Are AGM Batteries an improvement over typical lead acid battery?
CrRusty
CrRusty is offline
PostPosted: Wed Sep 18, 2019 8:23 am    Post subject: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
It seems like the availability and costs of AGM batteries have come along way in the last few years. I have an AGM (walmart)battery in my 2003 TDI Jetta for almost 9 years now, its still going strong.
Did a search in Bay and Vanagon land but did not turn up much info. I think the AGM are still not yet popular.
So Im thinking of replacing the starting battery in my Bay window with an AGM battery. The baywindow buses are unique since the aircooled engine (2ltr) creates a lot of heat compared to watercoolers, especially when turned off on the summer, and the battery is sitting above the muffler. Will the extra heat be enough to damage the AGM battery any differently than that of a flooded lead acid battery? We also have small output alternators.
Currently can get a 4 year free replacement AGM battery at Popboys for $147.
Appears to be a no brainer, but maybe others have some insight to share?
aeromech
aeromech is offline
PostPosted: Wed Sep 18, 2019 8:42 am    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
Here's mine. It's been working great
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
WhirledTraveller
WhirledTraveller is offline
PostPosted: Wed Sep 18, 2019 10:05 am    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
AGM's are just plain better than regular flooded batteries for starting use. No acid spill, more starting current, less self discharge. If you don't store them discharged they last a long time.
1977 Westy, Automatic. Big Valve heads, CS Cam.
Clatter
Clatter is offline
PostPosted: Wed Sep 18, 2019 11:22 am    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
I quit using AGM and went back to regular lead acid types.
Two reasons:
1. OG USA Optimas are overseas now and do not last long at all.
2. AGM doesn't like to sit; unless you trickle charge them they lose charge.
And then never fully recover..
Post your -recent- experience,
And it will be different than it was a few years ago..
So many things like this in the hobby now;
You would think at least batteries would be exempt FFS!
Bus Motor Build
What’s That Noise?!?
a-marshal
a-marshal is offline
PostPosted: Wed Sep 18, 2019 11:30 am    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
I've gone ten years with my Optima shore power battery and eight years with the starter, no problems at all. If it makes a difference my '73 westy gets stored for 6 months every winter.
-Ob. vehicle info....
1973 Westy w/ '74 1.8 liter / PDSI (type3?) carbs / 009 distributor / pertronix
WhirledTraveller
PostPosted: Wed Sep 18, 2019 1:59 pm    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
Two reasons:
1) The OP didn't say anything about Optimas. There a plenty of other brands of AGM.
2) Your experience is the opposite of what extensive testing and use in the field has shown. The self-discharge of AGM's is *significantly* lower than flooded. AGM self discharge typically 1-2% per month, lower at colder temperatures, vs. around 5-10% per month for flooded. AGM should (and does, in my experience) go through winter storage without trickle charging no problem. If your battery is dead in the spring, either you had a phantom power draw or your battery was defective.
What is true is that AGM batteries like to be kept topped off. If you partially discharge them, and store them in that state, they will sulfate. For that reason they don't make great "storage bank" batteries.
bluebus86
Banned
bluebus86 is offline
PostPosted: Wed Sep 18, 2019 2:22 pm    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
WhirledTraveller wrote:
Two reasons:
agree.
also the optima has never leaked in my cars. I got tired of battery acid damage repairs. Specially bad to repair in a 914, Acid there runs into the rockers, the 914 can collapse from this acid damage. I have 3 or 4 optima equipped cars, one of them optimas is 14 years old.
Even if optimas lasted half as long they would be worth it from the acid damage prevention standpoint.
Bug On!
andrewtf
andrewtf is offline
PostPosted: Wed Sep 18, 2019 2:30 pm    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
We have them as our auxiliary batteries in both Big Emma and Murphy.
One reason is that we could get larger batteries (physical size) because AGM batteries can be stored on their side. This makes connections and everything else .............. easier.
'75 Riviera - 'BIG EMMA' (Pan American highway trip paused for a make over)
'77 Riviera - Murphy' (being reborn.... slowly)
'63 Austin Healey
Abscate
Abscate is offline
PostPosted: Wed Sep 18, 2019 2:39 pm    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
I think flooded batteries in Big Emma would be a bad idea.
.ssS!
Q-Dog
Q-Dog is offline
PostPosted: Wed Sep 18, 2019 2:51 pm    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
I installed this AGM battery into my buggy because it is shorter/smaller and lighter than the stock VW group 42 battery I was using. My battery box has been shortened and the stock battery is too tall to fit.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
ImAddicted
ImAddicted is offline
PostPosted: Wed Sep 18, 2019 2:54 pm    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
I think it is already too late for that...
As for the AGM vs FLA batteries, it is interesting to hear the vehement support of the AGMs in this thread, where on other forums like OverlandBound and ExpeditionPortal, they only preach AGMs in cases where mounting the battery is going to be in a non-vertical orientation or if you expect to do a lot of high-angle driving. Otherwise, go with FLA or a non-deep cycle marine battery (they have thicker plates than standard FLA but not as thick as deep cycle). The price difference doesn't justify the livespan.
Deep cycle is an entirely different animal but I assume we are not talking those since we are talking SLI batteries.
1979 Transporter (sold)
KC1MUR
strfish7 wrote:
Original condition, which means something different on this forum than anywhere else!
rugblaster
rugblaster is offline
PostPosted: Wed Sep 18, 2019 3:29 pm    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
My daughter drives a E350 Mercedes Benz and it has had 2 AGM batteries installed by the dealer in Fort Worth in as many years. I'm 250 miles away so they have us by the short hairs. The second one they put in was a few months out of warranty. That is about $800 worth of AGMs in two years. I don't know if I'm a fan or not. My wife's car has one in it too, but it's mounted in the trunk. Also, I had to buy a smart charger to charge the fokker. (We're out of town for periods of time, sometimes.)
'69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!!
WhirledTraveller
PostPosted: Thu Sep 19, 2019 4:28 am    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
Modern cars can have significant power draw when they're off due to "always on" connectivity computers. This would be the same with a flooded lead acid. You could disconnect the battery when storing the car, although this will cause you to lose presets.
andrewtf
andrewtf is offline
PostPosted: Thu Sep 19, 2019 6:20 am    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
No place else can make me laugh and cry at the same time.
Love / Hate all of you.
FYI - The AGM battery side was 'down' after the Big Emma drowning roll-over. Was under water for.... 24 hours or so. We still used it as Murphy's auxilary battery for several months this spring and summer. It worked perfectly except that it would not quite charge to 100%, but it got pretty close. And that was after them using the hell out of it for more than a year and then having a long soak in the river bath tub.
'63 Austin Healey
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Thu Sep 19, 2019 12:54 pm    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
Did you roll Big Emma back over? Give her an enema!
I have all Optima batteries and one Walmart lead battery. The Walmart battery is $25. It's lasted over 2 years and still going. Now I ask myself if the optima are worth it.
ImAddicted
PostPosted: Thu Sep 19, 2019 1:50 pm    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
Said with love, my friend Smile.
There's only a handful of battery manufactures out there. Optima is by Johnson Controls who also make DieHard, Duralast, Bosch, ACDelco, Champion and others.
Walmart's Everstart brand is by Exide, who also make Interstate, Exide, NAPA, older Champion, and others.
My old RAM (2001) had a Walmart battery for 11 years, used in northern Maine, before it had to be replaced. I no longer have that truck but the guy who is using it on his farm up the road still has that 2012 replacement Everstart in it. My DD and the better half's Jeep both have Everstarts in them. Even if they crap out at 5 years, for $50 a pop, that's $10 year. Red Optima would have to last 26 years to break even. Not sure it can do that.
KC1MUR
VWNOS.com
heimlich is offline
PostPosted: Thu Sep 19, 2019 1:54 pm    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
That's because China floods the market and sells their batteries for less than they can make them for. They put the competitors out of business and then slowly ramp the prices back up. They don't do this only with batteries.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Thu Sep 19, 2019 2:00 pm    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
batteries are ALL junk these days. the claim to fame for the AGM's is a "cleaner" voltage so lots of high end shit use them. even still, you're lucky to get 3-5 years out of most (in high end cars, that is)
buy the biggest, cheapest battery you can stuff in the slot and call it a day. I just had to replace the battery in my blazah (that's right, bla-zah) plow truck. it lasted me 11 years.
the exact same battery I replaced it with must have weighed 5 pounds less. point being....they don't make them like they use to.
AGM isn't needed unless you have a special need for one. i'd save my money
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Clatter
Clatter is offline
PostPosted: Thu Sep 19, 2019 4:42 pm    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
^^^^Thank you for your real experience in the field^^^^
Mine has been the same.
Bus Motor Build
bnam
bnam is offline
PostPosted: Thu Sep 19, 2019 6:25 pm    Post subject: Re: Are AGM Batteries an improvement over typical lead acid battery? Reply with quote
The AGM in my 2008 E-class was only replaced in 2018. I think constant use is better for that battery. The lead acid in my Beetle was replaced in 2012. Still using it. I drive the car only 1000mi/yr or less.
Click to view image
1952 Citroen TA 11BL
