bnam Samba Member
Joined: July 02, 2006 Posts: 2935 Location: El Dorado Hills CA/ Bangalore, India
Posted: Sat Sep 28, 2019 1:24 am Post subject: Turning OG drum brakes on my 65 - how low (thin) can I go? |
I had to turn down the OG drums on my 65. It was pulsing and out of round. Post turning, the ID measures 234mm. Right now, I just need to be able to drive it about 50-100km/mo -- in slow city traffic. Will be stripping the car down for a full rebuild in a few months.
How bad is 234mm vs. original spec? I'm thinking it should be ok for the use I have in mind until I do full pan-off in a few months. By then I can source some good German drums I hope.
Byas _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Sep 28, 2019 4:59 am Post subject: Re: Turning OG drum brakes on my 65 - how low (thin) can I go? |
Should be fine for temporary but its beyond its limits by specs.
glutamodo wrote: |
from the 66-69 Bentley:
from the 61-65 Bentley:
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sat Sep 28, 2019 5:00 am Post subject: Re: Turning OG drum brakes on my 65 - how low (thin) can I go? |
Wear limit is 231.5mm, so 234 is pretty big.
The problem is when you exceed the limit is besides getting hotter and fading quicker, when you adjust the shoes they ride out too far and slip off the shoe support pads on the backing plates. This puts the shoes at an angle thus causing less contact area and possibly a clicking sound when braking. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
