Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10371 Location: Sunshine Coast B.C.
Posted: Mon Sep 23, 2019 9:18 am Post subject: New Mk3 IAC Idle Control Valve Quality User Input? |
Hi folks.
This is for the OBD1 ABA 2.0
Any users out there have experience with various brands of new or rebuilt IAC valves? i.e. for a $44 CND BECK/ARNLEY 1581478 am I looking at a really cheap product that will fail soon?
e.g. from Rockauto
https://www.rockauto.com/en/catalog/volkswagen,199...valve,6072
BOSCH 0280140551 Actual OE Part
STANDARD MOTOR PRODUCTS AC309 {#037906457E} Intermotor
WVE/AIRTEX/WELLS 2H1425
To VIN # 1H-S-999000
ULTRA-POWER 2H1425 Info
TO VIN # 1H-S-999000
BECK/ARNLEY 1581478 {#037906457E} Info
GL Model; GLS Model; Limited Edition [Wholesaler Closeout -- 30 Day Warranty] (Only 10 Remaining) _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Mon Sep 30, 2019 7:02 pm Post subject: Re: New Mk3 IAC Idle Control Valve Quality User Input? |
Dunno, I have never had one fail. I still have the original one on my '94 Golf with 318K miles on it.
Can you source one from a pick-n-pull? |
Posted: Tue Oct 01, 2019 9:41 am Post subject: Re: New Mk3 IAC Idle Control Valve Quality User Input? |
ps2375 wrote: |
Thanks. Helpful POV. My other ABA engine idles perfect. Same IAC for some miles. I've thoroughly cleaned each IAC on each engine.
Yes. I just bought another IAC and 2 spare ECU's re: the IAC, the other day my VW parts guy said something like 'unless its VAG, [Bosch] don't buy it'.
I just swapped in one of the "new" ECU's. I'm hoping the issue was at the "adaptive" circuitry in the old ECU. I'll inspect it for any scorched parts or cold solder joints.
Swapping the IAC in question to my other van didn't seem to cause the issues I see so it's most likely that the valve itself isn't at fault. On the van with the idle issues, the IAC Ohms out and I haven't found a fault in the wiring or a related sensor input to the idle control system. "Thankfully", lately, I can recreate the issue sometimes. 95% of the time the engine idles, runs awesome.
If I can't solve it, I'd be tempted to swap in an OBD2 system. FAS still has new Tiico motorized throttle bodies.
http://www.foreignautosupply.com/parts-accessories/115-2lr-tiico-throttle-body-brand-new/
I *think* they'd be the same as those used on a North American Mk3 or could be adapted?
Anyhow. This is getting into the "hybrid" forum territory.
Neil.
FAS Tiico new throttle body
VE7TBN |
