Vanagon Nut Samba Member
Posted: Fri Aug 30, 2019 4:47 pm Post subject: Serp Belt and Idler. Abnormal Wear? Debris Hit? PICS |
Hi folks.
For an inline 4 VW gas engine in a Vanagon.
I don't see anything interfering with the idler. Belt has ~ 7000 miles. Saw flaw at belt first then mark on the idler.
When plastic idlers start to wear, does the plastic start to "frag" out?
I'd guess the bearings would wear out first though.
My guess is something hit the belt and idler but if the idler plastic is failing due to age....
Thanks
Neil.
serp belt wear
mark on idler. I don't see any other marks.... yet
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
82westyrabbit Samba Member
Posted: Fri Aug 30, 2019 6:45 pm Post subject: Re: Serp Belt and Idler. Abnormal Wear? Debris Hit? PICS |
Hi Niel. I agree that is probably mechanical damage. My van only has a few thousand miles on it since I finished it and my belt looks like brand new and the belts on my truck have only been changed once in 180000 thousand miles. John |
Posted: Fri Aug 30, 2019 8:00 pm Post subject: Re: Serp Belt and Idler. Abnormal Wear? Debris Hit? PICS |
Hey John.
Thanks for that.
The roller has belt wear; it has a "raised" lip at edge where mark is and that edge shows a slight amount of odd looking wear. It almost looks a little frail, for lack of better term. Anyhow.....
The bearings are a little noisy too so I replaced that roller with a good used one.
VE7TBN |
Posted: Sat Aug 31, 2019 5:30 am Post subject: Re: Serp Belt and Idler. Abnormal Wear? Debris Hit? PICS |
I installed a new roller when I finished up my engine installation because of a noisy bearing as well. I think you drive on worse roads than I do and just picked up a rock or something. I did drive through a few fields to camp at music festivals (the vans primary purpose). John |
Posted: Sun Sep 01, 2019 7:48 pm Post subject: Re: Serp Belt and Idler. Abnormal Wear? Debris Hit? PICS |
82westyrabbit wrote: |
ya not that you were saying this, of course, but I should've kept a better QC going on that project. So many details. I mean, you'd think I would've installed a new roller on a rebuilt engine.
I do drive a fair amount of dirt roads. Comes at a price. Reminds me I really should install get back to figuring out a a protective plate for the aluminum oil pan.
VE7TBN |
Posted: Mon Sep 02, 2019 3:41 pm Post subject: Re: Serp Belt and Idler. Abnormal Wear? Debris Hit? PICS |
Hi Neil. Some sort of skid plate has been on my list but I doubt I will get that far. It’s always good to see someone use a project after they finish it if there is such a thing as finished. John |
