borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Sat Sep 28, 2019 4:13 pm Post subject: Check Your Wipers |
been traveling in Ireland and have seen a few vans (mostly hightop campers) and i just thought i'd let you all know that if you are planning on bringing your van here, it rains almost all the time. you should make sure that your wiper blades are in good knick and that the wiper linkage, arms, switch and associated electricals are also serviceable; because if they are not, you might not be able to safely navigate through the inclement weather that is often found in this part of the world.
good luck and happy vanning _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
