16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Wed Oct 02, 2019 6:58 pm Post subject: Re: Bad Gas Mileage |
Have you checked your grounds? Is your tail pipe Fat? My 1.9 was running like crap and using a ton of gas. After cleaning the grounds it all went away.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
jlrftype7 Samba Member
Posted: Thu Oct 03, 2019 6:57 am Post subject: Re: Bad Gas Mileage |
16CVs wrote: |
Have you checked your grounds? Is your tail pipe Fat? My 1.9 was running like crap and using a ton of gas. After cleaning the grounds it all went away Stacy |
. Me too..... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto
andrewvwco Samba Member
Joined: February 23, 2017 Posts: 298 Location: Estes Park colorado
Posted: Thu Oct 03, 2019 7:41 am Post subject: Re: Bad Gas Mileage |
16CVs wrote: |
Stacy |
Same clean all the grounds of any dirt, paint, exc down to bare metal. Put a fresh bolt and new ground cables too it is easy and cheap.
Here is the 1.9L ground locations.
https://www.thesamba.com/vw/forum/viewtopic.php?t=662834 _________________ Be here now, not in the past and not in the future, but be here now. |
-Derek- Samba Member
Joined: February 24, 2009 Posts: 41 Location: Seattle, WA
Posted: Sat Oct 05, 2019 8:39 pm Post subject: Re: Bad Gas Mileage |
Thanks all for the replies. Busy week at work, but took some time today to fuss with the grounds. Re-terminated a bunch of the small wire grounds to new ring terminals. Re-terminated the main engine ground strap. Cleaned everything. Made sure all the terminals were nested neatly and bolts tight. Measured nil resistance with engine cold. But after running there resistance was as I quoted earlier (~3 ohm from block to chassis). Real head scratcher.
I repeated the two diagnostic tests I performed last sunday with the same results. I'll borrow a fuel pressure test kit from the local FLAPS and measure the pressure next.
Unrelated, but while doing an oil change I spotted a coolant leak from the new water pump. Grrrr..... Looks like I'll be headed for a GW warranty claim. _________________ '83 Vanagon
'72 914 |
Posted: Sat Oct 05, 2019 8:51 pm Post subject: Re: Bad Gas Mileage |
16CVs wrote: |
...Is your tail pipe Fat? ... |
Not sure what you mean. My tailpipe is ugly for sure. _________________ '83 Vanagon
'72 914 |
Posted: Tue Oct 08, 2019 6:30 pm Post subject: Re: Bad Gas Mileage |
Fuel pressure is 36 psi with vacuum line disconnected, 32 psi connected. So a little higher than Bentley specifies, but not drastically off. _________________ '83 Vanagon
'72 914 |
Posted: Sun Oct 20, 2019 8:21 pm Post subject: Re: Bad Gas Mileage |
Today was the first lengthy drive since adjusting the timing and re-doing the grounds. I filled up before my 106 mile trip, and put 6 gallons back in when I got home, 17.6 mpg! 70/30 mix of highway/city. I really can't expect much better with my automatic.
However, whether as a consequence or coincidence, drive-ability is not what it was. Twice while accelerating from ~10 mph to ~35 mph the engine hesitated, alternating between bogging down and surging. Felt like I was behind the power curve. By backing off almost to idle and gently applying the throttle the rpm would slowly pick up. This happened while the engine was cold, didn't repeat after warming up or while driving at faster speeds.
-Derek _________________ '83 Vanagon
'72 914 |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32634 Location: Reading Pennsylvania
a2wolfsburggli Samba Member
Posted: Mon Oct 21, 2019 7:36 am Post subject: Re: Bad Gas Mileage |
-Derek- wrote: |
-Derek |
Mine did this from Idle to about 25mph. I swapped out the injector seals and all was good. What your describing is most likely a vacuum leak. _________________ Current: '87 Westfalia | '16 Audi Q5 3.0T S-Line w/sport package.
Past: '09 CC 3.6L 4motion "R36 wannabe" | '02 Audi TT "ALMS Edition" | '84 Jetta GLI with Autotech Supercharger | '89 Helios Jetta GLI 16v's (x2) | '95.5 URS6 | and the list goes on.
Never underestimate the entertainment value of OCD overruling Common Sense |
