T1mmyJ Samba Member
Joined: September 23, 2019 Posts: 7 Location: NORTHAMPTON, UK
Posted: Sun Sep 29, 2019 2:21 pm Post subject: Ted the '58 kombi |
So after dreaming (friends would say obsessing) of owning a Splitty for nearly 26years, I am finally the proud owner of a 1958 kombi called Ted.
Have lots I want to do but the three main items are:
1. Get the tin worm underneath sorted
2. Lower it (currently has been raised 2.1/2inches)
3. Front disc brake conversion.
Currently at a local workshop called Workshop 77, I will keep you updated with progress and pictures as and when. Also any advise greatly welcomed.
Thanks
Tim |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Sun Sep 29, 2019 6:03 pm Post subject: Re: Ted the '58 kombi |
looks good and i like the raised look. would love to see how the raise was done? _________________ regards
Uli
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Sun Sep 29, 2019 6:23 pm Post subject: Re: Ted the '58 kombi |
mandraks wrote: |
looks good and i like the raised look. would love to see how the raise was done? |
I would as well. Any pictures of your undercarriage? Hahaha _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Dustin B Samba Member
Joined: March 29, 2007 Posts: 1017 Location: hesperia, Ca USA
Posted: Sun Sep 29, 2019 6:43 pm Post subject: Re: Ted the '58 kombi |
62DoKaGuy wrote: |
mandraks wrote: |
I would as well. Any pictures of your undercarriage? Hahaha |
X3 please share some pictures of the front beam when you can. Possibly a bay window ball joint beam? _________________ Wanted Victoria motors licence plate frame.
62 og paint L469 type 1
61 og paint L31 DD panel type 2
64 heilite viscount tent trailer
71 sears clamshell trailer
I <3 Brazilian busses
Original paint and patina extravaganza http://www.thesamba.com/vw/forum/viewtopic.php?t=187156 |
NomadStudioBus Samba Member
Joined: August 20, 2015 Posts: 69 Location: Seneca, SC
Posted: Sun Sep 29, 2019 7:10 pm Post subject: Re: Ted the '58 kombi |
Very nice, congrats! Looking forward to seeing what you do with it.
I bought my first last year, Ted's younger brother, Froncis. a dove blue 62 kombi _________________ 61 Swivel Seat Panel |
T1mmyJ Samba Member
Posted: Tue Oct 01, 2019 2:10 am Post subject: Re: Ted the '58 kombi |
Thank you for the warm welcome folks.
Had a preliminary report back from the guys at Workshopseventy7 and the tin worm is a little more serve than first thought. There are even sections that have been stuffed with tin foil!!!!
As for the raised suspension that has also been done in a bodgeit and legit fashion. Apparently the front raise has been achieved by welding two spindles together!!! All very dangerous and all needing to be sorted.
Will try and get some photo's/videos for you to look in horror |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Tue Oct 01, 2019 10:29 am Post subject: Re: Ted the '58 kombi |
Welcome. Why is it called Ted? |
T1mmyJ Samba Member
Posted: Sat Oct 05, 2019 3:03 pm Post subject: Re: Ted the '58 kombi |
So this is a picture of the front wheel to show how the front raise was achieved. Basically a previous owner has welded a second spindle on top of the original. |
T1mmyJ Samba Member
Posted: Sat Oct 05, 2019 3:09 pm Post subject: Re: Ted the '58 kombi |
So tried to upload a video of the underneath of Ted but its to big. Safe to say the tin worm was worst then I had hoped for but not disastrous. The guys at Workshopseventy7 are doing a great job here a couple of photos of the work carried out so far.
Oh the reason he is called ted is that there is a mark on his side that looks like a teddy bear. |
Posted: Sat Oct 05, 2019 4:34 pm Post subject: Re: Ted the '58 kombi |
T1mmyJ wrote: |
certainly an interesting solution _________________ regards
Uli
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20279 Location: Sandpoint, ID
Posted: Sun Oct 06, 2019 8:42 am Post subject: Re: Ted the '58 kombi |
That looks like most lift spindles I have seen. Takes two sets to make one. As long as the welding is up to spec, it should be fine.
I searched a little bit but could not quickly find an example from a seller on here. I thought maybe Nate at Wagenswest made them, but I didn't see them on his site. _________________ nothing |
T1mmyJ Samba Member
Posted: Tue May 05, 2020 4:27 am Post subject: Re: Ted the '58 kombi |
Hello, all haven't posted for a while, but to date all the welding to the underneath has been completed, the 4in narrow front beam has been fitted along with new king and link pins and dropped spindles. Front drums have been replaced with vented calipers and just in the process of removing old brake lines and master cylinder and replacing with DCMC and new lines.
While removing the old lines I came across something that looked like a servo, on further investigation in turns out a previous owner has fitted a Hydrovac system and connected the vacuum pipe to the Weber manifolds!!!
Has anybody heard of this before?
Anyway heres a picture of how she looks at the mo.
