dschaftlein Samba Member
Posted: Sat Sep 21, 2019 4:51 pm Post subject: 130/90 H4 bulbs |
Anyone running these bulbs in their square headlight e code housings with relays? |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sat Sep 21, 2019 7:10 pm Post subject: Re: 130/90 H4 bulbs |
Did. The lifespan is not as long as 55/65w, but they are brighter for sure.
You need the relays installed to maximize the watts.
About $6.00 on Amazon.
https://www.amazon.com/gp/aw/d/B000VUB4CW?psc=1&ref=ppx_pop_mob_b_asin_title _________________ This free advice is worth exactly what you paid for it.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sat Sep 21, 2019 7:16 pm Post subject: Re: 130/90 H4 bulbs |
I run them in my Beetle.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Sep 21, 2019 10:03 pm Post subject: Re: 130/90 H4 bulbs |
Glenn wrote: |
How do you like the light pattern from those CIBIE's?
I ran those CIBIE's H4's in my '84 and much preferred the Hella H4 e codes over the CIBIE's H4's. _________________ This free advice is worth exactly what you paid for it.
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sun Sep 22, 2019 10:09 am Post subject: Re: 130/90 H4 bulbs |
I found that the 80/100 bulbs made just about as much usable light and lasted much longer. I'm now running 80/85 bulbs that last for years in my 7"round Cibie lamps. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Glenn Mr. 010
Posted: Sun Sep 22, 2019 10:33 am Post subject: Re: 130/90 H4 bulbs |
Steve M. wrote: |
Glenn wrote: |
I run them in my Beetle. |
I ran those CIBIE's H4's in my '84 and much preferred the Hella H4 e codes over the CIBIE's H4's. |
I first got them back in 1978 and still have my original set. i was lucky to find a NOS set a 15 years ago at a garage sale for $20.
I love the light pattern, the low beams have a sharp cut off and even with the 90W lows, they don't blind anyone. But put on the 130W lows and it's like a 747 coming to land behind you. _________________ Glenn
Member #1009
#BlueSquare |
maco70 Samba Member
Joined: March 16, 2011 Posts: 456 Location: Montréal, Québec
Posted: Sat Sep 26, 2020 12:27 pm Post subject: Re: 130/90 H4 bulbs |
No issue with the wires and electric components once we use that wattage (90/130 or 80/100) of bulbs, instead of 55/60 ?
I have the headlights relay kit, but still isn’t a lot of wattage for the wires ? _________________ Martin from Montréal
1986 Vanagon GL full camper westfalia
(brown/tan interior) |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
Posted: Sat Sep 26, 2020 3:50 pm Post subject: Re: 130/90 H4 bulbs |
I got the BusDepot.com kit several years ago that included the H4s for motorcycles and they have been very good. But motorcycle headlights may not be legal on a car in your state because they are very bright. You may not be concerned considering all the excessively bright headlights cars now run. Keep them aimed properly so you don’t blind oncoming drivers, and be aware that if your rear end sags under load it affects your headlight pattern.
I can verify that they really light up the road ahead. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Sat Sep 26, 2020 3:52 pm Post subject: Re: 130/90 H4 bulbs |
maco70 wrote: |
I have the headlights relay kit, but still isn’t a lot of wattage for the wires ? |
Its not the wires, its the switch. The relay prevents the switch from burning out. The wires are big enough. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
maco70 Samba Member
Posted: Sat Sep 26, 2020 4:37 pm Post subject: Re: 130/90 H4 bulbs |
Well received.
More, I will be aware about the light pattern for oncoming vehicules.
Many thanks _________________ Martin from Montréal
markswagen Samba Member
Joined: January 28, 2018 Posts: 1039 Location: san diego
Posted: Sat Sep 26, 2020 7:17 pm Post subject: Re: 130/90 H4 bulbs |
i'd put in some LED's in there, in place of the incandescent bulbs, extremely bright, no need for wiring upgrades.
https://www.amazon.com/Auxbeam-headlights-headligh...6387f8bcf1
i've used them on dozens of customer vans, everyone is happy, i have them in two of mine, IMHO no need to look else where. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
nemobuscaptain Samba Member
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Sun Sep 27, 2020 11:55 am Post subject: Re: 130/90 H4 bulbs |
A couple comments. First, Gnarlodious if you have two motorcycle single headlamp beam patterns on your van, then the left headlamp is putting glare at oncoming drivers. There's a reason that setup is illegal many/most places. The left headlamp cutoff pattern when viewed on a wall at night should be flat and the right headlamp cutoff pattern slopes upward to the right to illuminate away from oncoming drivers but provide farther away light. So be advised.
On super output bulbs like those asked about. It's worth knowing that the glare to oncoming drivers can be controlled with a quality beam pattern such as E codes. However, that's on a dry night. On a wet night, you're absolutely killing oncoming drivers as they're looking at the wet pavement bounce into their eyes of WAY too many watts. Putting 90 watts out on low beams on a wet night is extremely unkind. So keep that in mind.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
maco70 Samba Member
Posted: Sun Sep 27, 2020 12:46 pm Post subject: Re: 130/90 H4 bulbs |
Security first
I will stay with the 55/60 on E code new rectangular headlights. Enough brightness and more secure for oncoming vehicules. Thanks ! _________________ Martin from Montréal
Nimbus'87 Samba Member
Joined: January 03, 2013 Posts: 125 Location: Murrieta, Ca.
Posted: Sun Sep 27, 2020 6:23 pm Post subject: Re: 130/90 H4 bulbs |
With the higher wattage bulbs comes more heat; consider ceramic plug ends as well.
With the BD Ecodes, I've found no need for the super watt's.
Agreed about the glare and rain refractions. _________________ '87 Wolfram Grey Westy. '92 2.2 Subie, KEP/Calif. Reg. |
