bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Tue Sep 17, 2019 7:48 am Post subject: Quick qeustion regarding flasher switch |
I'm looking for a emergency flasher switch for my 71 bus to replace the aftermarket part that has been installed there.
I found one locally with the correct bus knob but it has a 14mm escutcheon, while the headlight switch and the opening for it are 10mm.
So, my question is, was the flasher also 10mm or was the flasher 14mm? Got to make a call on whether to return this one or not.
Thanks! _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Tue Sep 17, 2019 9:18 am Post subject: Re: Quick qeustion regarding flasher switch |
On my '71, it's 14mm. Reason: unlike other switches where the knob just pulls a shaft, the shaft for the e-flasher switch contains a light bulb to light up the knob, so it's bigger. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
bnam Samba Member
Posted: Tue Sep 17, 2019 9:29 am Post subject: Re: Quick qeustion regarding flasher switch |
Telford,
Thanks for the quick response! Prevented me from sending back a good unit. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
Posted: Tue Sep 17, 2019 4:56 pm Post subject: Re: Quick qeustion regarding flasher switch |
Keep in mind, that's for the US version of the bus... _________________ '71 panel, now with FI
