30" to bottom of body.
Last edited by tomsbuggered on Tue Jan 28, 2020 9:24 pm; edited 2 times in total |
Posted: Tue Jan 28, 2020 9:15 am Post subject: Re: TP's 56 Oval Project |
tomsbuggered wrote: |
VW_Jimbo wrote: |
I need to reinforce my dolly with a couple gussets, then off the lift she comes. |
That is always a “mixed feelings” moment for myself. 1.- Because your excited to see what needs to happen. 2.)Getting to see all the damages and understand what the road ahead looks like, can be overwhelming!
Good luck!
Remember - we all like pictures! _________________ Jimbo
TDCTDI wrote: |
Posted: Tue Jan 28, 2020 9:31 pm Post subject: Re: TP's 56 Oval Project |
Had a chance to clean up areas to see how bad the rust is. Surprised that for a 64 year old car it is pretty clean. It looks to me that the pan may have been replaced once, the welds don't look factory.
Need to brace body and then start heater channel removal. The door hinge bolts do not want to budge so will give it a couple more trys and then drill them out. _________________ June 1956 VW Oval Beetle
Last edited by tomsbuggered on Fri Jan 31, 2020 9:16 pm; edited 2 times in total |
Posted: Tue Jan 28, 2020 10:18 pm Post subject: Re: TP's 56 Oval Project |
Both sides of that lower luggage shelf look pretty nasty. That panel, the side you see, has a rear panel (reinforcement panel) welded to it. If both are rotted (kinda looks like it may be) you will need to replace all 4 pieces. 2 panels make up the lower shelf and the two reinforcement panels.
I just went through installing the lower panel, in mine. Page 11. _________________ Jimbo
TDCTDI wrote: |
Posted: Wed Jan 29, 2020 10:01 am Post subject: Re: TP's 56 Oval Project |
VW_Jimbo wrote: |
I just went through installing the lower panel, in mine. Page 11. |
I looked through your build post and looks like I have some tricky fabrication ahead of me. Out with the old, in with new. _________________ June 1956 VW Oval Beetle |
Posted: Wed Jan 29, 2020 8:19 pm Post subject: Re: TP's 56 Oval Project |
VW_Jimbo wrote: |
I looked through your build post and looks like I have some tricky fabrication ahead of me. Out with the old, in with new. |
You got it! Fun, fun, fun!
Looking forward to reading your progress! _________________ Jimbo
TDCTDI wrote: |
Posted: Fri Jan 31, 2020 7:15 pm Post subject: Re: TP's 56 Oval Project |
Parts arrived today, great delivery time.
Back to bracing body , then cut and fill! _________________ June 1956 VW Oval Beetle |
Posted: Fri Jan 31, 2020 8:58 pm Post subject: Re: TP's 56 Oval Project |
Looking forward to reading about your process! _________________ Jimbo
TDCTDI wrote: |
Posted: Tue Feb 04, 2020 9:53 pm Post subject: Re: TP's 56 Oval Project |
Worked on the Oval a little today, after taking the weekend off. My body sheetmetal arrived on Friday so today I unpacked and inspected them. I knew the Dansk channels weren't exact for 1956 but they will do the job, I think.
I am still fighting with getting the door hinge bolts out, and may resort to drilling them out unless there is a divine intervention the next couple days.
Next will be to brace the door openings and side to side. The body is sitting perfectly level so measurements should be fairly true.
Drilled out a bunch of spot welds in anticipation of getting the doors off. With luck I will start fitting up the driver side heater channel this week. _________________ June 1956 VW Oval Beetle |
Posted: Wed Feb 05, 2020 9:38 pm Post subject: Re: TP's 56 Oval Project |
Doors removed today after drilling out 14 of the 16 bolts.
Tomorrow I will start bracing the body. I cut out a bit more rust in preparation to installing the heater channels. A little more progress.
Edit: Did a dry fit of the heater channels to pan and they seem to line up. so need to brace door openings and then lower body to pan for fitment. _________________ June 1956 VW Oval Beetle |
