Drtrash Samba Member
Posted: Wed Sep 18, 2019 5:12 pm Post subject: Engine bay seals |
Dropped engine and want to replace seals, not sure how to go about replacing both rubber strips? Any assistane that would help make it a worthy endeavor would be greatly appreciated |
YDBD Samba Member
Joined: February 25, 2017 Posts: 891 Location: Bavaria, Germany
Posted: Wed Sep 18, 2019 8:48 pm Post subject: Re: Engine bay seals |
Do what you can to get the old one out.
Clean the grooves-really well there's gunk in there. Make sure the groove tabs are not bent or squished down.
Now the fun part, find a lube (silicone, wd-40, liquid wrench) that works on the new rubber with out dissolving it. Start at one end and start working it around, probably sitting inside the engine bay. You might use a couple pairs of pliers, needle nose and screw drivers to help pull and push, you will chew up the end a bit but you can cut that off later. Use the screw driver to work the rubber trim around under the flap.
Stretch and pull, stretch and pull, when you stretch it will move in the groove a little. About 2 hours later Viola! You have a new rubber seals! _________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
Posted: Thu Sep 19, 2019 4:49 am Post subject: Re: Engine bay seals |
Got old out that was easy, never would of thought you slide it all the way around. Do you pry the track out at all or just stretch and pull ? Not sure what previous owner did to get old ne in, have not inspected track yet |
jakokombi Samba Member
Joined: August 15, 2010 Posts: 779 Location: Milwaukee
Posted: Thu Sep 19, 2019 9:55 am Post subject: Re: Engine bay seals |
I recently replaced mine by prying it in with plastic pry tools after trying to feed it in.
It got easier as I went and I was far more successful. _________________ 70 Sunroof Kombi
85 Motherfukinvanagon
73 Thing
72 Baja |
Posted: Thu Sep 19, 2019 10:30 am Post subject: Re: Engine bay seals |
A heat gun may help also, both to remove and install. _________________ 70 Sunroof Kombi
73 Thing
72 Baja |
Posted: Fri Sep 20, 2019 5:58 am Post subject: Re: Engine bay seals |
Thanks for the tips, lube and heat, should be interesting |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Fri Sep 20, 2019 3:49 pm Post subject: Re: Engine bay seals |
Kentucky Jelly; doesn't degrade rubber |
Posted: Fri Sep 20, 2019 9:28 pm Post subject: Re: Engine bay seals |
Not sure if i should ask what is kentucky jelly, sounds like a choir maybe thats why few talk about it, appreciate the head start, going to do a serious de-grease of bay and jump on it while motor is being built |
YDBD Samba Member
Posted: Fri Sep 20, 2019 9:44 pm Post subject: Re: Engine bay seals |
KY jelly...water soluble lubrication....used often for coitus and other promiscuous activities to avoid chaffing, hot spots and to increase enjoyment of said activities. _________________ '56 pan Dune Buggy since '69
'67 bug
'64 baja
'60 dune buggy
