BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Fri Sep 13, 2019 11:44 am Post subject: VW tech bulletin for rear big hatch interior emergency release?? |
Hi all,
I know at some point that I saw a VW technical bulletin on how a VW technician or an owner could go back and install a interior pull ring that when pulled from inside would release the locked "big" rear hatch on a later Split-Bus. Ideal for a camper or any Bus as a way to get out if needed through the locked hatch. I believe you simply drilled a small hole and with a cotter pin and a round key ring you could cobble up this interior "pull release". Can anyone point me to a copy of the bulletin, as I'm about to do my entire interior wall and ceiling panels in new Baltic Birch and I want to add this feature to the interior panel on my rear hatch. Thanks for any help!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Fri Sep 13, 2019 12:02 pm Post subject: Re: VW tech bulletin for rear big hatch interior emergency release?? |
The "cobble" is in The Bentley for big hatch. If you can't find it I can go look. |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Fri Sep 13, 2019 2:12 pm Post subject: Re: VW tech bulletin for rear big hatch interior emergency release?? |
Hi Nancy!
We missed you guys at BNNTA! No, what I'm talking about is for the rear hatch (above the engine deck lid) on a late Split (my '67 westy).
"BarryL", I think you are correct about the mention of how to adapt the hatch latch assembly so you can open it from the inside. I'll dig out my Bentley Manual and look it up, I'll bet it's in there! A nice, simple fix to allow you to pop open the rear hatch from inside if you ever needed to.
Bill _________________ I'm looking for these license plate frames for my fleet:
velvetgreen Samba Member
Posted: Fri Sep 13, 2019 3:24 pm Post subject: Re: VW tech bulletin for rear big hatch interior emergency release?? |
I can't recall where I have seen it but basically involves one small hole to be drilled in the rear hatch release mechanism. Obviously you have to cut a triangle shaped notch in the rear hatch baltic birch to allow access to lock mechanism |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Sat Sep 14, 2019 7:27 am Post subject: Re: VW tech bulletin for rear big hatch interior emergency release?? |
Thanks again to "BarryL" for mentioning that the bulletin was in the "Body" section of the Bentley Workshop manual. Enjoy!
edit: sorry it is upside down, I don't know how to straighten the image. Have at it if you can.
EverettB Administrator
Joined: April 11, 2000 Posts: 69807 Location: Phoenix Metro
sgellis Samba Member
Joined: July 06, 2016 Posts: 2013 Location: SW Nova Scotia, Canada
Ragman The Sambinator
Posted: Mon Sep 16, 2019 8:40 am Post subject: Re: VW tech bulletin for rear big hatch interior emergency release?? |
This is how they are done in SO42 westys. (picture pulled from gallery)
Posted: Mon Sep 16, 2019 1:22 pm Post subject: Re: VW tech bulletin for rear big hatch interior emergency release?? |
SO44 as well. No need for a pin, easy access. |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Mon Sep 16, 2019 3:25 pm Post subject: Re: VW tech bulletin for rear big hatch interior emergency release?? |
I installed juan of thems in the Dormy also. A simple small opening cut to the board is good enough for access to the “trigger”. Notice that the bulletin calls for the pin/ring install on comercial passenger buses, meant to be used as an emergency exit. For your own bus it’s okay to just have access to the latching mechanism from the inside. Not to mention the damage that the pin/ring addition could cause to the cushion on a camper. _________________ Some people are so busy being clever they don't have time enough to be wise. |
BarryL Samba Member
Posted: Mon Sep 16, 2019 6:58 pm Post subject: Re: VW tech bulletin for rear big hatch interior emergency release?? |
Fwiw mine. Too bad I put it on the wrong edge of the new one.
