Vancer Samba Member
Joined: April 01, 2019 Posts: 4 Location: Memphis, Tennessee
Posted: Thu Sep 05, 2019 6:00 pm Post subject: How to Install Fuel Tank Nipple? |
69 VW Squareback, originally Fuel Injected but converted to carbs. Fuel tank is original. I sealed return line opening.
I purchased an EMPI Fuel Tank Nipple kit. It came with the fuel tube with circular plate which has a flange on the curved end, a filter, a fiber washer, and a 22 mm nut.
I have done this before. Filter inserted in tank opening until crush washer makes contact. Then, fiber washer over straight portion of fuel tube, resting on circular plate, then nut over bent end of tube. Put fuel resistant Teflon tape over threads and tightened nut. It leaked from 22 mm nut.
Logic tells me the fiber washer should go over the flanged end of fuel tube. This would seal between the nut and lower side of circular plate. However, opening of fiber washer does not allow for it to fit over flange.
Anyone with experience with this?
Thanks,
Vancer
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Fri Sep 06, 2019 8:29 am Post subject: Re: How to Install Fuel Tank Nipple? |
It goes: sock, bent tube with flange, washer, nut. |
Vancer Samba Member
Posted: Fri Sep 06, 2019 6:27 pm Post subject: Re: How to Install Fuel Tank Nipple? |
Thank you for your response. Please see photos above. Washer will not fit over flange. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22412 Location: Kimball, Mi
Posted: Sat Sep 07, 2019 8:41 am Post subject: Re: How to Install Fuel Tank Nipple? |
Vancer wrote: |
Keep in mind that most of the sock kits are set up for carbed cars using 1/4 inch hose. Since your car was original FI, it uses a 5/16ths set up. This is why the washer doesn't fit. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Vancer Samba Member
Posted: Sat Sep 07, 2019 2:16 pm Post subject: Re: How to Install Fuel Tank Nipple? |
This kit should fit itself. Also, as an aside, I have had 2 64 Notchbacks myself. Wish I still had at least one (wife wanted it gone). |
tonyvitello Samba Member
Joined: August 24, 2019 Posts: 12 Location: New Jersey
Posted: Tue Aug 18, 2020 6:14 pm Post subject: Re: How to Install Fuel Tank Nipple? |
Just bought a fuel tank for 76 bus. Have the same issue with the flanged side and washer. Was there ever an answer in this thread ? Thanks |
bmas2144 Samba Member
Joined: July 28, 2018 Posts: 20 Location: North Carolina
Posted: Sat Jun 12, 2021 5:19 pm Post subject: Re: How to Install Fuel Tank Nipple? |
Same issue! What did you guys end up doing? |
seattle_jerry Samba Member
Posted: Sat Aug 26, 2023 2:42 pm Post subject: Re: How to Install Fuel Tank Nipple? |
I just had the same issue. From as near as I can tell, the hole in the nut is out of tolerance, or the flare is too big.
I very slightly drilled the nut hole so the flare would fit through the hole.
The hole I drilled is still smaller than the internal diameter of the sealing washer.
Looking at my original nut, it's hole was a lot larger. |
