Thompson2 Samba Member
Joined: June 06, 2018 Posts: 659 Location: Portland, OR
Posted: Thu Sep 12, 2019 8:23 am Post subject: Easy engine bay air seal question |
Pulled the engine for the first time last night (thanks MW for the extra hands) and replaced the air seals. What I couldn’t seem to find was how to trim the seals at the front intersection. My old ones were mostly gone, so they weren’t real helpful as guides. This is what I’ve got right now and I’m just wondering if I should leave the excess in the firewall seal or trim it just above the horizontal seal.
Thanks!
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Thu Sep 12, 2019 9:44 am Post subject: Re: Easy engine bay air seal question |
They will shrink up a bit after you drive the bus around for a while. I'd just leave them and concentrate on cleaning that engine compartment! _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Thu Sep 12, 2019 9:56 am Post subject: Re: Easy engine bay air seal question |
crofty wrote: |
They will shrink up a bit after you drive the bus around for a while. I'd just leave them and concentrate on cleaning that engine compartment! |
Thanks. That'll make it easier... oh- but the new horizontal seal was already a bit short on the apron (like an inch on each end).... Should I worry about a gap like that and replace just that portion again? It's a WW seal, so I was surprised it wasn't quite right...
Engine bay is mostly dusty. Hopefully I have time this go-round to clean it all. That turkis paint is soooo purdy! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Thu Sep 12, 2019 10:16 am Post subject: Re: Easy engine bay air seal question |
Any hole you can see thru, is a bad hole.
Personally buy the beetle rear seal and cut it up into the three pieces needed forward of the bus rear apron. _________________ In Stereo, Where Available! |
Posted: Thu Sep 12, 2019 11:56 am Post subject: Re: Easy engine bay air seal question |
Eric&Barb wrote: |
Any hole you can see thru, is a bad hole. |
Figure'd that'd be the answer.
Eric&Barb wrote: |
Personally buy the beetle rear seal and cut it up into the three pieces needed forward of the bus rear apron. |
So you use the apron-style seal for the firewall as well? I already installed the "normal" T-shaped bus version. Is there a significant benefit to the split profile over the T-shape?
For reference, these are the ones that are installed now:
Split type - apron and sides
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111813705A
T-type - firewall
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111813741G |
Posted: Thu Sep 12, 2019 1:20 pm Post subject: Re: Easy engine bay air seal question |
Do not think there is a significant improvement using the split type. Just have had them on hand from often buying new ones at the swap meets from those who happened to be selling off new parts from abandoned projects or other reasons. Main thing is that seal is long enough to do all three areas and not be too short as to later shrink open holes.
Did you cut a slot in the front seal to allow the accelerator cable and its tube to pass thru there easily? _________________ In Stereo, Where Available! |
Posted: Thu Sep 12, 2019 3:16 pm Post subject: Re: Easy engine bay air seal question |
Okay. I won’t worry about swapping the front. I will get a new spilt seal and finish up the apron properly.
And no, I haven’t cut a slot... I also don’t have a tube for the accelerator... yet. It’s on my shopping list though.
Thanks again |
Posted: Thu Sep 12, 2019 4:15 pm Post subject: Re: Easy engine bay air seal question |
Good! Do not forget the accelerator bowden tube also. _________________ In Stereo, Where Available! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
sgellis Samba Member
Joined: July 06, 2016 Posts: 2014 Location: SW Nova Scotia, Canada
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Fri Sep 13, 2019 5:44 am Post subject: Re: Easy engine bay air seal question |
On my bus and both my Beetles the accelerator cable tube is long enough that it goes through the seal not the cable. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Fri Sep 27, 2019 10:08 pm Post subject: Re: Easy engine bay air seal question |
Following up an easy question with a dumb one...
Over, under or through?
Does the sheet metal go over the seal with the seal kind of “tucked” along side the sheet metal?
Or does it go completely under the seal, with both “flaps” sitting on top?
Or does it go between the two flaps of the seal?
I’ve managed to get all three situations when I reinstalled the engine today... it appears to be a pain to move it from one position to the other, so I’d like to only do this once... |
Posted: Sat Sep 28, 2019 7:51 am Post subject: Re: Easy engine bay air seal question |
Posted: Sat Sep 28, 2019 9:24 am Post subject: Re: Easy engine bay air seal question |
Well, that definitely makes the most sense. Too bad it’s the version that looks the worst. Lol |
Posted: Sat Sep 28, 2019 9:34 am Post subject: Re: Easy engine bay air seal question |
Eric&Barb wrote: |
Did you cut a slot in the front seal to allow the accelerator cable and its tube to pass thru there easily? |
I ended up not needing to slot the seal for the accelerator cable. Everything went though easily for me. I think that the metal tube that goes through the tins pushed it up just enough to keep it clear. |
