daveswoodcraft Samba Member
Posted: Wed Aug 28, 2019 6:47 am Post subject: heating system diagram |
Looking for a complete diagram on heating system and components for a 1970 Bug. I read the heating tutorial and it is great information but I am trying to figure out what all parts I am missing in my bug. IE control wires not running to anything under rear seat etc. I am not sure if I will ever move back to NH again if I do I need heat even in September, the car will be stored before road salt season starts which last at least 4 months there.
Thanks for any help or direction you can give
Dave _________________ There are not such thing as a stupid question, but there are a lot of inquisitive idiots! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Wed Aug 28, 2019 8:08 am Post subject: Re: heating system diagram |
I just went to Google and typed in “1970 bug heat diagram”. Came back with a number of diagrams.
Might be one in there! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Wed Aug 28, 2019 8:12 am Post subject: Re: heating system diagram |
VW_Jimbo wrote: |
Might be one in there! |
Morning Jimbo
Thanks I did that, and there was a couple of flow charts nothing with specific parts, I am thinking (and that may be the problem) that the wire under the reat seat hooks to something to direct/divert the air between the back to front or even to allow the air to come out under the seat. All those pieces are missing and this being my first bug I am clueless what I should be looking for as far as parts.
Thanks again
Posted: Wed Aug 28, 2019 8:15 am Post subject: Re: heating system diagram |
That cable connects to a flap, if we are talking about the same one (pictures work great) to a flap at the panel below the rear seat rail.
I am off to work or I would find the picture for you. If no one gets to you, I will post one up tonight. _________________ Jimbo
TDCTDI wrote: |
Posted: Wed Aug 28, 2019 8:25 am Post subject: Re: heating system diagram |
VW_Jimbo wrote: |
I am off to work or I would find the picture for you. If no one gets to you, I will post one up tonight. |
Thank you Sir
much appreciated _________________ There are not such thing as a stupid question, but there are a lot of inquisitive idiots! |
windfish Samba Member
Posted: Wed Aug 28, 2019 8:32 am Post subject: Re: heating system diagram |
VW_Jimbo wrote: |
Did that for grins, this is mildly disappointing - https://www.jbugs.com/category/vw-heater-parts-boxes.html (scroll down a bit)
It's mostly well diagrammed.. but they've got the damn heater boxes backwards. The exhaust pipe is even pointing at the cabin.
This means that when they show the 'closed' diagram no air flows through the heat exchangers, which is incorrect.
Anyways.
daveswoodcraft wrote: |
I am thinking that the wire under the reat seat hooks to something to direct/divert the air between the back to front or even to allow the air to come out under the seat. All those pieces are missing and this being my first bug I am clueless what I should be looking for as far as parts. |
The part you're looking for is the Y that sits under the rear seat, it's typically covered with a bit of insulation.
Pic from the gallery -
It has a flap inside which is controlled by a wire hooked to one of the handles by the hand brake
Some air will always flow into the heater channels, but with that flap open a significant amount will exit under the rear seat.
The classifies here has some of the y's
Here's one ad - https://www.thesamba.com/vw/classifieds/detail.php?id=2288483
Be sure to request one with a working flap, many have broken or gone missing.
I completely rebuilt the heat system on my '70 and it works well enough.
Do you know if your heat exchangers are aftermarket or factory?
It makes a fairly big difference
AlmostHeavenWV_VW Samba Member
Posted: Wed Aug 28, 2019 8:46 am Post subject: Re: heating system diagram |
AlmostHeavenWV_VW wrote: |
Found these on Jbugs which illustrate the heater channels and the heater lever functions pretty well:
...yes, that one right there. Backwards heat exchangers.
It's irking because it's so close, but makes you question if the author really understood what they were doing.
Where, exactly, did they think that bottom tube was going?
For the record, the cable to the heat exhcangers opens a bypass vent that dumps the hot air under the car.
If air were not flowing through the heat exchangers they would get very, very hot. Right below the heads.
edit - I've emailed them. They're otherwise nice diagrams. |
Posted: Wed Aug 28, 2019 9:12 am Post subject: Re: heating system diagram |
windfish,
I never noticed those heat exchangers were backward. I can fix that for us on the samba. hopefully jbugs will too.
ill get Everett to remove the others from my gallery. _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Posted: Wed Aug 28, 2019 9:53 am Post subject: Re: heating system diagram |
Thank you Everyone
I will have time tomorrow to go through all the pictures and see what I am missing.
You folks ROCK _________________ There are not such thing as a stupid question, but there are a lot of inquisitive idiots! |
Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Wed Aug 28, 2019 9:59 am Post subject: Re: heating system diagram |
windfish,
ill get Everett to remove the others from my gallery. |
After you edit these, would you mind adding them the the Cooling Tutorial? Those are nice diagrams! _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Wed Aug 28, 2019 7:56 pm Post subject: Re: heating system diagram |
Those diagrams are OK, but aside from the backwards heat exchangers it would have been nice if they accurately depicted what happens to the air when the heat is turned off.
Whether the heat is turned on or not, air is always flowing through the heat exchangers and being heated, so in that sense the heat is always "on."
The lever in the car just controls a valve at each heat exchanger. When the lever is down, the valve dumps the heated air out under the car with the rest of the waste heat.
When the lever is up, the valve directs the heated air into the cabin. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Thu Aug 29, 2019 4:04 am Post subject: Re: heating system diagram |
Okay done.
I'll PM Everett to delete the others from my gallery. _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Posted: Thu Aug 29, 2019 8:30 am Post subject: Re: heating system diagram |
Nice!! _________________ 1965 Volkswagen 1500 Variant S
