tomsbuggered Samba Member
Joined: October 16, 2014 Posts: 417 Location: Calgary, AB Canada
Posted: Wed Jul 15, 2020 4:50 pm Post subject: Re: TP's 56 Oval Project |
tehillah1 wrote: |
Nice work on the repair fabrications! Thanks for documenting your process. |
Glad you are able to glean some information that you can you use on your own build. I am certainly no expert, but these forums are an excellent source for insight, from those that have gone before.
Good luck on your project!
Tom _________________ June 1956 VW Oval Beetle |
Posted: Fri Jul 17, 2020 8:31 pm Post subject: Re: inner door repair |
I finished repairing the driver door lower inner structure today. I wasn't able to fabricate the lower weatherstrip section, so I ordered a lower repair panel from CIP1. The part needed some tweaking to straighten it but it fit pretty well overall.
I need to hammer out some dings that were previously "fixed". There is quite a high spot and oil canning that need to be addressed before I weld on the lower outside door skin.
Posted: Sun Jul 26, 2020 6:20 pm Post subject: Re: TP's 56 Oval Project |
Had some forward progress this weekend working on the driver door skin repair and the engine decklid dent removal. All rust is gone, just need to shrink the door skin to remove the oil canning
Was able to get the deck lid fairly straight, without removing the inner reinforcement panel.
Posted: Tue Jul 28, 2020 7:20 pm Post subject: Re: TP's 56 Oval Project |
I sanded and primed the rear deck lid today.
Next will be boot lid. _________________ June 1956 VW Oval Beetle |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9950 Location: Huntington Beach, CA
Posted: Tue Jul 28, 2020 7:33 pm Post subject: Re: TP's 56 Oval Project |
Nice! It all adds up! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Tue Jul 28, 2020 7:52 pm Post subject: Re: TP's 56 Oval Project |
VW_Jimbo wrote: |
Nice! It all adds up! |
Yes Jimmy, baby steps but forward movement.
Posted: Sat Sep 05, 2020 8:08 pm Post subject: Rear apron repair |
Removed the rear apron yesterday, stripped paint, wire wheeled and tomorrow will start rust removal and dent repairs.
Once that is done will get it into primer. Toying with modifying it to be removable.
More progress today, welding completed
Posted: Tue Sep 08, 2020 8:21 pm Post subject: Re: TP's 56 Oval Project |
Got the rear apron in primer, as far as I will take it for now _________________ June 1956 VW Oval Beetle |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1770 Location: Winnipeg
Posted: Wed Sep 09, 2020 6:05 am Post subject: Re: TP's 56 Oval Project |
Those original aprons are so crisp. Really worth saving. Well done.
Don _________________ Better and better mistakes! |
Posted: Thu Sep 17, 2020 10:14 am Post subject: Re: TP's 56 Oval Project |
I'm not able to work on rust removal on the body at the moment so I am tackling restoration of some of the smaller bits.
Posted: Fri Sep 18, 2020 7:37 pm Post subject: Re: TP's 56 Oval Project |
Got the interior parts repaired, prepped and primed
Moving on to steering wheel repair. I got the wheel sanded and started with epoxy resin of cracks.
There are a lot of hairline cracks and some fairly major ones.
No worse than the last one I did though. _________________ June 1956 VW Oval Beetle
Last edited by tomsbuggered on Sat Sep 19, 2020 7:47 am; edited 2 times in total |
Volksvr6gti Samba Member
Joined: July 22, 2019 Posts: 298 Location: Jacksonville
Posted: Fri Sep 18, 2020 7:45 pm Post subject: Re: TP's 56 Oval Project |
Looking good what is your plan for all the hairline cracks. I started to work on my wheel, pretty much at your step currently. Next is to attack those hairline ones and seeing what product you think works best from your previous steering wheel. |
Posted: Fri Sep 18, 2020 7:57 pm Post subject: Re: TP's 56 Oval Project |
I used a thin epoxy glue(much like crazy glue) and let it run in the cracks. On the bigger cracks I am using JB weld epoxy for metal. I have used JB weld on two other steering wheel restorations with good results. Sometimes it helps to v notch the smaller cracks slightly. It is a fairly slow process with sanding but I hope to get it to primer stage early next week. _________________ June 1956 VW Oval Beetle |
Posted: Fri Sep 18, 2020 8:11 pm Post subject: Re: TP's 56 Oval Project |
Oh interesting on the smaller cracks. I was thinking of bondo possibly but maybe your idea will work better. I have all my big ones done and sanded |
Posted: Fri Sep 18, 2020 8:29 pm Post subject: Re: TP's 56 Oval Project |
JB Weld makes a putty form too but it is difficult to get into the smaller cracks. _________________ June 1956 VW Oval Beetle |
Posted: Sun Sep 20, 2020 9:07 pm Post subject: Re: TP's 56 Oval Project |
Today I sanded and applied another coat of epoxy to cracks in steering wheel. I will finish off any hairline deficiencies with glazing putty.
Posted: Tue Sep 22, 2020 5:03 pm Post subject: Re: TP's 56 Oval Project |
I filled, sanded, primed and put a seal coat on the steering wheel today. I will leave as is until i get a close paint match to the original turn signal housing.
I reworked the original front bumper, which for 64 years of a hard life, it turned out not too bad.
Posted: Tue Sep 22, 2020 8:07 pm Post subject: Re: TP's 56 Oval Project |
that steering wheel came out nice. you have me inspired to work on mine. when you have time do you mind taking pictures on the products you used to complete it. thanks again for you assistance |
Posted: Tue Sep 22, 2020 8:48 pm Post subject: Re: TP's 56 Oval Project |
Volksvr6gti wrote: |
Thanks, will take some pctures of products tomorrow.
Went through your build site tonight, very nice project and attention to detail. _________________ June 1956 VW Oval Beetle |
Posted: Wed Sep 23, 2020 8:02 am Post subject: Steering wheel repair |
These are the products I used to restore the steering wheel.
I searched the forum but didn't find info on the original paint colour for the interior trim.(Edit: possibly L472 Beige Gray)or L71 orL 278 ? I will try to get a paint match off the signal housing to use for the trim bits. I will deviate slightly with maybe using a black steering column.
Tomorrow I will start alignment of A pillars to heater channel.
I will need to start at square one and measure door openings up and check door gaps. I currently have narrower gaps at bottom of both doors. _________________ June 1956 VW Oval Beetle |
