Longmont1302 Samba Member
Joined: October 01, 2015 Posts: 324 Location: Longmont, CO
Posted: Wed Sep 04, 2019 9:02 pm Post subject: Glove box won't stay shut |
The glovebox on our '71 Super won't stay shut. I assumed the latch was the culprit:...but on closer inspection the steel it latches to may be the problem.
My guess is that te best way to fix this would be to remove the plastic, grind the area down, and weld a little more steel on there.
Can anyone suggest a simpler solution? |
windfish Samba Member
Posted: Wed Sep 04, 2019 9:39 pm Post subject: Re: Glove box won't stay shut |
Yep, that'd do it.
Guy earlier this year had the same problem - https://www.thesamba.com/vw/forum/viewtopic.php?t=713828
He used a pop-rivet and a small scrap of metal to patch it.
Alternatively, the latch on my '70 is busted so I'm using a neodymium bar magnet behind the dash, works fine. |
grandpa red Samba Member
Joined: November 23, 2018 Posts: 520 Location: Hollister,Ca.
Posted: Thu Sep 05, 2019 6:34 am Post subject: Re: Glove box won't stay shut |
The plastic latch also looks worn. _________________ '72 Beetle |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
Posted: Sun Sep 08, 2019 4:44 pm Post subject: Re: Glove box won't stay shut |
windfish wrote: |
Guy earlier this year had the same problem... |
Thanks for the link -- I did not find this in my searches.
grandpa red wrote: |
The plastic latch also looks worn. |
Thanks for this suggestion, too. I've flattened the remaining steel out a little more, and adding a fresh latch to the equation could make the difference.
Globespotter wrote: |
I'm pretty sure there is a metal clip on mine at that point not just the metal of the glove box. |
If anyone has a photo of this metal clip, I'd be very interested to see it. Thanks to all. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sun Sep 08, 2019 7:00 pm Post subject: Re: Glove box won't stay shut |
From the gallery - not sure if correct year, but it looks right
_________________ D-Dubya Manx clone - 63 Short pan,1914.
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Sun Sep 08, 2019 7:20 pm Post subject: Re: Glove box won't stay shut |
Did you try loosening the hinge screws on the door and adjusting it up a little? Mine was always popping open and when I removed the dash pad I adjusted the door and now it stays. |
Posted: Tue Sep 10, 2019 4:08 pm Post subject: Re: Glove box won't stay shut |
andk5591 wrote: |
From the gallery - not sure if correct year, but it looks right |
Thanks for the image. My vision isn't 100%, but that looks like it's just dash steel and not a clip to me.
Vanillagurilla wrote: |
I did not, and that's a great idea. Thanks! |
Posted: Wed Sep 11, 2019 5:35 am Post subject: Re: Glove box won't stay shut |
It is just the dash. Just a tab stamped into it. Depends how pretty you want, but a patch pop riveted in would do the trick. You can put it in and if too tight, just bend it a little. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Wed Sep 11, 2019 2:31 pm Post subject: Re: Glove box won't stay shut |
andk5591 wrote: |
It is just the dash. Just a tab stamped into it. Depends how pretty you want, but a patch pop riveted in would do the trick. You can put it in and if too tight, just bend it a little. |
Thanks, Andy. |
