Vanagon Nut Samba Member
Posted: Mon Sep 30, 2019 5:56 pm Post subject: "Lazy" Brake Light Switch? Real Time Help? |
Hi folks.
I did a quick search by title but.....
Can a "lazy" or "marginal" brake light switch make it so the driver has to push the pedal harder than normal to light up the brake lights?
My brake lights work but I have to push the pedal "hard" to get them to light up. i.e. the brakes engage before lights come on.
With a volt meter connected to each switch:
one meter shows the switch closest to booster closing first. Both close.
Is that because that switch gets hydraulic pressure first? Or.....
Do I have a "lazy" switch? i.e. if I replace the switch further from booster will this help my brake lights come on "sooner"? (less pedal pressure)
Some time ago, I had the same "issue" on my '81. One switch had failed. Replacing it helped the brake lights come on "sooner".
Thanks
1988 West DIY 50º ABA
VE7TBN |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Mon Sep 30, 2019 6:34 pm Post subject: Re: "Lazy" Brake Light Switch? Real Time Help? |
Often as the switches are failing they require more and more pressure to function. Might be time to replace both.
On another car with a similar switch I added a mechanical switch, this one:
https://www.amazon.com/gp/product/B000E5DILY?psc=1...PDKIKX0DER
Just a simple bracket that allows the switch to be pressed when the pedal is at rest does the job. |
Franklinstower Samba Member
Posted: Mon Sep 30, 2019 7:08 pm Post subject: Re: "Lazy" Brake Light Switch? Real Time Help? |
Yes.
Recently while driving, i was told my brake lights aren't coming on. I checked this at a stop with my wife and it took her immense foot pressure to get the light to come on.
Went to flaps, grabbed a new switch, light now comes on as it should. $10 bucks and 20 minutes. _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
Posted: Mon Sep 30, 2019 7:33 pm Post subject: Re: "Lazy" Brake Light Switch? Real Time Help? |
Thanks much people.
Ok. I'll likely replace both switches. I can get my hands on some good quality new ones. (made in Spain IIRC)
At first I thought I was seeing differences in resistance between the two switches but then I swapped the meters and for some reason, they now show very similar resistances. Not that that really matters per se.
VE7TBN |
danfromsyr Samba Member
Posted: Tue Oct 01, 2019 6:03 am Post subject: Re: "Lazy" Brake Light Switch? Real Time Help? |
this problem happens when the internal contacts get pushed further IN and then require more pedal pressure to make the contacts.
the 'cheap' replacements will do this after a hard/panic stop..
I've added a mechanical switch as well into the circuit. |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3098 Location: ABQ NM USA.... Except when not
Posted: Tue Oct 01, 2019 7:50 am Post subject: Re: "Lazy" Brake Light Switch? Real Time Help? |
Vanagon Nut wrote: |
Thanks much people.
Neil. |
tighten just enough. tightening too much can crack the master cylinder since the threads are tapered...which seems like a bad/leaking switch. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10250 Location: N. Idaho
Posted: Tue Oct 01, 2019 8:17 am Post subject: Re: "Lazy" Brake Light Switch? Real Time Help? |
A $4 upgrade at most U-pull junkyards will get you the roof top mounted high mount LED stop lamp unit. Two phillips screws and its yours. Fits perfectly on Vanagon's rear roof edge with 3M double stick tape or screw it down. Worthy so you have that in case tail lamp wiring fails, or with a distracted driver behind you.
EDIT: Wups, would have been very helpful if I'd mentioned which car. So, all Suburbans, Yukons, and full size GMC/Chevy SUVs with the body of the 93 model year have a bolt on LED third brake light that's cake to grab. Pull some wire up out of the roof so you can easily splice it into your tail light wiring. Looks factory on my Vanagon. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader
Posted: Tue Oct 01, 2019 9:12 am Post subject: Re: "Lazy" Brake Light Switch? Real Time Help? |
vanis13 wrote: |
tighten just enough. tightening too much can crack the master cylinder since the threads are tapered...which seems like a bad/leaking switch. |
I didn't know they were tapered threads. Makes sense as I recall there was more torque required on last few turns. I was careful not to torque them too hard.
VE7TBN |
Posted: Tue Oct 01, 2019 9:23 am Post subject: Re: "Lazy" Brake Light Switch? Real Time Help? |
danfromsyr wrote: |
IdahoDoug wrote: |
A $4 upgrade at most U-pull junkyards will get you the roof top mounted high mount LED stop lamp unit. Two phillips screws and its yours. Fits perfectly on Vanagon's rear roof edge with 3M double stick tape or screw it down. Worthy so you have that in case tail lamp wiring fails, or with a distracted driver behind you. |
I've considered a third light or even a flashing third light, if that kind of thing even exists. Ironically, having to lightly pump the brakes to activate the lights probably got drivers attention (I watch how close they are). Then again gearing down can catch them off guard. Between cruise control and most people driving automatics some drivers pay less attention now these days; they're really used to seeing brake lights when a vehicle slows down. Years ago I'd had an idea to make an adjustable motion activated third brake light. It would come on after the regular brake lights did when the pedal was pushed harder. (more inertia forward would activate the third light switch). e.g. useful for drivers who ride the brakes then suddenly have to use them. [edit but I recall now that with a switch like that, driving downhill would be problematic LOL ]
Didn't know the failure mode of the switch. Helpful to know. I recall seeing posts here about adding a mechanical switch at the pedal.
I'm lucky to have a parts guy who is as particular as he can be about parts sourcing. The switches he has are purported to be better than some.
VE7TBN |
