Speedometer tab bolts
Karzapart55
Karzapart55 is offline
PostPosted: Tue Sep 03, 2019 4:03 am    Post subject: Speedometer tab bolts Reply with quote
Anyone know where you can get some slide in tab bolts for my buggy?
Central Jersey Volkswagen Socity
Dale M.
Dale M. is offline
PostPosted: Tue Sep 03, 2019 6:06 am    Post subject: Re: Speedometer tab bolts Reply with quote
Not sure what you are asking for...
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Karzapart55
PostPosted: Tue Sep 03, 2019 11:16 am    Post subject: Re: Speedometer tab bolts Reply with quote
I have a 71 Meyers body. Ther is une slide in retainer bolt to install an early Dub speedo. I need two
BL3Manx
BL3Manx is offline
PostPosted: Tue Sep 03, 2019 8:49 pm    Post subject: Re: Speedometer tab bolts Reply with quote
I've owned a few Meyers Manxes with ABS, fiberglass and metal dash panels.
They all used plain nuts and bolts to hold the VW speedometer.
If you prefer some type of nutplate, McMaster Carr has a bunch
https://www.mcmaster.com/nut-plates
vanderjw
vanderjw is offline
PostPosted: Thu Sep 05, 2019 11:02 am    Post subject: Re: Speedometer tab bolts Reply with quote
I cut the tabs off. I put an oring on the back of the speedo to keep it from rotating and scratching the dash. Then secured it with a big hose clamp on the back side.
BL3Manx
BL3Manx is offline
PostPosted: Thu Sep 05, 2019 12:19 pm    Post subject: Re: Speedometer tab bolts Reply with quote
Clever!
Free_Buggy
Free_Buggy is offline
PostPosted: Wed Sep 18, 2019 7:35 pm    Post subject: Re: Speedometer tab bolts Reply with quote
Similar topic that I replied to.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...free_buggy
Hugh
Genuine Manx Clone
