Frodge Samba Member
Posted: Sun Sep 29, 2019 4:18 pm Post subject: 70 beetle mainshaft |
How can you differentiate between a bad mainshaft bearing, pinion bearing, rear wheel bearing or cv? I always see the description of a bad mainshaft bearing as a howling noise? Is this high pitched? How low does a trans have to be run for this to happen?
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Sep 29, 2019 4:27 pm Post subject: Re: 70 beetle |
Mainshaft makes noise in neutral with your foot off the clutch (engine running, car stopped)
Pinion makes noise under load or decel but gets quiet coasting.
Wheel bearings make noise rolling regardless of power or coasting and often get louder or quieter when turning one way or the other.
CV's make a clicking noise under power. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Frodge Samba Member
Posted: Sun Sep 29, 2019 5:08 pm Post subject: Re: 70 beetle |
How would you describe main shaft bearing and pinion noise? |
Posted: Sun Sep 29, 2019 5:29 pm Post subject: Re: 70 beetle |
The main shaft usually makes a whirring noise, the worse it gets the more grumbly it sounds. The pinion usually exhibits a fairly loud whine that changes with speed and power. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Sun Sep 29, 2019 6:57 pm Post subject: Re: 70 beetle |
A bad wheel bearing or CV will be noise all the time in gear or in neutral while coasting. The mainshaft bearings usually only howl under load in 3rd & 4th gear and quiet down while in neutral. Usually 4th is the loudest A bad pinion bearing will howl on acceleration and deceleration. Either one doesn't really matter it will require a complete transaxle rebuild. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1170 Location: San Angelo, Texas
Posted: Sun Sep 29, 2019 7:45 pm Post subject: Re: 70 beetle |
I'll differ a bit by saying a main shaft bearing will make noise while the car is sitting still, idling, in neutral and the clutch is engaged. Push the clutch in and the noise stops (main shaft quits spinning) _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
Frodge Samba Member
Posted: Wed Oct 09, 2019 4:30 pm Post subject: Re: 70 beetle mainshaft |
What does a mainshaft bearing sound like when bad? |
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1221 Location: Kansas City, Kansas
Posted: Wed Oct 09, 2019 5:08 pm Post subject: Re: 70 beetle mainshaft |
gggg..whi...gg...whirl....gggg…..wh.....gg.gg.g.g...whir, does that sound right?
I would take off the fan belt and loosen the clutch cable and run the engine with it in neutral. That will eliminate a few items and you can see if the noise is still present or not.
Typically the mainshaft bearing that goes bad doesn't make noise at first in idle. I'd be careful forcing it to the transaxle, it might be a expensive test and replace with no positive results.
If the rear wheels of the car aren't moving, the CV's, pinion shaft (bottom half of the trans) aren't moving either.
If the trans is in gear and the rear wheels aren't moving, neither in the top half of the transaxle. The problem here is that you need toput your foot on the clutch, which presses the throw out bearing into the pressure plate and moves the crank forward. So some engine noises can be eliminated by pushing on the clutch pedal, making you think it's the trans or clutch when the motor has an extra variable to it. (I'd pull and push on your crank pulley to see if it has a lot of movement.) _________________ T1 IRS Rebuild Book on Lulu.com
http://www.lulu.com/shop/tim-marshall/t1-irs-transaxle-book/paperback/product-24055997.html
As seen in Volks America Issue 14 Page 11 (Full page review) |
Frodge Samba Member
Posted: Wed Oct 09, 2019 5:23 pm Post subject: Re: 70 beetle mainshaft |
Any sound clip of bad pinion and mainshaft bearing? I listed to Muir’s but they don’t seem very clear.... |
Onceler Samba Member
Posted: Wed Oct 09, 2019 7:03 pm Post subject: Re: 70 beetle mainshaft |
Before I replaced my main shaft bearing it sorta sounded like a road race car. Or running in reverse. I sorta thought it sounded cool. But it wasn’t cool.
Wasn’t too bad a job to replace, I marked all the shifter fork positions with an engraving tool, must’ve got lucky, but it shifts smooth and no more whine. Here’s the bearing.
_________________ 1972 Karmann Ghia |
Frodge Samba Member
Posted: Thu Oct 10, 2019 4:24 am Post subject: Re: 70 beetle mainshaft |
Wow. That looks pretty chewed up. |
Frodge Samba Member
Posted: Sat Oct 12, 2019 4:39 pm Post subject: Re: 70 beetle mainshaft |
Does anyone have any recording of mainshaft or pinion that is bad. |
Posted: Sat Oct 12, 2019 7:16 pm Post subject: Re: 70 beetle mainshaft |
Dude if it's making noise then it is going to have to be fixed. As I said before when the mainshaft bearings or the pinion bearing wears out it is time to rebuild the entire gearbox and changing the gear oil isn't going to fix it. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
