Charlie57 Samba Member
Joined: July 29, 2012 Posts: 140 Location: Lebanon, TN
Posted: Mon Sep 02, 2019 9:50 am Post subject: Couple of Tin and Heating Questions |
I have been making some progress on my Bus engine. I am really getting closer to trying to get the engine and transmission back in. I have some questions I'll ask with the photos
First, it's a 1978 Bus. It appears the tin is from different years, I had a few issues ordering what I have so far but I think I.m in the home stretch. For any of the parts I need, if anyone knows a supplier please let me know.
Thanks for any help,
Charlie
What would I call the heat tube that comes off the exchanger? I need to buy one.
Otherside, same question. Also, what is the round hole for right beside the oval?
Long story, I bought the wrong tin, it was too short, finally got a piece that fit, however, the new piece on top does not have the cutout opening. The tin on the engine does have the opening and I have those pieces. What is the purpose and should I cut a hole in the new piece or plug the holel in the large piece?
Posted: Mon Sep 02, 2019 10:20 am Post subject: Re: Couple of Tin and Heating Questions |
I would call the two missing pieces for the heat booster fan "risers", "ducts" or "pipes" don't know what VW may have called them. Do you have the fan? If you don't have the fan, then just closing off the holes in the heat exchangers and tin is the way to go.
The extra hole on the left side is for the '75 air preheat, it can be closed off permanently.
You last drawing shows the intake air preheat for a stock carbureted engine. You probably will not need this without the OEM air cleaner. |
