vwtaiwan Samba Member
Posted: Fri Oct 04, 2019 8:01 am Post subject: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
Share my small power big fun engine build.
Stock 85.5
none counterweight balanced 69mm crank
4kg Flywheel
Stock 35.3 x 32 cylinder heads
9.3 : 1 CR
W110 camshaft
twin 40IDF with 28 choke
57 idle jets
128 main jets
167 air corrections
stock 1971 superbeetle 1302 gear box none LSD
205/50/16 front
225/45/16 rear
[/youtube]https://www.youtube.com/watch?v=FhUst4UD79w
Posted: Fri Oct 04, 2019 8:03 am Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
Xevin Samba Member
Posted: Fri Oct 04, 2019 8:42 am Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
Looks fun. What exhaust you running _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Fri Oct 04, 2019 8:47 am Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
Xevin wrote: |
Looks fun. What exhaust you running |
Thank you bro ~~ _________________
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Fri Oct 04, 2019 10:18 am Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
So wait...
Are you drifting with the “small power big fun” engine?
I didn’t think a 1600 would do that so I built a 2276 for my Ghia.
By the way, I put the 43mm 740 Merged Comp with the 150mm exhaust on it.
I’m glad you guys are doing what you do. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Fri Oct 04, 2019 3:45 pm Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
jeffrey8164 wrote: |
So wait...
I’m glad you guys are doing what you do. |
Thank you so much my friend ! _________________
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Fri Oct 04, 2019 4:57 pm Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
So wait...
Yes, they will. Back in the day one of the most popular engines was the 88x69 1679cc screamer. Right cam, compression, and heads and a small cc motor can be pretty stout. _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
Posted: Fri Oct 04, 2019 7:08 pm Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
fivelugshortaxle wrote: |
So wait...
Yes, they will. Back in the day one of the most popular engines was the 88x69 1679cc screamer. Right cam, compression, and heads and a small cc motor can be pretty stout. |
Yeah.
Whatever, Mr. 2332
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sat Oct 05, 2019 5:36 am Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
Nice! Looks like it runs pretty good! I thought i read that everyone says not to run a W110 on a stock size engine. Appears to work well enough. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Sat Oct 05, 2019 11:54 am Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
Sounds great!! Man you must be running some small CC heads?? _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
QRP Samba Member
Joined: April 27, 2008 Posts: 1710 Location: NORTH HOLLYWOOD,CA
Posted: Sat Oct 05, 2019 4:20 pm Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
vwtaiwan wrote: |
Stock 85.5
4kg Flywheel
9.3 : 1 CR
W110 camshaft
57 idle jets
128 main jets
167 air corrections
205/50/16 front
225/45/16 rear
I kinda always kept this to myself but I think every type 1 engine should be able to run 4000 RPM like that all day long without overheating.
If it can't then is it really worth having in your bug?
NICE WORK VWTAIWAN !!!
whats your speed at 4000 in 4th?
and got anymore details on the engine?
Valve train and cooling system? |
Posted: Sat Oct 05, 2019 10:53 pm Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
So wait...
Yeah.
Whatever, Mr. 2332
Lol...the 1679 screamer was very popular back in the day.... ow, definitely not stout like a 2 liter but it can be built to perform very well. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sun Oct 06, 2019 1:30 am Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
What kind of fuel are you using? |
Posted: Sun Oct 06, 2019 5:10 am Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
FreeBug wrote: |
we have 98 RON here. _________________
Posted: Sun Oct 06, 2019 5:17 am Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
QRP wrote: |
vwtaiwan wrote: |
Stock 85.5
4kg Flywheel
9.3 : 1 CR
W110 camshaft
57 idle jets
128 main jets
167 air corrections
205/50/16 front
225/45/16 rear
4000 in 4th is about 80mph
Engine detail :
Balanced Stock crank
all moving parts were balanced also
4kg flywheel
I like 35.5 x 32 head, in order to keep air velocity. Bigger valves not possible to drift.
Single heavy duty valves and thick wall Alu. push rods.
W110 with 9.3:1 compressor is the key to make power ~ _________________
Dake Samba Member
Joined: September 02, 2014 Posts: 481 Location: Georgia
Posted: Tue Oct 08, 2019 7:17 am Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
vwtaiwan wrote: |
Xevin wrote: |
Thank you bro ~~ |
So witch VS is it? |
74 Thing Samba Member
Posted: Tue Oct 08, 2019 7:38 am Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
In the first link are you really going approx 109mph in 4th gear? |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Tue Oct 08, 2019 8:27 am Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
Dake wrote: |
vwtaiwan wrote: |
Xevin wrote: |
Thank you bro ~~ |
On the video above, it states SS143 _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7214 Location: Videbaek Denmark
Posted: Tue Oct 08, 2019 9:52 am Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
109 mph top speed sounds about right.
The 143 is actually a quite decent set up. About the best style they make. Just a shame that it cannot be run with heater boxes. That would have increased sales tremendeusly in Europe at least. |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1291 Location: Modesto, CA
Posted: Tue Oct 08, 2019 10:24 am Post subject: Re: 9.3 : 1 W110 with Stock 85.5 x 69 Daily Bug Engine build. |
On their site I see the SS143 WITH heater boxes _________________ (o\_i_/o) I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants. |
