Vanagon914 Samba Member
Posted: Sat May 22, 2021 12:58 pm Post subject: Re: Scooby-gets-a-suby |
Finished result
Crankey Samba Member
Posted: Sat May 22, 2021 4:33 pm Post subject: Re: Scooby-gets-a-suby |
I've been looking at rmw vs vanaru kits, you have rmw but the exhaust manifolds look like what vanaru shows on their site. But vanaru dosn't offer parts or a kit now, only a kit supplied to a pro shop for install.
Curious where your parts come from.
Looks pretty great overall. Nice work ! |
Posted: Sat May 22, 2021 6:09 pm Post subject: Re: Scooby-gets-a-suby |
Thanks. The exhaust set up is RMW, including the headers. |
Posted: Sat Aug 07, 2021 9:15 am Post subject: Re: Scooby-gets-a-suby |
So since I got the van I have never been able to find 1st. So I got all new bushings and the "big shot" shifter upgrade. I made sure to mark the locations of where everything lined up, but I'm sure it had been messed with long before I got it because man......was it a pain to get everything lined up correctly. Where the front shaft and rear shaft come together was about 1/2 off where it was originally.
Posted: Sat Aug 07, 2021 9:16 am Post subject: Re: Scooby-gets-a-suby |
Man what a difference thought....... I really like the height difference and the shorter throw. |
STINKAPE Samba Member
Posted: Wed Aug 11, 2021 10:02 am Post subject: Re: Scooby-gets-a-suby |
Nicely done ! |
Posted: Sat Aug 14, 2021 1:48 pm Post subject: Re: Scooby-gets-a-suby |
Got the twin peaks rear bumper to match the front. A little longer and heavier but looks way better.
Posted: Sat Aug 14, 2021 1:49 pm Post subject: Re: Scooby-gets-a-suby |
mitch5 Samba Member
Joined: October 17, 2019 Posts: 132 Location: phoenix
Posted: Sat Aug 14, 2021 9:48 pm Post subject: Re: Scooby-gets-a-suby |
You have a very clean subaru swap! One thing i noticed while browsing through was your RMW carrier install. I have the same carrier and it looks like you installed the crossbar in the syncro spot(bottom holes), unless you were only mocking up. The only side effect of doing that on a 2wd would be losing the 1.5 inch of ground clearance it think? |
Posted: Sun Aug 15, 2021 4:38 am Post subject: Re: Scooby-gets-a-suby |
Yes that picture was just during the mocking up and drilling stage. It's installed the the 2wd upper holes.
Posted: Sat Dec 18, 2021 11:40 am Post subject: Re: Scooby-gets-a-suby |
New Sirocco 360 fan hooked up to the aux battery should help with those hot nights
Posted: Sat Apr 02, 2022 5:41 pm Post subject: Re: Scooby-gets-a-suby |
Got a rancho rebuild installed and running smooth. Always check the gear oil because it didn't come with any and I totally almost went for a spin without checking....
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Posted: Sat May 28, 2022 11:17 am Post subject: Re: Scooby-gets-a-suby |
1st time doing drums not too bad
Posted: Sat May 28, 2022 11:18 am Post subject: Re: Scooby-gets-a-suby |
New steering wheel, little extra leg room also
sanchius Samba Member
Posted: Sat Aug 13, 2022 9:48 am Post subject: Re: Scooby-gets-a-suby |
Fox shocks were back in stock (for maybe 10 minutes) so I had to hop on it. The poor man's lift that had been installed by the PO sure made this job a bigger pain
Posted: Sat Aug 13, 2022 9:49 am Post subject: Re: Scooby-gets-a-suby |
Posted: Sat Aug 13, 2022 9:51 am Post subject: Re: Scooby-gets-a-suby |
There were home made spacers all over the suspension .I removed them all and with zero lift gowesty springs the van was raised an inch
Posted: Sat Aug 13, 2022 9:54 am Post subject: Re: Scooby-gets-a-suby |
After doing the front with a traditional spring compressor, I had to get a better set up because there is so little space to get a bite. Save your self some pain and get this kind
