sinclair Samba Member
Joined: July 01, 2004 Posts: 398 Location: New Forest UK
Posted: Wed Oct 02, 2019 9:28 am Post subject: Can this industrial engine be dated. |
My 52 received a nos Industrial engine a couple of years ago. Can it be dated from the number? And what’s the spec. Anyone know?
fes Samba Member
Joined: January 26, 2011 Posts: 999 Location: Prince Edward Island
Posted: Wed Oct 02, 2019 10:02 am Post subject: Re: Can this industrial engine be dated. |
From what I can tell in the Technical section here https://www.thesamba.com/vw/archives/info/industrialdating.php
Looks like July 1955..36HP _________________ '68 Campmobile-Pedro
'15 Golf-Stella Blau
'56 Oval-The Turd (for now)
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Wed Oct 02, 2019 10:48 am Post subject: Re: Can this industrial engine be dated. |
Many parts have date codes. You can looks at the top of the condenser for one.
This one has 034 which is;
_________________ Glenn
Member #1009
#BlueSquare |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Wed Oct 02, 2019 11:41 am Post subject: Re: Can this industrial engine be dated. |
on the side of the generator stand. distributor side. there should be 3 #'s in circles . month/ day/ and year. the #'s in the technical section does not show industrial numbers. I don't think ?
Steve _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
fes Samba Member
Posted: Wed Oct 02, 2019 1:16 pm Post subject: Re: Can this industrial engine be dated. |
sgmalt46 wrote: |
Steve |
It does.. I fixed my link that I posted earlier _________________ '68 Campmobile-Pedro
'56 Oval-The Turd (for now) |
Posted: Thu Oct 03, 2019 12:22 am Post subject: Re: Can this industrial engine be dated. |
Thanks guys. Very much appreciated. Good people on here |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Thu Oct 03, 2019 6:00 am Post subject: Re: Can this industrial engine be dated. |
sgmalt46 wrote: |
on the side of the generator stand. distributor side. there should be 3 #'s in circles . month/ day/ and year. |
Just to remember that is simply the casting date of the case. It could be before or after the date the engine was actually produced. |
slalombuggy Samba Member
Posted: Thu Oct 03, 2019 3:27 pm Post subject: Re: Can this industrial engine be dated. |
nlorntson wrote: |
sgmalt46 wrote: |
Pretty hard to produce an engine before the case is cast
brad |
Posted: Thu Oct 03, 2019 4:02 pm Post subject: Re: Can this industrial engine be dated. |
slalombuggy wrote: |
brad |
Yes, production for sure, but for example a case for a 25hp engine was cast in 1956. In this example (a true one at that) the casting date was much later than the production of the 25hp engine. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Fri Oct 04, 2019 3:46 am Post subject: Re: Can this industrial engine be dated. |
The distributor badge looks like it says BR 25. That distributor was produced from late 1959 through the 1960 model year. the badge design eliminates it as a 1955 ish distributor. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Fri Oct 04, 2019 3:49 am Post subject: Re: Can this industrial engine be dated. |
Glenn wrote: |
2nd quarter of 1970. _________________ Roads Scholar &
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Sat Oct 05, 2019 10:56 pm Post subject: Re: Can this industrial engine be dated. |
tasb wrote: |
The distributor badge looks like it says BR 25. That distributor was produced from late 1959 through the 1960 model year. the badge design eliminates it as a 1955 ish distributor. |
The BR25 was later renamed by Bosch to 010, a very good distributor when running Twin carb setup. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
Frederik Samba Member
Posted: Tue Dec 17, 2019 4:19 pm Post subject: Re: Can this industrial engine be dated. |
Sorry for lifting an old thread, but didn't the engine number get interpreted wrong?
A (0)9000 serial (after the 122 industrial coding) might have been july 1955 but this is a 5 digit (0)90000 serial, 122-099501 = more likely a 1961 36hp industrial engine (and fits better with the fuel pump, br25 and other parts on it.
Here's another one for you (just bougt it but haven't got it jet).
Posted: Wed Dec 18, 2019 1:09 am Post subject: Re: Can this industrial engine be dated. |
Frederik wrote: |
Thats interesting. I did check the date circles on the stand, first one being 25 which equates to 1955 I thought? |
Posted: Wed Dec 18, 2019 10:53 am Post subject: Re: Can this industrial engine be dated. |
First date circle should be Day. So 25 XX ZY is the 25th of XX (month) and Y (year), Z being shift. Post a photo. However the engine number 090000 is way to high to be a 55, my 021000 above should be a June/Juli 1956 |
Posted: Wed Dec 18, 2019 12:40 pm Post subject: Re: Can this industrial engine be dated. |
10/6/25
Posted: Wed Dec 18, 2019 12:50 pm Post subject: Re: Can this industrial engine be dated. |
The ones I have are stamped from the bottom up. On this they are facing the other way/ the numbering is mirrored (turned 180 degrees), but I think you should reed it as 25 6 01 as in 25th of june 1961 or possible 25th of June 1st shift 1960.
Posted: Wed Dec 18, 2019 1:05 pm Post subject: Re: Can this industrial engine be dated. |
Frederik wrote: |
The ones I have are stamped from the bottom up. On this they are facing the other way/ the numbering is mirrored, but I think you should reed it as 25 6 01 as in 25th of june 1961 or possible 25th of June 1st shift 1960. |
Mmm. Not sure I buy that but willing to stand corrected. |
Posted: Wed Dec 18, 2019 1:21 pm Post subject: Re: Can this industrial engine be dated. |
Whats the left case half date code? Does the case have a oil drain plug (not the one in oil strain cover)?
Posted: Thu Dec 19, 2019 5:02 am Post subject: Re: Can this industrial engine be dated. |
60s 36hp have no oil drain plug in the case but have the casting for it
A -55 should have the oil drain plug in the case
(Pictures from gallery) |
