thedkidhd Samba Member
Posted: Fri Sep 06, 2019 1:58 pm Post subject: Brake bleeding help |
I just installed a new master cylinder in my 69. I cant get fluid to the rears and have no pedal pressure. Please help susposted to head out to a show tomorrow |
bluebus86 Banned
Posted: Fri Sep 06, 2019 2:50 pm Post subject: Re: Brake bleeding help |
Assure master pushrod is correct length, adjust as needed, there MUST be freeplay. Assure rear shoes are adjusted prior to bleeding. Assure rear hoses are not block, they can with age swell internally. make sure bleeder valves are not clogged, remove them to inspect. make sure the metal pipe that runs along tunnel on driver side floor pan, and under rear seat has not ruptured and leaking, thus filling the pan under the floor matts with fluid. they have been known to rust out. lift floor matts to inspect also assure the fluid reservoir hose to rear master fitting is not blocked, kinked.
Good luck
Bug On!
ps also assure master is not defective, loosen the rear pipe fitting on the master and assure fluid comes out when pumped, if not, then for sure check pushrod for end play, if that is good, with proper endplay, then you may have a bad master. you can loosen fitting at hoses at wheels and test if fluid comes out too, do upstream side, if you get flow, then try down stream side. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Fri Sep 06, 2019 3:24 pm Post subject: Re: Brake bleeding help |
Fluid comes out of the back master hole so that's ok. And the has movement before it hits the push rod so it letting it come back all the way |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6617 Location: Houston, Texas
Posted: Sat Sep 07, 2019 9:05 am Post subject: Re: Brake bleeding help |
Tighten all 8 star nuts so the wheels don't move. Then run around the car twice bleeding. _________________ www.vwnos.com [email protected]
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sat Sep 07, 2019 11:33 am Post subject: Re: Brake bleeding help |
If it is still dual circuit MC, you need to bleed the fronts first.
Definitely full lock each shoe to the drums to get it to bleed.
Do not slam pedal, that makes big bubbles int he fluid turn into tiny hard to bleed bubbles. _________________ In Stereo, Where Available! |
Rayfield Samba Member
Joined: October 26, 2011 Posts: 127 Location: United States
Posted: Tue Oct 27, 2020 4:16 pm Post subject: Re: Brake bleeding help |
Trying to get something resembling brakes on my '75, and got to this thread during my searching. I replaced the MC with a dual circuit (this one: https://www.amazon.com/gp/product/B001PYTNTE/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1). My reading seems to indicate that with a dual, you start with the fronts; I can't get anything resembling a good bleed of fluid out:
Gravity - Fluid will come out for a bit, then it's just air, with the reservoir full up. The reservoir is pretty high up in a '75, so I would have expected this to work ok to get me started.
Vacuum - I bought a cheap vacuum bleeder, but I'm not convinced it seals very well around the bleeder screw. Same story, it will suck out a bit of fluid, and then there's just air in the line coming off the screw.
One-Man-Bleed Kit - I put a hose on that seems fairly tight on the screw, loosen it a quarter to a half turn, and pump the brake pedal a few times. I got some fluid when I first started, then it's all air.
The MC was bench bled using this procedure: http://www.vw-resource.com/alternate.html before I mounted it. But I'm wondering if it's a cheap piece of crap. I see fluid around the top, where the input hoses from the reservoir go in.
One thing I haven't done is something people talk about in this thread, which is to lock my shoes tight to the drum. I don't remember having to do this in the past to get a good bleed, but I'm not having a lot of luck otherwise!
Any thoughts? |
Posted: Tue Oct 27, 2020 4:21 pm Post subject: Re: Brake bleeding help |
Rayfield wrote: |
Any thoughts? |
Sounds like you may have figured it out.... _________________ In Stereo, Where Available! |
Posted: Tue Oct 27, 2020 4:28 pm Post subject: Re: Brake bleeding help |
Eric&Barb wrote: |
Rayfield wrote: |
Any thoughts? |
Sounds like you may have figured it out.... |
Man, that would be nice, I'm riding a wave of frustration, trying to get something working, this week! So just dial the adjustment stars up so the drum no longer turns? |
Posted: Tue Oct 27, 2020 4:49 pm Post subject: Re: Brake bleeding help |
Rayfield wrote: |
Eric&Barb wrote: |
Rayfield wrote: |
Any thoughts? |
Turn adjusting stars out till brake shoes are shoved against the drums and the stars will not longer move. Sometimes with new shoes or shoes that have not been kept in adjustment, they can end up seating down into the drum radius more after you try to bleed the brakes a time or two. So you may need to go around a second time to make sure all the adjusting stars are keeping each shoe tight to the drum. _________________ In Stereo, Where Available! |
Posted: Tue Oct 27, 2020 4:53 pm Post subject: Re: Brake bleeding help |
Ok, thanks. Yep, new brake hardware all the way around, so I'll keep that in mind. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Tue Oct 27, 2020 8:56 pm Post subject: Re: Brake bleeding help |
Rayfield wrote: |
Any thoughts? |
Did you adjust the push rod length to the correct spec. If not, the front piston will not pull and push fluid. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Wed Oct 28, 2020 2:42 am Post subject: Re: Brake bleeding help |
It's a good thought, I'll need to find a writeup for doing that. The car came to me in pieces, I have no idea if the push rod is set up correctly or not.
VW_Jimbo wrote: |
Did you adjust the push rod length to the correct spec. If not, the front piston will not pull and push fluid. |
Michael Ambrozik Samba Member
Joined: October 17, 2020 Posts: 631 Location: San Jose, CA
Posted: Wed Oct 28, 2020 3:35 pm Post subject: Re: Brake bleeding help |
Did you bench bleed the MC before installing it in the car? First step in replacing a MC. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Wed Oct 28, 2020 4:41 pm Post subject: Re: Brake bleeding help |
Michael Ambrozik wrote: |
I always do that too. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Oct 28, 2020 5:55 pm Post subject: Re: Brake bleeding help |
Yep.
Following up, I leveled the car today (the front end was on jackstands, a little higher than the rear, before) and tightened the brakes as advised. When I went to bleed the fronts, I got fluid to flow out of both sides. Backed the shoes off again, but I don't have any pedal as yet. Should I expect to have some pedal if the front circuit has been bled, but not the back, yet?
Hopefully I'll have a second to bleed the backs tomorrow, and see what happens. |
Posted: Wed Oct 28, 2020 7:33 pm Post subject: Re: Brake bleeding help |
Rayfield wrote: |
Yep.
Not if you do not have the front bled completely. To do the rears, you need to relock the front adjusters. That way you have as close to 100% of the pedal to push the air out of the much longer rear circuit. Get both circuits bled before letting up on the adjusters. _________________ In Stereo, Where Available! |
Posted: Wed Oct 28, 2020 9:38 pm Post subject: Re: Brake bleeding help |
Here you go!
FWIW. I have never had to “ lock up” the shoes, to bleed the brakes. But I gravity bleed them first. No reason working hard! Fill the reservoir and open up 1 bleeder and wait. It will start dripping soon! While waiting, I will typically go work on some other part of the car. Easy! Once you get fluid out one side, move to the next side! _________________ Jimbo
TDCTDI wrote: |
Posted: Thu Oct 29, 2020 2:36 am Post subject: Re: Brake bleeding help |
Ah, ok, makes sense. I keep thinking of the front and rear as completely separate stuff, but the pedal is connected to both, isn't it..
Eric&Barb wrote: |
Not if you do not have the front bled completely. To do the rears, you need to relock the front adjusters. That way you have as close to 100% of the pedal to push the air out of the much longer rear circuit. Get both circuits bled before letting up on the adjusters. |
Posted: Thu Oct 29, 2020 2:37 am Post subject: Re: Brake bleeding help |
Thanks!
VW_Jimbo wrote: |
Here you go!
FWIW. I have never had to “ lock up” the shoes, to bleed the brakes. But I gravity bleed them first. No reason working hard! Fill the reservoir and open up 1 bleeder and wait. It will start dripping soon! While waiting, I will typically go work on some other part of the car. Easy! Once you get fluid out one side, move to the next side! |
