Tom K. Samba Member
Joined: March 10, 2005 Posts: 1604 Location: Central Pennsylvania
meatness Samba Member
Joined: September 11, 2019 Posts: 29 Location: Sultan, WA
Posted: Wed Oct 16, 2019 2:06 pm Post subject: Re: I have until May |
Tom K. wrote: |
Can you drill in from the transmission side? Drilling the head of that bolt off might free it. |
That's an idea but I don't think that there is room for a drill in there. If I could get the oil cooler off (tins are in the way of the mounting bolts and tins can't be removed without removing engine.....) I could get an air hammer on the bolt head and drive it out. _________________ Noob
1968 Vert Project on a budget
Looking for stock intake tube, stock carb linkage advice and my marbles |
Posted: Wed Oct 16, 2019 2:16 pm Post subject: Re: I have until May |
Buggeee wrote: |
When you go to put that engine back in you're going to need a new captive nut as the doghouse oil cooler will make accessing that difficult if not impossible. Here are a couple of links that had been offered in another thread on this issue so you can get the part when you need it
Cusser wrote: |
I've got this saved as Engine Case Nut Insert Captive Nut
https://www.wolfgangint.com/store/product/engine-case-nut-insert-111199102/
Part #111 199 102
This nut came on all dual relief cases. This is because with a doghouse cooler it is near impossible to get a nut off or on once the engine is in. If you're putting a dual relief case on a transmission that took a single relief case, make sure you grind off the locking boss for the bolt on the clutch arm side before you put the motor in. Be careful not to crack the case when installing. Rig up a pipe that has a notch to match the notch on the flywheel side of the case. Draw the nut into the case with a bolt. |
And here's the thread that those quotes came from
https://www.thesamba.com/vw/forum/viewtopic.php?p=7061930
The engine in your bug may have come from a later model so there are some differences. The common idea that all these parts can be mixed and matched across the years is only partially true. Volkswagen was constantly making changes sometimes even mid-year so often times there are little modifications needed to get things to match together you never know how the prior owner got it done.
Cussers comment about the locking boss for the bolt on the transaxle side is something that may be a clue to help your quest. |
Digging around in the links pointed me to this https://www.wolfgangint.com/store/product/engine-case-nut-insert-111199102/
"If you're putting a dual relief case on a transmission that took a single relief case, make sure you grind off the locking boss for the bolt on the clutch arm side before you put the motor in. Be careful not to crack the case when installing. Rig up a pipe that has a notch to match the notch on the flywheel side of the case. Draw the nut into the case with a bolt."
Guess what wasn't done by one of the PO's Well I am still stuck but at least I know why. Also, how the hell was this installed flush like this?! _________________ Noob
Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Wed Oct 16, 2019 2:23 pm Post subject: Re: I have until May |
It'll be a bitch, but since the head is off the speed nut, it should just pull through the case.
Try jacking the engine up so that there is a gap between the engine & trans, place a coin or screwdriver in between & lower the engine & repeat as it pull through. The closer you can get to the top, the less likely you are to crack the ear off the case. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Oct 16, 2019 2:29 pm Post subject: Re: I have until May |
TDCTDI wrote: |
Try jacking the engine up so that there is a gap between the engine & trans, place a coin or screwdriver in between & lower the engine & repeat as it pull through. The closer you can get to the top, the less likely you are to crack the ear off the case. |
That's not a bad idea. I am checking now how hard it is to just pull the transmission with it. Once out I can have much better access to everything. _________________ Noob
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9955 Location: Huntington Beach, CA
Posted: Wed Oct 16, 2019 4:20 pm Post subject: Re: I have until May |
Pulling the tranny attached to the engine is not an option. The differential flanges will not clear the frame horns. They need to move past the end of them.
You stated earlier about having an oil cooler wrench. I have one made by a company in Germany. I had a fellow mechanic take a cheap 10mm box end wrench and bend it to do the same thing. Might be worth it!
_________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Wed Oct 16, 2019 5:10 pm Post subject: Re: I have until May |
VW_Jimbo wrote: |
Thanks Jimbo! That should be a lot of help. _________________ Noob
Posted: Thu Oct 17, 2019 7:59 pm Post subject: Re: I have until May |
When I bought the bug it came with new heater and support channels. As I have started to learn a little I am thinking that these heater channels are not correct for the year. I believe that these or for '69 and up body and I want the heater channels for the '68 and back.
Is my thinking correct here?
If I buy heater channels for '68 and back, will they have the heat slots in stock location up near the foot well or will I have to cut and weld to keep that stock location?
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Thu Oct 17, 2019 8:46 pm Post subject: Re: I have until May |
Those heater channels are later than 1970 model year. HCs changed some between 1967 & 1968 model year.
From a search for "heater channel" and checked the "Titles Only" box.
https://www.thesamba.com/vw/forum/search.php?searc...=titleonly _________________ In Stereo, Where Available! |
Posted: Thu Oct 17, 2019 10:48 pm Post subject: Re: I have until May |
Those are Klokerman heater channels. They have one set of dies for stamping early and late channels. You get both, for every year. They cut out the vent based on the year. They work. They just look wrong. There is another producer of later style channels. I am coming up with Klassicfab, but that is wrong. They are only up to 67. There is another supplier. I think CIP1 sells them.
It is CIP1. I just looked. Dansk is the manufacturer.
https://www2.cip1.com/ProductDetails.asp?ProductCode=TAB%2D400%2D432 _________________ Jimbo
TDCTDI wrote: |
Posted: Thu Oct 17, 2019 11:01 pm Post subject: Re: I have until May |
Thanks again. This one looks correct to me. https://www2.cip1.com/ProductDetails.asp?ProductCode=TAB%2D400%2D431
Or maybe not. Hard to tell..... Looks like there is a set out there that doesn't have the inner pipe. _________________ Noob
Posted: Fri Oct 18, 2019 12:54 pm Post subject: Re: I have until May |
Working on the driver side top mount today. Having to dig quite a bit to get it done right and the wiring harness is in the way so things are transitioning a little bit to pulling the engine again.
@VW_Jimbo - I bent me up a wrench and got the oil cooler out of there, then tried to drive the bolt through with the air hammer, then a sledge with not affect. I am headed into town to grab a cheap wrench that I can make something out of to get that damn bolt out.
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4407 Location: Stuck in Ohio
Posted: Fri Oct 18, 2019 8:42 pm Post subject: Re: I have until May |
Buggeee wrote: |
OMG Meatness that engine bolt Fiasco is something I've never seen before and I can't get my head around how that thing was tightened in ever. This is too ridiculous. Welcome to the world of air-cooled Volkswagen by the way. Prior owners have left us all with one legacy or another, but I have never seen a riddle like this before. |
There has been plenty of PO surprises on this car and I am sure more to come. It's going to be a road to travel getting everything sorted.
I did end up drilling the bolt out from the engine side to get the engine out. It came out very clean in the end and will have no lasting damage from the "Fiasco"
I appreciate the shoulder to cry on and the feedback I get from you guys. Even when you are just telling me how dumb I am. _________________ Noob
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Sat Oct 19, 2019 3:15 am Post subject: Re: I have until May |
meatness wrote: |
I appreciate the shoulder to cry on and the feedback I get from you guys. Even when you are just telling me how dumb I am. |
Don't worry about people telling you you're nuts, just work on the car as hard as you can and imagine your wife at her birthday!
Happy wife, happy life _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
wcfvw69 Samba Purist
Posted: Sat Oct 19, 2019 6:39 am Post subject: Re: I have until May |
Oh yes, I know exactly what road you're driving down. If I may make a suggestion. Find someone selling original heater channels from a parted out bug in the dry, rust free SW USA before fitting those terrible aftermarket heater channels. They are really bad. I fitted one of those aftermarket heater channels on the drivers side during my 69 bug convertible restoration. Never again.
What I learned replacing the lower 12" of my convertible metal is NOTHING fits like the original German made metal. If I did this again, I'd find donor metal all day long vs. buying any of the new metal sold as it's just terrible. On your bug, it's obviously had a front nose impact. You really need to pull it out and massage the metal back into place. There's body measurements on this site. Doing so will assure your fenders and hood will fit correctly. Find original VW fenders before buying aftermarket as well.
The good news is after hundreds and hundreds of hours and major damage to my wallet, these projects can have a happy ending.
Feel free to PM me if you have any questions or need help during your restoration.
Bill[/img] _________________ Contact me at [email protected]
The Samba member since 2004.
tisius Samba Member
Posted: Wed Feb 05, 2020 4:42 pm Post subject: Re: I have until May |
How is progress on your build, just curious? _________________ drive it like you just robbed the bank
Tom K. Samba Member
calvinater Samba Member
Joined: September 06, 2014 Posts: 3327 Location: 802 The Pointless Forrest
Posted: Thu Feb 06, 2020 5:08 am Post subject: Re: I have until May |
Like a friend said when i asked when he was getting married? " May, may the day never come " _________________ "Albatross"! |
Posted: Thu Feb 06, 2020 10:19 am Post subject: Re: I have until May |
Drill that bolt out. Be sure to center punch it. Drill in enough to just take the threads off of the splined nut. _________________ Jimbo
TDCTDI wrote: |
