Looking for info on missing engine part- air flap?
mrutatech
mrutatech is offline
PostPosted: Wed Sep 11, 2019 9:03 am    Post subject: Looking for info on missing engine part- air flap? Reply with quote
Hi everyone, I'm trying to get this bus put back together (correctly!), and I just came across a missing part. A new bus friend showed me that the engine is missing a "flap" as shown in the picture.
Can anyone tell me what this is called and possibly any leads on where I can source a replacement?
Thanks!!!!
[/img]
SGKent Premium Member
SGKent is offline
PostPosted: Wed Sep 11, 2019 9:14 am    Post subject: Re: Looking for info on missing engine part- air flap? Reply with quote
there is a cover and a flap on each side. keeps air from pushing back into the shroud when the defrost fan or aux heater if you have one are on.
You also need a pin for each flap. I made pins out of nails I cut off.
They look like this photo from RAtwell.com
Godspeed to all who undertake a journey in a VW Bus.
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing those right.
It isn't our fault you bought a 50-year old toy you can't afford. None of us can afford it really. Even Steve Jobs had to sell his bus to make his financial life work.
1971 (sold)
1977
SamboSamba22 Premium Member
SamboSamba22 is offline
PostPosted: Wed Sep 11, 2019 9:17 am    Post subject: Re: Looking for info on missing engine part- air flap? Reply with quote
Flaps are correct as shown above and need to be sourced. I know that Bus Depot sells the covers, which originally came with a type of cork gasket. Not sure if there is aftermarket availability on the flippers.
The Bus Barn Ltd. Co.
Maywood Mountain
Invention is the tool of the adventurer - Jacques Cousteau
Sinning led me to become a saint, which I then learned I wasn't qualified. -S.H.B.
1959 Dove Blue Single Cab - SOLD (undergoing complete restoration)
1965 Ruby Red Standard Beetle - SOLD (currently loved in Oklahoma)
Oct. ’67 Double Cab (’68 Doka) 1835, Weber 40 IDF’s
1974 Brilliant Orange Westfalia “PushPop" The bus that started it all - SOLD
Wildthings
Wildthings is offline
There is a flap under that area that is not needed, what you need is the cover. I think they are available new at this point in time. Try CALLING Bus Depot and see if they have a box of them somewhere. The right and left covers are different in shape.
The cover has a gasket to help it seal, but I just use high temperature silicone. I put a bead on the cover, let is set for a half hour or so until it skims over well but has not fully set. I then install it carefully and tighten the screws down, this gives a nice tight custom fit even with somewhat mangled parts and pieces, it will be removable even if some of the silicone squished out of the joint.
SGKent is offline
PostPosted: Thu Sep 12, 2019 7:19 am    Post subject: Re: Looking for info on missing engine part- air flap? Reply with quote
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-021-119-263-APR
https://www.vwheritage.com/021119263a-fan-shroud-air-flaps-pair-1700-2000cc-vw-spare
https://www.csp-shop.com/en/engine/fan-shroud-air-flaps-119-263-021a-29611a.html
1971 (sold)
1977
