What to do with these side foot-rails?
epowell
epowell is offline
PostPosted: Fri Sep 06, 2019 8:19 am    Post subject: What to do with these side foot-rails? Reply with quote
They look OK but they are disturbing the metal... what to do?
I guess I MUST remove them now and fix the rust... but is it worth to put them back on??
www.edwardpowell.com
MarkWard
MarkWard is offline
PostPosted: Fri Sep 06, 2019 8:29 am    Post subject: Re: What to do with these SIDE FOOT-RAILS? Reply with quote
Putting them back on would be up to you. The passenger side one might make the step up easier at the sliding door. Otherwise I don't see the purpose. Running boards seem to be an invitation for someone to "jump" on them for a quick ride somewhere. It's really up to you.
1982 Vanagon Camper with ALH TDI.
1990 Vanagon Camper Syncro.
In Car https://youtu.be/5hbfdUJR88Q
Squidfish
Squidfish is offline
PostPosted: Fri Sep 06, 2019 9:17 am    Post subject: Re: What to do with these SIDE FOOT-RAILS? Reply with quote
I wouldn't personally.
1985.5 - Vanagon Westfalia Wolfsburg Weekender - BBM LH8U - "Penny"
- 2.6i 5-Cylinder 10v (Overland via 2004) with all the goodies - John
epowell
epowell is offline
PostPosted: Fri Sep 06, 2019 10:10 am    Post subject: Re: What to do with these SIDE FOOT-RAILS? Reply with quote
...now f I can only get the buggers off Shocked
epowell
epowell is offline
PostPosted: Fri Sep 06, 2019 11:56 am    Post subject: Re: What to do with these side foot-rails? Reply with quote
seems naked without them....
if anyone in vancouver wants to pick them up - they can have them or free...
jlrftype7
jlrftype7 is offline
PostPosted: Fri Sep 06, 2019 12:06 pm    Post subject: Re: What to do with these side foot-rails? Reply with quote
Naked, nah, you've just set your Vanagon Free, that's all.... Wink Wink
'67 Type 3 Fastback, my 2nd car- also long gone
'69 Semi-Auto Stick Shift Beetle, my wife's first car= yep. still long gone....
‘84 Tin Top - Hilga....Auto
epowell
epowell is offline
PostPosted: Fri Sep 06, 2019 12:20 pm    Post subject: Re: What to do with these side foot-rails? Reply with quote
Laughing
Jeffrey Lee
Jeffrey Lee is offline
PostPosted: Fri Sep 06, 2019 12:41 pm    Post subject: Re: What to do with these side foot-rails? Reply with quote
Definitely keep them, and also add a tinted bubble-window, orange shag carpet interior, and an airbrushed mural.
Or, if you insist on removing them, you'll have room for some really groovy chrome side pipes ...
Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com
SyncroHead
SyncroHead is offline
PostPosted: Fri Sep 06, 2019 2:57 pm    Post subject: Re: What to do with these side foot-rails? Reply with quote
Jeffrey Lee wrote:
Rolling Eyes Rolling Eyes Rolling Eyes
That photo is hilarious! Guy takes bikini babe to the beach in his van... plays chess! They're so intellectual! Shocked Very Happy
"A Vanagon? It's not a car or a van. It's a hobby!"
Check out www.SyncroSafari.org and www.Vanagons.org
sphet wrote:
I have *no* idea what the previous owner carried in his Westy... angry donkeys?
Sodo
Sodo is offline
PostPosted: Fri Sep 06, 2019 3:24 pm    Post subject: Re: What to do with these side foot-rails? Reply with quote
Are those Aluminum? I think the steel van body is sacrificial in that case, sacrificing itself, protecting the Aluminum.
Large chunks of aluminum attached to the van should be electrically isolated. In other words, not in direct electrical connection to the steel body. And ideally, only in dry locations. Presence of an electrolyte (salty water) and steel and aluminum (all 3 in contact) is real bad combination and can be called "a battery".
The bigger the chunk of aluminum, the bigger the corrosion. Are they painted or bare/anodized? Bare/anodized is worse. When you bolt bare aluminum to a van, it does not seem to corrode,
not because you're "lucky" or cuz "Aluminum is cool",
but because the steel van body is protecting the aluminum by corroding "more".
So you really should paint the aluminum and lose a little bit of the cool factor.
Seems strange, right?
And it's a detail that's easy to forget, especially cuz anodized aluminum looks cool.
It is "cool" in dry environments.
Your "Aluminum" engine, for example is mostly "dry" cuz it's heated. And the electrical connection is a ground strap that's generally dry too; not bathed in electrolyte.
It's a bad deal wo have aluminum bolted to steel in a wet & salty environment. So I'd say, get those things off the van, or look seriously at the mounting and make sure there is no electrical connection.
EJ25, Peloquin diff, locker, transaxle oil cooler/filtration system
....KTMs, GasGas, and a Stumpjumper
Gear oil is like underwear.
