Dash2808 Samba Member
Posted: Fri Sep 20, 2019 7:59 pm Post subject: Re: 1.8T swap w/ auto trans ~ alternator light weirdness |
oes anyone know if i can use an Automatic Transmission from 1980- 1990 VW Vanagon into a VW Bus t2 Engine? or i should use only with the original 2.1 engine and adapt it into a T2 Bus?...sorry if it's a dumm question |
Zeitgeist 13 Samba Member
Posted: Fri Sep 20, 2019 8:38 pm Post subject: Re: 1.8T swap w/ auto trans ~ alternator light weirdness |
"80-'83 vans with AC engines were attached to autos, so I don't see any reason why they can't be used in earlier bay vans. The later autos can also be used, but the 2.1L versions will need some kind of an external heat exchanger. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Sat Sep 21, 2019 5:07 am Post subject: Re: T3 Vanagon auto trans into T2 Bay Window? |
What year bay? From memory the late bays and the aircooled vanagon had a very similar install. That would be the easiest swap. _________________ ☮️ |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Sat Sep 21, 2019 6:48 am Post subject: Re: T3 Vanagon auto trans into T2 Bay Window? |
The vanagon air cooled automatic was geared taller than the later wbx auto. _________________ ☮️ |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Sat Sep 21, 2019 8:03 am Post subject: Re: T3 Vanagon auto trans into T2 Bay Window? |
I''m just finishing up putting the auto trans from an '81 into a '77 Bay Westfalia -- which is also a manual-to-automatic conversion for someone who can't drive stick anymore -- did the first test driving on the Bus yesterday.
Assuming a T4 engine, attaching the transmission to the engine is the easy part. You can use the flex plate and torque converter from the Vanagon (AC or WBX) and it all bolts together. Where it gets tricky is with the Bay-specific ancillary parts, if you don't already have them: the transmission mount, the CV axles, the throttle cable & bracket, the shifter, shifter linkage&cable&bracket, the AT filler/dipstick tube, the AT dipstick.
Some of those can be found new (CV axles, throttle cable), some of those can be worked around with fabrication or adapting the Vanagon part. The mount is really going to be the sticking point I think. Vanagon won't work and there's not a lot of room to work with for anything else... |
