rs3 Samba Member
Posted: Sun Sep 29, 2019 11:01 pm Post subject: brake drums don't fit |
I have a 1956 convertible and just went through all the brakes. On the rear brakes I replaced everything and even had the new drums turned. The emergency brake is off, the star wheels are turned all the way in, I've adjusted the new shoes up and down to center them, etc. Nothing looks unusual but the old drums and the new drums will not go on. I had no problem with the front brake drums but the rear brake drums will not go on. The only thing I think it can be is the shoes, but they seem to match the old shoes. Here is a picture of the rear brake. Any suggestions? Thanks.
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Mon Sep 30, 2019 2:26 am Post subject: Re: brake drums don't fit |
Compare the new shoes to the old ones, I'll bet they are different _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Ovally Samba Member
Posted: Mon Sep 30, 2019 7:35 am Post subject: Re: brake drums don't fit |
rs3 wrote: |
It looks like the emergency brake is not complete off.
Regards. _________________ VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018 |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Mon Sep 30, 2019 7:53 am Post subject: Re: brake drums don't fit |
I have had the exact problems you are having. My original VW drums measure well within spec, adjusters turned ALL the way in, verified several times that the emergency brake wasn't engaged at all. One thing I did notice is that with the new aftermarket wheel cylinders, the ear of the brake shoe is much wider than the wheel cylinder slot. I had to use a cut off wheel to massage the opening larger to accept the brake shoe so it would fully seat. The brake shoe material is extremely thick on the aftermarket shoes as well. You may need to arc the shoes to the drum to get them to fit if all else fails. |
aa390392 Samba Member
Posted: Mon Sep 30, 2019 8:31 am Post subject: Re: brake drums don't fit |
Just curious, are the shoes upside down? It looks like a lot of space at the top of backing plate. ????? _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Mon Sep 30, 2019 9:08 am Post subject: Re: brake drums don't fit |
Rear shoes only fit one way...the ebrake bar notches are at the bottom. The shoes look like there is space there because the wheel cylinder piston notches are angled, just like the adjusters. I ran into the same issues the OP is experiencing. Even fit up my old shoes and the drums slid right on. I think it's combination of aftermarket parts, and the linings on the shoes being too thick. |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Mon Sep 30, 2019 12:18 pm Post subject: Re: brake drums don't fit |
The right side shoe looks like it has thicker lining than the left side shoe.
Are you tapping the shoes up and down to get them centered as you are putting the drum on? It's probably just the camera angle but it looks like there is more space between the outer rim of the backing plate and shoes at the top than there is at the bottom. |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Mon Sep 30, 2019 12:34 pm Post subject: Re: brake drums don't fit |
looks like the wheel cylinder needs to be pushed in. the e-brake push rod does not look bottomed out on shoe? did you de-adjust the e-brake adjustment? just grab the shoes near the bottom and push. if they go in your fine. if not the e-brake is adjusted too tight. everything looks right otherwise. but the gasket on the bearing cap looks ripped and pushing out on the top?
Steve _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Ovally Samba Member
Posted: Mon Sep 30, 2019 7:46 pm Post subject: Re: brake drums don't fit |
The parking brake shoe lever must be at least parallel to the bearing cover (and even more to the left).See red line.
Adjust both cables of the parking brake lever in the car so that they are more loose and try to install the brake drums over the brake shoes again.
Regards.
VW Bug 1200 D motor
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Mon Sep 30, 2019 8:45 pm Post subject: Re: brake drums don't fit |
I have never worked on a 56 convertible, but your backing plate is upside down. Every Bug I have removed the rear drum on had the wheel cylinder on the top. Maybe that would help. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Mon Sep 30, 2019 9:23 pm Post subject: Re: brake drums don't fit |
well you never worked on one that old I guess. they are on correct. the first time a put brakes on my 55 I tripped out. .I still say the e-brake is adjusted too tight. common mistake .the e-brake stops holding the car on a hill so they tighten the cables. when they should be adjusting the shoes instead. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
rs3 Samba Member
Posted: Mon Sep 30, 2019 10:52 pm Post subject: Re: brake drums don't fit |
Thank you everyone for your input/suggestions. I know my bearing cap gasket is torn but I think the gasket is in place behind the bearing cap. It's new, so I'm hoping it doesn't leak. Maybe I should pull it off and replace the gasket?
I will loosen up my emergency brake cables inside the car so that the bar is vertical or to the left. |
Ovally Samba Member
Posted: Tue Oct 01, 2019 12:41 am Post subject: Re: brake drums don't fit |
VW_Jimbo wrote: |
... the wheel cylinder on the top |
From the model year 1958 (started in August '57) the rear wheel cylinder is at the top.
(@ VW Jimbo : your Bug 1954 must have the rear wheel cylinder at the bottom)
VW Bug 1200 D motor
Posted: Tue Oct 01, 2019 8:12 am Post subject: Re: brake drums don't fit |
ya that is a good point. same as his 54? maybe he wasn't awake yet? I have done that myself. anyway I would change the gasket. why chance it. do it right once. looks like you did a nice job . no sense in making it a oily mess now.
64 crew cab
55 rag top beetle
66 beetle
bwaz Samba Member
Posted: Tue Oct 01, 2019 11:49 am Post subject: Re: brake drums don't fit |
Ovally wrote: |
VW_Jimbo wrote: |
Regards. |
Mostly. My 58 Square window beetle leaving the factory August 2, 1957 has the wheel cylinder at the bottom. |
0nebadbug Samba Member
Joined: October 01, 2009 Posts: 1087 Location: Rockford, Illinois
Posted: Tue Oct 01, 2019 12:10 pm Post subject: Re: brake drums don't fit |
What years are your rear drums...
Only reason for asking this is for two reasons...
1, If you know, beyond a shadow of doubt, you are still on original drums, you may have a wear lip that can make it quite difficult to fit over the new shoes & would necessitate having the drums cut ... or at least the wear lip removed to allow them to slip back on...
2, if you have later drums, they may have the same wear lip issue as well as the back outer drums lip will need ~2mm material shaved off of the outer lip to allow them to seat all the way in without rubbing the original backing plates as well...
And yes, the brake cylinder indeed does go at the bottoms on the 1957 model year... top mount cylinders only started with the 58 (non-oval) model year backing plates... _________________ ::: Slowoval ::: LaDawri Sebring ::: '61 Creampuff ::: Dust Storm '66 :::
qwerty Samba Member
Snort Samba Member
Posted: Tue Oct 01, 2019 12:37 pm Post subject: Re: brake drums don't fit |
Bentley claims the frame change for the new shorter brake cables started with chassis number 1604758 (August) and at that time they rotated the rear backing plates 180 degrees to accommodate those front-entering cables which would place the wheel cylinders on top.
Bwaz, does your 58 have those shorter hand brake cables which exit the frame a couple inches further forward than the Oval frames? How does your frame number match up with this Bentley information?
The next change according to Bentley, was chassis number 1673351 (October) where all the wheel cylinders, drums backing plates etc. were changed to to the later style which of course also has the top mounted rear wheel cylinders. |
Posted: Tue Oct 01, 2019 9:47 pm Post subject: Re: brake drums don't fit |
Thank you, all. I do not remember seeing the wheel cylinders on the bottom. Been 22 years, since I last worked on an Oval. There were 4 that I worked on at the independent VW repair shop I worked at. But man, I seriously did not remember that. Still don’t. Still have not removed the rear drums on the 54. Looks like I will not be too surprised now! _________________ Jimbo
TDCTDI wrote: |
Posted: Tue Oct 01, 2019 10:02 pm Post subject: Re: brake drums don't fit |
Just noticed the outer lip on the seal is not sitting correctly. You need to grease the lip before installing the collar and turn it while installing it. If the lip still folds in, you can take an automatic tranny seal setting tool, to get it into the correct position. Yellow circle.
TDCTDI wrote: |
