nadodave Samba Member
Joined: April 19, 2011 Posts: 37 Location: Coronado, CA
Posted: Wed Oct 02, 2019 12:31 pm Post subject: Converting from strut to beam front end |
So I had purchased a 71 bug some time ago, and finally got around to starting work on converting it to a speedster replica. So, imagine my surprise when I discovered the bug was actually a super beetle! (I had thought all super beetles had the extended dash, but evidently not so.) I am told that everything on a super beetle is the same as a standard bug from the "bulkhead" back, but in order to install the speedster body, I must change to a beam front end. My questions:
1) If I buy a Front Frame head replacement from Raybuck (or somebody), can it be welded on to the front of a super beetle frame, or is something else required? And,
2) Do I want a link pin or ball joint front end for a Speedster Replica?
Thanks in advance. _________________ Nadodave
Coronado, CA |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Wed Oct 02, 2019 2:58 pm Post subject: Re: Converting from strut to beam front end |
Back in late 80's CMC had a conversion kit but of course no longer available. You can grind off the numerous spot welds and remove the Super's front assembly and then weld on the standard beetle replacement pieces that are readily available. You need the front frme head assembly ($230) plus the ball jointfront beam assembly with torsion bars, spindles and brakes (go disc). It has to be welded precisely though. I'd have a frame shop with a frame table do it. It might be worth having them shorten the frame too (even if you mark and cut where needed).
Be sure to sign up at Speedsterowners.com - for more Speedster advice.
Another thought is to go to with a CoolRydes front suspension
https://www.coolrydescustoms.com/t-1-front-suspension.html _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
oprn Samba Member
Joined: November 13, 2016 Posts: 12730 Location: Western Canada
Posted: Wed Oct 02, 2019 4:55 pm Post subject: Re: Converting from strut to beam front end |
Pitty you bought the wrong Bug! Any chance the body as a whole is good enough to restore? If so someone just might swap you for a regular Bug chassis.
The Super Beetle is superior in ride and handling for a driver. |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
Bkhansen93 Samba Member
Joined: July 14, 2018 Posts: 207 Location: Coal City, Il USA
Posted: Thu Oct 03, 2019 10:25 am Post subject: Re: Converting from strut to beam front end |
You can replace the frame head from a standard and put a beam on. My buggy is an SB with a transplant on the front. Not hard to do at all. Just cut everything off from the napoleon hat forward and weld the standard front on. |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Thu Oct 03, 2019 11:15 am Post subject: Re: Converting from strut to beam front end |
I think ball joint would work better for your Speedster, easier to adjust camber
and simpler to remove leaves to soften the front end for the lighter Speedster body
slalombuggy Samba Member
Posted: Thu Oct 03, 2019 3:22 pm Post subject: Re: Converting from strut to beam front end |
See if you can find just a bare pan from an non SB car and when you cut the pan to shorten it use the front part from the second pan and the rear from the SB pan. Way easier than cutting the pan twice and getting 3 pieces lined up. Also much stronger. I've done a ball joint to link pin swap on a 71 pan and it's a lot of fitting and fabrication
brad |
coolrydes Samba Member
Posted: Mon Oct 07, 2019 5:53 pm Post subject: Re: Converting from strut to beam front end |
Wolfgangdieter wrote: |
https://www.coolrydescustoms.com/t-1-front-suspension.html |
We have a front end that fits right on to the Super beetle bulkhead, no frame head change. and far better then any beam
_________________ Kevin "Coolrydes" Zagar
COOLRYDES So-Cal CUSTOMS
MENDEOLA SUSPENSION
THE HOME OF STYLE AND PERFORMANCE
www.CoolRydescustoms.com |
dustymojave Samba Member
Posted: Sat Nov 02, 2019 7:06 pm Post subject: Re: Converting from strut to beam front end |
But will that front end fit under the Speedster body? _________________ Richard
SoCalBajas Member
Posted: Sun Nov 03, 2019 6:57 pm Post subject: Re: Converting from strut to beam front end |
Oh yeah!!!
MENDEOLA SUSPENSION
