samcocker Samba Member
Posted: Wed Sep 04, 2019 1:13 am Post subject: Barndoor popout frame |
Can anyone help with the difference between the frames on barndoors and later splits ?
Thanks very much |
Scotty Samba Member
Joined: July 02, 2003 Posts: 1525 Location: Northampton - Uk
Posted: Wed Sep 04, 2019 5:12 am Post subject: Re: Barndoor popout frame |
The very early frames are solid without a rubber on them. They have catches like pre 53 quarter lights
The next style the frame is the same as later split bus, but has a different tab for the catch
When the catches changed to late split style the tab changed too
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
Posted: Wed Sep 04, 2019 8:21 am Post subject: Re: Barndoor popout frame |
Cheers scotty, could you send a close up of the late barndoor tab please ?
Thanks |
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
EmpiGT Samba Member
Posted: Wed Sep 04, 2019 12:53 pm Post subject: Re: Barndoor popout frame |
EverettB wrote: |
More information:
The "late" style started in early 1954 but I don't see the change listed in Progressive Refinements so I'm not sure of the exact chassis # or date. |
So the deep skylight deluxe above displaying a late barndoor pop out is incorrect? I had thought the late barndoor frame started earlier than piano hinge vent wing busses ended. Guess not? Learned something new. |
Posted: Wed Sep 04, 2019 1:02 pm Post subject: Re: Barndoor popout frame |
EverettB wrote: |
More information:
My barndoor is Jan 54 so guessing I will just go late type.
Thanks for your help |
Posted: Wed Sep 04, 2019 5:22 pm Post subject: Re: Barndoor popout frame |
EmpiGT wrote: |
EverettB wrote: |
More information:
No, it's correct.
To be clear:
By late style I mean this style, this is sometime in 1954-up:
_________________ How to Post Photos
samcocker wrote: |
EverettB wrote: |
More information:
Unless I am remembering wrong, this Bus is from 1/54:
Edit: It's VIN # 20-073180, which is very early 2/54
and it still has this style of popout:
Clara Samba Member
Posted: Fri Sep 06, 2019 2:37 pm Post subject: Re: Barndoor popout frame |
EverettB wrote: |
More information:
In the Parts List I found the VIN for the latch change:
221 847 081 - up to ch # 20-76-673
221 847 081 A - from ch # 20-76 673 |
23 window mike Samba Member
Joined: April 29, 2007 Posts: 32 Location: Stoke-on-Trent
Posted: Sun Oct 13, 2019 6:41 am Post subject: Re: Barndoor popout frame |
Has any one got a photo of a 1954 pop out catch |
Posted: Mon Oct 14, 2019 5:19 am Post subject: Re: Barndoor popout frame |
Are these barndoor
Clara Samba Member
Posted: Mon Oct 14, 2019 9:21 am Post subject: Re: Barndoor popout frame |
23 window mike wrote: |
Are these barndoor
They look like they will fit a later pop out frame, don't they?
The black knobs on the BD are a different shape, as well. |
EmpiGT Samba Member
Posted: Mon Oct 14, 2019 11:52 am Post subject: Re: Barndoor popout frame |
Those look like Brazilian bus latches. |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Mon Oct 14, 2019 12:20 pm Post subject: Re: Barndoor popout frame |
They look like Fleetline latches to me, those used in at least South Africa. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Posted: Mon Oct 14, 2019 10:28 pm Post subject: Re: Barndoor popout frame |
Ok thanks I have seen some advertised on here as barndoor |
Scotty Samba Member
Posted: Wed Oct 16, 2019 5:45 am Post subject: Re: Barndoor popout frame |
I have seen quite a few items listed as barndoor that definitely aren't. You have to be careful and make sure you know what you're buying _________________
EverettB wrote: |
Posted: Wed Oct 16, 2019 7:28 am Post subject: Re: Barndoor popout frame |
Yes I know thanks for that Scotty |
